beasters
How Your Car Sits
Does your old man help you with the car at all?
You bet! Not as often as before unless I really need a helping hand or fatherly brains for some problem solving. :)
Quarantine boredom.
  • Like 2
  • Upvote 3
8 hours ago, quiksilver said:
Quarantine boredom.
Wow...
Installed the Maxpeedingrods coilovers the other day. While I haven't driven it much yet as I'm waiting for an alignment, first impression is that it rides smoother than IPDs/Konis.  Couldn't go wrong with these as the whole set is cheaper than just replacing front struts on the normal setup..
The fronts are as low as they go unless I remove the collar ring (which I may do later). Height is comparable to IPD springs as-is.
The rears took a little effort to install, had to drill the lower shock bushing holes a little as they wouldn't fit over the studs. Also, at full droop (shock fully extended), the rear springs are slightly past full extension and loose. I don't think they are going to fall out or anything, but I am a little weary of going lower at this point. I may re-work the upper shock mounting a little higher so that it can't droop as much, but we'll see how this rides for a while first. I suspect everything will settle in and lower a little more as I drive it.
This car has been in storage for about 2 years and I'm happy to be bringing it back to roadworthy over the rest of this summer.
Copy
Edited by tuner4life
Photobucket is a pile of hot steaming garbage..
  • Upvote 3
what a timeless design ;) looks good
  • Like 1
They will never go old man, ad some bi-xenon lights and its look like born yesterday!!!
Popular to contrary belief, a stock XC70 on all-season tires can be loads of fun to autox.
105911695_10157341263281966_199730015261
105977991_10157341263181966_412495385757
  • Like 1
  • Upvote 2
