18G Wrx @ 20Psi....Vaaaawyyyy Intewesting
Posted 28 May 2010 - 12:01 PM
Posted 28 May 2010 - 12:03 PM
long live vanessa 2.0!
Posted 28 May 2010 - 12:25 PM
Another win for Volvo!
Posted 28 May 2010 - 02:21 PM
His car can takes turns, ours can't. Another lose for volvo!
96 855T Now with 232WHP and 292WTQ
White, M56H, Black TDR 1.2's, Kilen Springs, KYB shocks, Bilstein HD struts, Precision FMIC
3" DP to 2.5" EST cat back
And yes I like mopeds, can't argue with 240 MPG
Posted 28 May 2010 - 02:27 PM
Tightmopedman9, on 28 May 2010 - 02:21 PM, said:
stock wrx's handle like shit on paved roads...
and im fairly certain ben payed like $100 for his car
Posted 28 May 2010 - 04:36 PM
B Mac, on 28 May 2010 - 12:01 PM, said:
Get the Stage 1 Universal Kit, over 3 years and no issues with any parts running almost 100% meth
Edited by TorqueSteer, 28 May 2010 - 04:36 PM.
Posted 29 May 2010 - 05:18 PM
Maybe $5k total lol...including the initial price
plus 1 andddd plus 1
TorqueSteer, on 28 May 2010 - 04:36 PM, said:
I'm actually installing the kit today. I just need a few fittings for the nozzles and stuff and some pushlock fittings....which I can get at any paintball shop. Res. and pump are in the trunk, 3gph nozzle is about 11 inches from the throttle body. I'm using it mostly as octane but it will still cool the boost considerably. Anything wrong with that setup that you might change Ben? I know the nozzle should be further away from the throttle body but it needs to be after my recirc valve so I'm not shooting meth all over the o-rings lol.
Edited by B Mac, 29 May 2010 - 05:28 PM.
Posted 29 May 2010 - 05:36 PM
Edited by B Mac, 29 May 2010 - 05:46 PM.
Posted 29 May 2010 - 05:55 PM
B Mac, on 29 May 2010 - 05:36 PM, said:
I'm about to order two of those kits
Edited by sconeman, 29 May 2010 - 05:55 PM.
850 Project
SHORT SHIFT KITS---------- TURBO INTAKES---------- SHIFTER CABLE BUSHINGS
Posted 29 May 2010 - 06:22 PM
Posted 29 May 2010 - 09:19 PM
550, on 29 May 2010 - 06:22 PM, said:
without doubt it does fine.... but its nothing lightyears ahead of our cars....
subys are HUGE up here... i have driven/riddin many modded/stock sti's/wrx's and they push into corners worse then our cars...
Posted 29 May 2010 - 10:40 PM
#14
Posted 30 May 2010 - 03:40 PM
How far do they recommend that the nozzle should be from the tb? Mine is about 10-11 inches away, it seems just fine. You might have to try out a few different nozzles, im running a 5gph, but with the larger td05 super 16g turbo.
#16
Posted 24 June 2010 - 12:03 PM
TorqueSteer, on 30 May 2010 - 03:40 PM, said:
Sorry for the late response.....I'm hearing mixed reviews on the distance..."no less than 24 inches" was one of them. From my understanding, the closer to the tb you are, the higher the octane, the further away you are, the better the cooling. My 3gph nozzle feels pretty good but I'm wondering if I should step it up to the 5gph?? I'm making really good power from 4k-6800rpm....maybe the extra octane will help a little bit. Pump turns on at 13-14psi too....verified by sticking the hose out of the hood and driving down the road brake boosting
#17
Posted 26 June 2010 - 05:38 PM
B Mac, on 24 June 2010 - 12:03 PM, said:
The 5gph nozzle is worth a shot. No clue about the cooling vs. octane trade-off, where did you find this information?
A better way to measure the psi at which the switch is set to is to just wire in a LED into the dash, connect the ground to any ground and tap the power from the pump power; if the LED lights up, then you know that power is being sent to the pump, and assuming that the pump is working, the light will tell you exactly when the pump is on.
#18
Posted 30 June 2010 - 12:26 PM
Yes yes yes I know about the LED. I got lazy and impatient when installing it though. I'm going to put in a low fluid level sensor as well as the power LED.
#19
Posted 01 July 2010 - 01:52 AM
B Mac, on 30 June 2010 - 12:26 PM, said:
Damn straight you do . . .
FIRST TO PUT 20G ON AN 850R
#20
Posted 01 July 2010 - 06:28 AM
1998-S70 Glt crashed by meth dealer.
2001-XC70 Daily and Parts.
2004-S60R 314 Awhp Mustang Dyno.
