I swapped the 1996 injectors , turbo boost controller and turbo to the 98.
I used the 1996 engine wire harness. The differences between them were few. the 98 wiring had a few less ground wires, a different type of knock sensor connection. I fixed that by swapping to the 96 knock sensors
I used the 98 computer and got a check engine lite. I then tried the 96 computer and no check engine lite. Yeaa!!!!
I had a lot of valve noise and I used some Marvel Mystery oil The next day it quieted down.
. The 98 trans worked fine. I will change/flush the trans after a couple of weeks to make sure all is well with it. Have tested it for 3 days now and all is well.
My mileage increased by a third. better power as well. 5 cylinders work better the 4
After that I think I will will do a ECU chip.
Edited by rlnelson, 10 December 2004 - 11:07 PM.
