Front Brakes 940 Turbo Wgn
Started by steelman, May 18 2010 06:47 PM
1 reply to this topic
#1
Posted 18 May 2010 - 06:47 PM
I have a problem with the front bakes bumping (bump-bump-bump) when applied. I figured rotors and pads, so I replaced said items. Same symptoms persist.
Can or will someone please tell me what I have missed and what to look for. Thanks.
#2
Posted 03 June 2010 - 12:41 AM
I've seen this only 1 time. It was on a nissan van doing the same.. It was a bent front hub assy. Pull the wheels and see if you get a slight wobble when ya spin them, watch the studs when spinning to see if ya have warpage to the hub.. And do this on both sides and lemmie know what the result is..
P.S. ALSO try it with the wheels on..I've seen this only 1 time. It was on a nissan van doing the same.. It was a bent front hub assy. Pull the wheels and see if you get a slight wobble when ya spin them, watch the studs when spinning to see if ya have warpage to the hub.. And do this on both sides and lemmie know what the result is..
I was here, but you were gone. Now you're here and I'm gone.. 10-4
