and the 2nd silly question, can i replace them without fully jacking the car up (wheels off ground)? The car is currently in the only shady spot around i can work in
thoughts?
Posted 17 July 2010 - 12:54 PM
Posted 20 July 2010 - 03:07 PM
Maybe it's a silly question, but I'm replacing both hydraulic mounts today (hopefully). Does it matter which i should do first? Will it make it easier to do front then rear? front seems to be more worn, about 3/8" between trans and bump stop. Not feeling frame hits, but they're the only old mounts left and the vibration is noticable.
and the 2nd silly question, can i replace them without fully jacking the car up (wheels off ground)? The car is currently in the only shady spot around i can work in, and it's a bit of a slope. I'd love to be able to work under the tree, but I wonder if the car will stay "down" as I jack the engine up.
thoughts?
Posted 20 July 2010 - 03:59 PM
Posted 20 July 2010 - 05:24 PM
Why are you bothering to replace the hydraulic mounts? They are very rare to fail!
1998 Volvo S70-T5 SE Auto
Black on Tan
GlowShift boost Gauge, Hallman Pro MBC, K&N Air Filter, OBX Strut Brace
Posted 20 July 2010 - 05:29 PM
Posted 20 July 2010 - 05:34 PM
I've never seen a bad one and I would never recommend wasting the time on them. Spend your time and money on parts that do fail.
Black on Tan
Posted 20 July 2010 - 06:03 PM
05 S60R Black Sapphire/Nordkap 6MT
Posted 20 July 2010 - 06:06 PM
bullshit. compare the height of a new one vs a used one. They are rarely replaced, they fail often.
Posted 20 July 2010 - 06:08 PM
Yeah, when I pulled out my old rear mount it was about an inch shorter than the new one I put in. And I used to have a problem with my OBX rattling against the center brace underneath my car, hasn't done that since I replaced the mount, that's how big of a difference it made. So to say that they don't fail over time is false.
Posted 20 July 2010 - 07:04 PM
I'm dumb. compare the height of a new one vs a used one. They are rarely replaced, they fail often.
Black on Tan
Posted 20 July 2010 - 07:22 PM
Posted 20 July 2010 - 08:17 PM
On the hundreds of these cars I've owned and worked on I have never seem or had an issue with one. There will always be a height difference from old to new as the new ones have never had pressure on it.
Posted 20 July 2010 - 08:56 PM
Posted 20 July 2010 - 09:05 PM
Posted 21 July 2010 - 01:56 PM
Posted 21 July 2010 - 03:52 PM
Posted 21 July 2010 - 05:12 PM
Mine were toast when I changed them at ~ 200,000miles. I could tell a big difference in the height of the motor/tranny compared to the sub frame. Pre change the tranny was actually resting on the rubber bumpstop lightly. Afterword there was nearly an inch clearance.
I changed them again when I did a motor swap after ~85k...they were still ok but I did not want to do that again any time soon and it was MUCH easier with the motor already out. Plus if those are worn, the other mounts are subject to increased wear.
Posted 21 July 2010 - 05:31 PM
I've never had the hydraulic mount cause a single issue. This is not a matter of my skill level and it's not cool questioning my integrity either. Also I still have not seen a real issue with the mount on here either. Other then the OBX clearence issue which is non-stock.If you haven't seen a bad hydraulic mount on an 850/X70 and you have worked on hundreds, I don't think I'd trust you to fill my washer fluid.
Posted 21 July 2010 - 05:46 PM
It's under the tranny, popped into the subframe on the left side.Where is this bump stop? I don't think I've ever noticed it and since I'll be under the car later I figured I'll give it a look.
Posted 21 July 2010 - 07:28 PM
