My 850 Hates Me :(
24 replies to this topic
#1 Kevin.
    I'm 22 and I love anal
  • 7,285 posts
Posted 02 June 2010 - 04:15 PM
Yesterday I went over to iPD to pick up a K&N Filter, iPD spark plug wires, Bocsh distributor cap and rotor, and Bosch plat plugs. Lucky showed me around and took me for a spin in the Flash Green Stage III V70R. E-brake FTW :tup:
Anyways, as I was heading back up 205 towards Portland I put it in 3rd so I could pass a retard going 45 on the highway. Then I heard a "thunk-crunch" noise from under my hood, and my car lost all power. My oil light came on and I instantly turned my car off and pulled off the highway. I popped the hood and white smoke was coming out of my air intake hose and I opened up my air hob and there was a ton of white smoke coming out. My dipstick tube was smoking as well. Oil levels are good. Serp belt is present and good. I didn't get a chance to look at the timing belt before I had it towed and I have not been around the car for the last 12 hours or so.
I'm going to call up Lucky and see if he would be interested in helping be out since he lives no more than 10 mins from me. My buddy Eli is heading over to help me out at some point after he gets off work today from the local Volvo dealer (gotta love having Volvo techs as your friends)
Obviously, if I snapped my timing belt I am going to need a new head. I am also considering doing an turbo engine swap but I want to know what I should realistically expect in parts for the instal.
If I cannot afford to fix the 850, its getting parted. Transmission has already been spoken for.
#2 Falcone
Falcone
    Pvt. Douche Nozzle
  • 1,328 posts
Posted 02 June 2010 - 04:21 PM
white smoke from the airbox sounds bad. I've never snapped a belt, but when a buddy snapped his 960's, the engine just dies, no smoke or oil light. I popped his cover (wondered why it wouldn't start, dumbass cost himself a new head) and it was wrapped around both cams at least twice.
We went and pulled a jy head, and took the jy head and the one with the bent valves and cracked slides to a machine shop. The valves were swapped, same with the guides (heat and cool to get them out) and put back together. Total around 400 bux. That being said, you can get a turbo motor for around that, which personally, is what i would do. If your belt snapped, everything inside it is fawked, and your pistons might be super scored. Pop the cover and report back
K-Town Brick Militia______________94 854 The BBQ_________________97 Pewter T5 teh dd
I was us up all night with a rusty hammer trying to build a fence around these magic beans my dreams have gathered
#3 mojojo
mojojo
  • 407 posts
Posted 02 June 2010 - 06:57 PM
I always caution to replacing only valves (top end) when collision occurs. If it were my car, anything that hit would be replaced, including pistons. I have removed cast pistons that hit valves and under close inspection noted several spider web-like cracks along the bottoms of the pistons. At that point I only imagine what would happen when a piston with these 'injuries' is shattered due to compression.
Like the others said, buy a new engine, and put a new belt on it.
As well, I've repaired broken timing belts (with new engines), and never noticed any sort of smoke.
Usually, just the immediate loss of power and oil light.
#4 FCP Groton
FCP Groton
  • 1,838 posts
Posted 03 June 2010 - 01:58 AM
+1
I have ever heard of the smoke that you are having either, which could be a good thing. You may have lucked out and the engine is still good. Maybe it is just a blown head gasket or something, that would not be so bad.
Andrew Owendoff
#5 Kevin.
  • 7,285 posts
Posted 03 June 2010 - 04:31 AM
Timing belt is good.
Looks like it may be one of the following:
-headgasket
-bad lifter
-bad valve
gotta love going back to square one
#6 mojojo
mojojo
  • 407 posts
Posted 03 June 2010 - 06:34 PM
I would think bruned valve due to smoke in the manifold.
Compression and leak down time.
#7 Kevin.
  • 7,285 posts
Posted 03 June 2010 - 07:09 PM
That's being done tonight. I will post my findings
#8 Kevin.
  • 7,285 posts
Posted 04 June 2010 - 12:20 AM
I lost piston #1 the 850 is dead.
#9 FCP Groton
FCP Groton
  • 1,838 posts
Posted 04 June 2010 - 12:49 AM
Did they tell you why the piston went? Car probably ran lean on that cylinder.
Andrew Owendoff
#10 Kevin.
  • 7,285 posts
Posted 04 June 2010 - 12:52 AM
All I know is that piston #1 and the rod ain't there anymore.
On a side note, what is your return policy? I have a bunch of parts that I am going to need to return to you guys
#11 s_moneh
s_moneh
  • 1,583 posts
Posted 04 June 2010 - 01:09 AM
uhoh :( i'm getting P0171 every like 600km i just delete and move on, shietttt thats bad isnt it? :(
sorry for stealing the thread!
#12 aggarcia
aggarcia
  • 275 posts
Posted 04 June 2010 - 01:55 AM
The #1 piston and rod maybe damaged, but they are still in the motor ( maybe piston in pieces ). Have the head and oil pan been pulled to see what damage is there? In most cases it is repairable.
97 850R - ARD Blue tune, S60R Ceramic Manifold, 18T, Snabb Fresh air pipe, OBX Downpipe, 3' SS mid pipe w/Random Technology Cat, TME Exhaust, AC Delco BCS, FCP Silicon Hoses,
Suspension - IPD 25 mm track sway bars, H&R Springs, Koni Sports struts/shocks, Maxxium Grip 18x8 Wheels, 302 brakes with Porterfield R4S pads
#13 Kevin.
  • 7,285 posts
Posted 04 June 2010 - 03:25 AM
I lost a intake valve and it shattered my piston. I have damage to both the upper and lower parts of my engine as well as my oil pan
Edited by KeVTRoN, 05 June 2010 - 06:55 AM.
#14 HPTDoh
HPTDoh
  • Validating
  • 5,969 posts
Posted 05 June 2010 - 06:32 AM
I think josh from tki is selling a motor :tup:
#15 Kevin.
  • 7,285 posts
Posted 05 June 2010 - 06:42 AM
I dont think that my current $500 budget is gonna cover that :(
#16 swc75
swc75
  • 534 posts
Posted 05 June 2010 - 06:54 AM
Sorry for your loss.
http://i650.photobuc...75/DSCN4699.jpg
1998 V70 T5 sold
2001 V70 T5M
#17 aggarcia
aggarcia
  • 275 posts
Posted 06 June 2010 - 12:45 PM
I have had the same occur to me with other brands. The damage can be great if run too long. I have seen complete used motors sell for less than $500. It depends if you want to keep the car or getting something different. Good luck.
#18 BEJinFBK
BEJinFBK
  • 1,930 posts
Posted 06 June 2010 - 06:43 PM
There are a ton of Volvos in the N/W. Keep your eyes open and you may get lucky!
Some folks just want a junker that's been in a wreck hauled away.
Bad body, tranny, etc could easily still have a great engine...
#19 s_moneh
s_moneh
  • 1,583 posts
Posted 07 June 2010 - 02:31 AM
nope the head nore oil pan have been pulled, i dont have time for that aha all i know is i burn a TON of oil on start up, no matter what aha on initial start up its nothing but after like turning it off then on it burns like made even with leaving the car run for like a minute after driving for the turbo to drain
and by todays performance at the track i doubt i have a piston or a rod damaged, i was runnign 14's with 15psi of boost and no codes the p0171 code only shows up after a long drive with the car
#20 Turbosleeper
Turbosleeper
  • 195 posts
Posted 07 June 2010 - 08:48 PM
I think he was referring to the OP
For Sale
'98 s70 T5 SE 260km Silver Auto
$3000
