Groaning Noise
Posted 22 May 2010 - 05:54 PM
It only groans while in Drive, Reverse, or Low. It groans while driving AND while idling, especially under load. The groan noise goes higher/lower in pitch depending on the RPM. It goes away when put into Park or Neutral. So I am mostly assuming bad transmission. But, it shifts like new. No leaks at all. Noise doesn't seem linked to steering pump.
I've checked the engine joints, and they seem fine.
I've checked the axles, and they seem fine.
I just flushed the transmission, and it didn't make a difference.
Recently, I've located the noise to be just below the turbo area...so now I'm thinking, this could easily be a bad turbo bearing!?
But do our turbos cut out when put into neutral and park?
1997 Volvo GLT w/ 116,000 miles.
Thanks for any help! Otherwise, I'm almost ready to take her in and have a professional diagnose the sound (which can get costly!)
Posted 22 May 2010 - 08:30 PM
By stating that it goes away in neutral or park, I have to assume that it only makes the noise while the car is moving? If this is the case, have you ruled out your front hubs? When that bearing starts going bad it can make a variety of sounds.
Posted 22 May 2010 - 10:58 PM
N. Virginia
Posted 22 May 2010 - 11:36 PM
Doesn't sound like a turbo issue to me unless you want to include heat shield to the equation.
Posted 23 May 2010 - 02:39 AM
There is no vibration, and it's definitely not a rattle. It sounds like an engine or transmission groan to me, and less bearing sounding.
Because it only happens in gear, even while stationary, I have to assume it's the transmission. And although it's RPM related, I cannot get the noise to happen when in neutral or park. But it shifts sweet, which makes no sense if it's the transmission.
Could the transmission fluid pump be going out?
About the only thing I can relate the groaning sound to is the sound of a hydraulic press.
Posted 23 May 2010 - 04:11 AM
Based on everything you've said and already ruled out, the transmission pump is a logical candidate for being the culprit, and not making the sound in park or neutral falls in line with the scenario.
Posted 23 May 2010 - 05:24 PM
Rsterns, on 23 May 2010 - 04:11 AM, said:
Yeah, unfortunately that's becoming my conclusion also. So, what to do? Is this an easy fix without having to yank out the transmission? Do I just run it until the transmission goes? Can the pump run for years at this point?
Posted 23 May 2010 - 07:02 PM
BlackBrick, on 23 May 2010 - 05:24 PM, said:
The only answer I can provide to your question is 'Time will Tell'. If you can tolerate the grown, then run it till it fails. Just make sure you have a good road towing service account, because when it fails your not going anywhere. If I'm not mistaken, the transmission will need to be removed to have the pump replaced, at that point I'd get a rebuilt transmission which either way equals a significant reinvestment in your car.
Posted 23 May 2010 - 07:50 PM
The mileage is low (116,000), and I've maintained this wagon for 7 years now. I won't give up this early, so a transmission swap may be in my future one day. For all I know, it may not even be the transmission.
I have AAA, so thanks for the advice.
Any others with similar sounds, I welcome your experiences.
Posted 18 June 2010 - 07:34 PM
My conclusion is that now the right axle is going? (I had the left axle replaced 2 months ago).
Hopefully time has told, and it's just both axles causing all the fuss.
There is 115,000 miles/13 years of wear, which I assume is a good life for an axle? (CV boots never been changed either)
Posted 22 June 2010 - 02:54 AM
Anyone out there!? Looks like I'm chasing two ghosts. The new axle has eliminated the loud noise and vibration. The light groan is still there, BUT upon closer examination, the OEM upper engine mount (behind dashboard) is torn. (And it's only 2 years old!) Maybe THAT is what has been causing the mild groan? Someone here had mentioned engine movement could cause this noise. Fingers crossed.
Posted 24 January 2012 - 03:43 AM
Posted 24 January 2012 - 04:41 AM
1996 854T x2
#14
Posted 24 January 2012 - 03:22 PM
And the wagon is my wife's car...she hates manual shift.
#15
Posted 24 January 2012 - 07:32 PM
1996 854T x2
#16
Posted 24 January 2012 - 07:52 PM
