Best Way To Remove 02 Sensor That Was Never Touched For 300,000?
6 replies to this topic
#1 slashmaster
slashmaster
  • 55 posts
Posted 03 April 2010 - 10:46 PM
Apparently no one replaced the 02 sensor since the car was new so will be a oh yeah! to get out. The only thing I have that will fit the 7/8" of the 02 sensor is a 6 point 7/8" socket and a adjustable wrench. Surely I'll round it off if I use the adjustable wrench right? Shall I smash away the top of the old o2 sensor and use the 6 point? I could go out and buy a 7/8" wrench but looks like the flange of the cat might get in the way.
#2 Patdon10
Patdon10
  • 183 posts
Posted 04 April 2010 - 03:02 AM
What car? I'll assume an N/A 240. It might not actually be as bad as you think. Mine came out pretty easily. If you are definately going to remove it, you can cut the wire and use a socket.
Spray it down with PB blaster for a few days before hand. When you are ready to remove, start your car and let it run for 10 minutes or so. Get some gloves, because that header pipe is going to be hot and you WILL burn yourself if you touch it with your bareskin. From there, it's just a wrestling match. Once you get it to initially break free and start spinning, it should be easy from there. You may need a torque bar for this.
#3 blackknight
blackknight
  • 142 posts
Posted 04 April 2010 - 02:50 PM
Unplug the wire leading to the o2 sensore and thred it through the box end of your wrench. PB Blaster is the stuff, you should have some in your toolbox!!!
90' 245dl
"I won't be wronged, I won't be insulted and i won't be laid a hand on. I do these for other men, and require the same."
"Life is like a jar of jalopenos; what you do today may burn your @$$ tomorrow"
#4 DHV70
DHV70
    Deadbeat, owes people money Derrick Hendrickson 860-841-0504
  • 576 posts
Posted 04 April 2010 - 05:43 PM
Don't bother trying to run the car. That won't heat it up. Your best bet is to use a propane torch or something. They're cheap, they've got a million uses, and this is definitely one of them. If you don't have one, to the store with you!
In all seriousness. I had to use a box wrench on my 855. The sockets are generally too awkward for the area, in my opinion. It took me a good 30 minutes of heating the thing up to get it off though.
No matter how you heat it, be aware that your wrench or socket will get just as hot <_<
Good luck!
Deadbeat, owes people money.
39 olde hall rd.
Hebron, CT 06248
Cell Phone: 860-841-0504
Home phone: 860-530-1325
Mom's Work phone: 860-486-4120 You may get results with her. who knows.
Derrick's email: DHendrickson117@gmail.com
http://volvospeed.co...0
#5 Guest_slashmaster_*
Guest_slashmaster_*
Posted 14 April 2010 - 02:13 AM
I did it, After it soaked several hours with penetrating oil I smashed off the top of the old sensor with a hammer so I could use a normal 6 point socket, once it initially started to turn had to turn it back in and out several times until I got it out. Got the new one in with an adjustable wrench and hooked it up but the motor still doesn't idle right. Guess I have to bring it back to someone with a code reader so they can reset the check engine light?
#6 Guest_nctrooper10722001_*
Posted 04 June 2010 - 12:04 AM
PB Blaster= You dont need a wrench.. it'll screw itself out! :lol:
#7 Three Fat Tigers
Three Fat Tigers
    RWD Moderator
  • 1,752 posts
Posted 06 June 2010 - 05:58 PM
No code reader required to retrieve the codes:
http://www.brickboard.com/FAQ/700-900/EngineOBDCodes.htm
