Posted 20 July 2011 - 12:29 PM
crazykn, on 20 July 2011 - 07:31 AM, said:
I probably should update what I did to fix my car. Turns out my RPM drop was my transmission. In the end I ended up with a brand new transmission from Volvo directly ($2600) and well that fixed the problem for good. Upon inspection of the old unit, turns out i was flooded with metal shavings. Apparently the magnets on the bottom of the pan were full and couldn't really hold more, so without a transmission filter in this tranny, these particles probably circulated and clogged and jammed the valve bodies, reducing transmission fluid pressure...
I'm just happy my S70 T5 now drives like new again.
I also had my transmission replaced about 30k miles ago, so did the timing belt and belt tensioner. RPM drop still exists, so my RPM drop does not related to timing belt or transmission .....
Ching-Ho Cheng
1995 855 NA: Bilstien Touring Strut & Shocks, Volvo Protective Grill, K&N Filter, E-Code Lens, ClearCorner Light, Alpine CD-Changer, AutoDim RearView Mirror, 6000K HID, Tranny Cooler
2005 530i: PPP, CWP, Nav, Xeon, Rear SunShade, Steptronics, Blue Light Door Sills, Wide Angle Driver Side Mirror, M5 iDrive Knob, White LED License Plate Light
