Moving Lock From 850 To S70 Door Handle
Posted 21 May 2010 - 06:35 PM
I know how to pull the 850 tumbler (put in key, push spring with flat head, pull out), but not the S70 tumbler. And once they are out, do they simply swap in?
Serge - 95 850 T5
Posted 21 May 2010 - 06:50 PM
http://volvospeed.co...grade-for-850s/
Looks like I'll have to re-pin the S70 lock, which I think I can manage.
But I still need to find out how to remove the tumbler from the S70 lock w/o the key.. any ideas?
Serge - 95 850 T5
Posted 21 May 2010 - 06:53 PM
Your best method to get the S70 key to work is to re-key the tumbler to accept your 850 key.
http://www.zeebuck.c.../doorlocks.html
Try using moving around the stock plates to get it to accept it as best as possible, then with the remaining plates that just don't fit, dremel them so that they do accept the key. It's best to try to keep all the plates in (for security reasons).
Posted 21 May 2010 - 06:55 PM
No, the S70 key tumbler is not swappable. It's a completely different design with exception of the key design acceptance..
http://www.zeebuck.com/bimmers/tech/doorlocks/doorlocks.html
Will do. Any suggestions on how to take the S70 tumbler out? It would seem like it will be impossible unless you have the key in.
Edited by LiquidKernel, 21 May 2010 - 06:55 PM.
Serge - 95 850 T5
Posted 21 May 2010 - 06:58 PM
work from the furthest plate and slowly pull out the tumbler.
edit... MacGyver
Posted 21 May 2010 - 07:00 PM
um..the MacGuyer method... hairpins and screwdrivers, toothpicks, whatever you can do to pick the tumbler.
edit... MacGyver
Was afraid of that. Looks like it's time to pickup some lock picking skills. I need to look at the lock more closely and see if the pins are visible from the outside.
Serge - 95 850 T5
Posted 21 May 2010 - 07:05 PM
There's only 10 plates in there, so it can't be that hard.
Posted 21 May 2010 - 11:50 PM
And that will unlock it real easy.
Or, just pick it.
1976 BMW 2002 - 13" Period BBS, slammed Hard.
Posted 22 May 2010 - 11:41 PM
Posted 22 May 2010 - 11:44 PM
Edited by TorqueSteer, 22 May 2010 - 11:45 PM.
Posted 23 May 2010 - 03:30 AM
There's gotta be a way to use the 850 tumbler in an x70 handle.
No can do. Like I said earlier, the 2 door handle designs are completely different. Volvo redesigned the S70 one to use plastic, so the tumbler snaps in completely differently whereas the 850 was made with metal... Infact the S70 tumber has a larger diameter..
Posted 10 July 2010 - 10:23 PM
To take the S70 tumbler assembly out of the handle, I just inserted my 850 key, then turned it as much as possible (moves maybe 1mm but its enough to "grab"), at the same time I pulled the key while pressing in on the little retaining clip and the lock slid right out.
I tried that, didn't really work. Did you use a vise?
Serge - 95 850 T5
Posted 10 July 2010 - 11:07 PM
1993 Mercedes-Benz 190e 2.3 91k still broken
1996 Volvo 855 GLT-R 320+k and going ( Project GLT-R)
1998 Subaru Outback SUS -Daily Driver
Volvo for LIFE......
#14
Posted 11 July 2010 - 01:34 AM
the tumbler is held in by a pin to the handle and you dont need a key to get it out, i havent figured out how to take the tumbler apart yet, ive tried everything, i need to get a few extra tumblers to mess around with.
Which part? The circular part that accepts the key is the tumbler. It's supposed to slide out of it's larger metal assembly and leave a circular hole.
Serge - 95 850 T5
#15
Posted 11 July 2010 - 02:33 AM
#16
Posted 11 July 2010 - 06:33 AM
Serge - 95 850 T5
#17
Posted 11 July 2010 - 02:53 PM
I think I screwed up my terms. I was just referring to removing the entire lock assembly from the plastic handle.
#18
Posted 12 July 2010 - 07:18 AM
Ahhh. Yeah, that's just held in by a few clips. So far it seems like picking it is the only way.
Serge - 95 850 T5
#19
Posted 12 July 2010 - 02:49 PM
can't you just leave the lock in there? why remove it if the 850 assembly wont fit in there anyway.
1996 854 T5M
1996 854R (Euro-spec) 5 speed
#20
Posted 12 July 2010 - 03:35 PM
850 and x70 tumbler side by side
Now you have to access the keys, first you have to pry off the locking ring around the top of the tumbler
be careful cause the ring can break, under that is the locking ring, most likely they will come out together, once out the tumbler will slide out of its metal casing and look like this
then the tumbler is exposed and can be pulled out of its smaller case to access the tumbler keys.. be careful when pulling the tumbler to get to the keys, as the keys are under tension and can pop out..
from there is basically trial and error rearranging the tumbler keys, with your 850 key in the tumbler. when you have the right tumbler key, your key will slide in and turn freely without any snagging. its best to do 1 at a time, starting from one end this way you know all the preceding keys work. you may not have all the right keys needed, so it is best to have a spare tumbler for extra keys, or the dealer may have some for you. i currently have 1 tumbler key missing from my tumbler, but my key fits fine. i am have problems locking my car with the key, but i can unlock it which is most important. i always use my fob, so there is no need to use the key unless the fob goes out.
The locking pin shaft thing, that goes into the door, it won't an 850 fit because the end on x70 one is too tall compared to the 850 one. you just have to dremel the sides a bit and it will fit in. when installing the lock, i found it best to completely install the door handle first, then insert the door lock into the door handle, so the shaft lines up inside the door.
Rob
Edited by echo5625, 12 July 2010 - 03:42 PM.
