Lpt Internals
Posted 23 May 2010 - 09:38 PM
I realize that bending rods, pistons can happen regardless, but lets assume that the boost doesn't onset too early and talk about the internal strength.
Why are LPT internals weaker than HPT internals? the only difference(according to vadis) is that the LPT bore is 2 mm more than the HPT. Comparison pictures, or more information than "my brother's cousin told me" would be nice.
19T, 0.5 bar actuator, 3" turbo back exhaust, InMotion tune, SRT4 fmic with 2.5" hot-side piping 3" cold-side, ME7 NA intake manifold, big green injectors, ebay pull-type BOV, japanifold exhaust, EBC, weitec lowering springs, no cat, single dual outlet muffler, e-code headlights, dual transmission coolers, polyurethane mounts, front strut bar, XC front bumper, Innovate wideband
Posted 23 May 2010 - 09:58 PM
Rods are the same as the HPT and pistons are probably just as strong as the stock HPT pistons.
Posted 24 May 2010 - 04:07 AM
so the conditions for bending rods would be close to the same as a HPT at a higher psi?
so at the same psi a LPT should run a bit richer than a HPT to decrease the risk of bending a rod/piston? I realize the risk is still present I just want to decrease the probability
Posted 24 May 2010 - 04:47 AM
Posted 24 May 2010 - 04:07 PM
86 Kawasaki Gpz900R Ninja
Posted 25 May 2010 - 02:17 AM
better tune.MOAR OCTANE!
I find it lol worthy that people are afraid to do hard throttle at low RPM. The great thing about having a turbo is having torque down low. What's the point if you can't use it.
Nadine | ME7 S70 T5 601 - sold
Posted 25 May 2010 - 02:33 AM
I run 19 lbs from a K24 on my LPT...
with a tune obviously and stock internals?
Posted 26 May 2010 - 04:36 AM
That thing must be a torque monster
Posted 26 May 2010 - 04:50 AM
better tune.
what do you mean? if the tune is better you can have lower rpm boost? i actually am one of those people, i ease into throttle before fully stepping on it for that reason haha. i have an ipd tune, but for some reason dont trust that it is one. bought it off here used and it hold 14/15psi but eh.
- Greg - '96 Red/Tan 855 R - M - 104k miles - '98 Blue/Charcoal V70 T5 - M - 170k miles -
Posted 27 May 2010 - 01:56 AM
Yeah, it bothers me that IPD tuned ECU can't be identified I had the same issue with mine until I could verify its origin.lol John your "INterests" are funny.
At 15 psi, my AFR's are consistently in the 11's or even 10's. RICA tune and 15 psi max...Stock internals, crappy tune. haha With water injection. Afrs= mid 13's .. haha
Posted 27 May 2010 - 02:08 AM
ipd sparkplug wires, HD TCV, CBV, sways and springs, K&N filter
1999 Jeep Grand Cherokee Laredo, unstopable
#14
Posted 27 May 2010 - 02:14 AM
If I can run 19 LBS at mid 13's... well you can infer the rest.
#15
Posted 27 May 2010 - 03:31 AM
im at 12psi with a t5 ecu, im hoping to go to/above 15psi when i get my new turbo, and this threads making me nervous and sad...
15 psi with a tune, i wouldn't with a mbc, im sure you could but i have mine set at 12, 13 psi right now.
#16
01 Volvo S60 LPT Powered by ARD
3" DP & back | ipd sways and links | Bilstein & Eibach sport | R - BBK | B&M Cooler | 19T | ipd CBV | Quaife | M56lk | greens | FMIC | Snabb | ACD TCV | ARD crank pulley
Looking for S60 Radiator (broken okay) to make aluminum replacement!!
#17
Posted 27 May 2010 - 04:10 AM
#18
Posted 27 May 2010 - 06:25 AM
yeah but idk im at 12 now at its not a problem at all (also 12 out of a 13g so its lame haha) but who knows f good cheap tunes for us glt guys? I wanna run over 15psi when i get my new turbo and exhaust and ishh
yea at 12 psi on a 13g probably not doing much lol, wait til you get a 16t a lot more fun, even with just a mbc, til i can afford a tune lol.
#19
Posted 27 May 2010 - 03:01 PM
agreed, I just installed my 16t the other day with a mbc( probably around 10-12psi) havent installed a gauge yet but I dont hit fuel cut off so Im good. But what a difference over the 13g.
'98 s70 T5 SE 260km Silver Auto
$3000
#20
Posted 27 May 2010 - 03:07 PM
Edited by Big Will, 27 May 2010 - 03:07 PM.
Me: "Yea."
98 V70 AWD Manual: Wothrline ECU, angled 15G turbo, White injectors, EST Intake, R Manifold, TME Downpipe, TME Exhaust, IPD Swaybars + HD endlinks, Volvo Strut Brace, Öhlins Roadholding Suspension + Springs, 302mm Front Rotors and Vented R Rears, SS Brake lines, E-spec C70 Jewels.
2000 V70 XC SE Manual: SOLD
