Ticking Noise
Posted 15 June 2010 - 07:53 PM
Posted 15 June 2010 - 08:44 PM
Nadine | ME7 S70 T5 601 - sold
Posted 15 June 2010 - 09:55 PM
what weight oil did you put in?
10w30
Posted 15 June 2010 - 10:08 PM
and the level is okay?10w30
Posted 15 June 2010 - 11:20 PM
this.
If the level is okay, get ready to replace your oil pan o-rings
Posted 16 June 2010 - 01:58 AM
Posted 16 June 2010 - 02:05 AM
Posted 16 June 2010 - 02:12 AM
LUCAS OIL STABILIZER works miracles.
i may add some of this, i've used lucas products in my prev. cars and they definitely work good.
Posted 16 June 2010 - 02:22 AM
Posted 16 June 2010 - 03:19 AM
mine seems to tick more often. Besides the lifters making noise.
98' S70GLT 237K miles ... still on original Turbo..yes it's leaking like a sieve.
Posted 16 June 2010 - 04:18 AM
i also saw on here in another thread atf works good to run in the oil for a few miles to clean it out, since it has a lot of detergents in it, should i maybe try this to quiet things down or just add the lucas?
Well if you are trying to clean it out run some SEAFOAM thru the engine for a few miles before changing the oil.Worked great in my engine.Oil now looks clear and clean.Car has around 158k so it had quite a bit of sludge built up.I did flush the engine 2 or 3 times to get it as clean as it now is.
I am running 'Q' 10w40 'TORQUE' with ZDDP added for extra protection as it is great for turbo cars and cars with high milage.
Posted 16 June 2010 - 05:10 AM
Could it possibly be your EVAP purge valve cycling?
+1 - I thought the same things. The EVAP Purge valves can make some really weird sounds that if you don't pay attention can be mistaken for lifter. I replace the valve and the "ticking sound" went away.
#14
Posted 16 June 2010 - 05:38 AM
Jake
1998 Volvo S70 T5M 190k
#15
Posted 17 June 2010 - 04:10 AM
or i could check or replace the evap purge valve?
#16
Posted 17 June 2010 - 06:36 AM
#17
Posted 17 June 2010 - 06:43 AM
no difference between 5w-30 and 10w-30 when upto operating temperature.
#18
Posted 17 June 2010 - 04:13 PM
#19
Posted 18 June 2010 - 03:43 AM
#20
Posted 18 June 2010 - 06:03 AM
you should give a high mileage 10w40 a try, it really quieted my motor down, i like the castrol....seal conditioners in the oil lessened my loss from my rms as well
