Glovebox Handle
1 reply to this topic
#1 xtonyx
xtonyx
  • 220 posts
Posted 10 December 2004 - 05:03 PM
my glovebox handle broke or something.. it's limp.. now it wont open..
gag.
how do i open the glovebox without it.. at least to get my stuff out?
#2 Geevs
Geevs
  • 1,808 posts
Posted 10 December 2004 - 05:14 PM
Use the search - a solution has been discussed in detail here before. Essentially uses a hack saw blade slipped in the opening between the dash and glove box door. Then hack saw the U-shaped metal clasp. Once the door is opened you need to replace the broken latch inside the door as well as the U-shaped clasp. Both parts are cheaper to replace than the tearing apart the entire glove box door.
