I picked up a set of S70 door handles to swap into my 850. I have installed three of them with no problem. I am now stuck on the front drivers side. I had originally thought that I could swap lock cylinders from my 850 into the S70 handle. It seems that the two lock cylinders are of a different design and are not interchangeable. Am I missing something or will I have to use a passenger side handle (without the hole for the lock) on the front drivers side?
Or can I use the drivers side handle and modify the S70 cylinder to make just a dummy lock for cosmetic purposes?
Hopefully my key fob works, or else Ill just have to use the trunk to lock/unlock.
If you have done this common mod, what did you do?
Thank you!
Edited by TorqueSteer, 08 May 2010 - 03:15 PM.
