New Seats From A V70R For The T5
8 replies to this topic
#1 Blue850T5
Blue850T5
  • 353 posts
Posted 17 July 2010 - 06:01 AM
I picked up a set of 1998 V70R front seats from the local Volvo yard for my 97 850. I installed the drivers seat and it plugged right in and the power options and seat heater work great. I didn't have to do any mods to it or modify the harness. I popped the pass seat in and no such luck. Even thought the harness connectors hooked up fine, the power options don't work. The seat heater works great. I have power to the seat, all four seat motors checked out with a power probe. The switch was double checked in another car and it's working.
Anyone else have any ideas or run into this issue. There are only three wires at the chassis harness and three wires on the seat harness (differing colors). My guess is that there is a relay somewhere not switching/recognizing the seat in the 850, thus the seat power option won't work.
1997 854T5, Aqua Blue, M56H, IPD Stage III Manual ECU, 18t, 3" "CJ" Downpipe, R Manifold, Green Injectors, OEM RIP, 940TB, IPD Intake, Custom Exhaust, Sampco Hoses, "CJ" Strut Brace, IPD Sways, IPD Sport Springs, Yellow Bilsteins-Koni, IPD Endlinks, 302mm Conversion, IPD Brake Lines, Homelink, IPD Boost Gauge, Short Shifter w/Brass Mounts, HID's, R Interior Accents, R Bumper & Spoiler, ....many projects pending!
#2 (n)A-GAME
(n)A-GAME
  • 7,288 posts
  • Crew:ECC
Posted 17 July 2010 - 12:03 PM
Did you originally have a passenger side power seat? Or was it a manual seat originally?
2011 Volvo S60 T6 AWD
#3 mdlimy
mdlimy
  • 2,933 posts
  • Interests:Beer, volvos, boost <3
Posted 17 July 2010 - 04:41 PM
most likely you need to add 12v to one of the pins on the seat connector plug, i dont remember which one but you can just run a wire out one pin and into the one that needs power.
View PostJVC, on 13 March 2012 - 05:56 AM, said:
You sir... just keep on winning...
#4 --Aaron--
--Aaron--
    douche bag
  • PipPipPipPipPipPip
  • 12,546 posts
  • Gender:Female
Posted 17 July 2010 - 05:08 PM
If you previously had a manual seat you may need to add a breaker under your fuse box cover. It is a polished looking one, 20 amps I believe.
#5 Blue850T5
Blue850T5
  • 353 posts
Posted 17 July 2010 - 05:35 PM
Previous seat was powered. I will try the pin by pin approach. Thanks for all the ideas.
#6 Silver854m56
Silver854m56
  • 36 posts
  • Interests:Rock Climbing, Running, XC Skiing.
Posted 09 February 2012 - 09:31 PM
Currently swapping 98 V70R seats into my 94 854. it had all manual seats... but they were heated!
if anyone has experience/insight/knowledge on how to use the seat heater's pos/neg for the elec seat I would love that... and what's this about breakers?
1994 Silver 854 5spd W/ Bilstein Touring setup, IPD Springs. 224,xxx mi.
1995 Black 855 5spd--RIP 265, 1996 Black 854 Turbo--RIP
1998 Silver V70R, 1995 Olive Green 854 GLT (Both Sold) New Hampshire.
#7 rmorse
rmorse
    GLT's aren't turbo,YO
  • 744 posts
  • Interests:SPEED! Snowboards, dirt bikes, volvos, crotch rockets....
Posted 10 February 2012 - 01:26 AM
Pop the hood, look at the fuse box. Remove those torx screws, remove the cover, and look at the silver shiny fuses. You have to add one.
#8 Black Betty
Black Betty
  • 6,987 posts
Posted 10 February 2012 - 02:13 AM
There's a wire you need to jump
I can check under my seat tomorrow if you haven't got it.
#9 burnout8488
burnout8488
  • 170 posts
  • Interests:Daily Volvo Repairs
Posted 12 February 2012 - 07:53 PM
This is what you need on an x70, not sure if 850 differs.
'99 S70 AWD except not
2.4+15g/Rmani/Snabb Intake/ARD Green
