Burning Oil
44 replies to this topic
#1 mrbrightside2009
mrbrightside2009
    I eat rice for breakfast
  • 1,144 posts
Posted 06 August 2010 - 04:53 AM
anything i can add to my oil to minimize this? after 2000 miles of driving my car is somewhat low on oil already, i do drive somewhat hard. i heard the engine restore in the gray can works good? any opinions?
and if that does help, there are only 4,6,8 cylinder cans, which one would i use?
1998 s70 glt t5 converted - 16t, t5 ecu, white injectors, nxs mbc @ 11psi, cone filter, magnaflow muffler, 3in. DP, high flow cat, full 3in. exhaust, hd wg, na tb, ipd turbo hoses, 6000k hids, black mesh grille, columba wheels, glowshift boost gauge, white interior leds, stage 0 complete
#2 bergmjs
bergmjs
  • 2,060 posts
Posted 06 August 2010 - 05:04 AM
You sure you're burning it and not just losing out your RMS or another seal somewhere?
'95 854 T5M 195k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue - DEAD - To be parted out
'04 S60R - 125k
#3 Turbo Box
Turbo Box
  • 31 posts
Posted 06 August 2010 - 05:09 AM
Could be your valve guide seals. Not much you can do, but replace them. No fun on a bucket spring style head and snake oil will not help.
#4 AverageVolvo
AverageVolvo
  • 1,636 posts
Posted 06 August 2010 - 07:24 AM
From what I understand, It's completely normal to burn apprx .5 to 1qt oil every 3 k. Both my 850's do as well as several of my friends cars.
96 850 (412) wagon W/2 racing seats no rear seats, ..Converted to M56h with Quaife. R clutch,Kw v2 coilovers, qbm end links,Ipd sways,strut and shock braces/ Front/rear lower Ultra racing chassis braces. Team Dynamic 17in rims 17lbs .Poly mounts on trans, engine and firewall.Porsche Bbk, Ss lines, Super Blue Ate.5mm Spacers,Rolled Fenders,R Manifold, T04E 50 trim @18psi. Divorced WG and BOV ,3in Downpipe, gutted 3in cat,2.5 tme/Ipd catback Gizzmo Ebc, 1 gallon Aem progressive Meth Injection kit. Walbro 255. Na mani W /960 plate and Na Silicone Tb hose. Boost/egr/wideband gauges dash mounted. Double Din touchscreen Nav. 12in Fosgate p3 and 2 Alpine amps/ + Cf spoiler+ V70 stuff.
#5 MyCarIsRed
MyCarIsRed
  • 1,526 posts
Posted 06 August 2010 - 10:32 AM
Volvo actually states this somewhere, i just can't find it right now. 1qt for 3k is "normal" for the turbos.
#6 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,896 posts
Posted 06 August 2010 - 11:45 AM
How much oil has it used?
#7 MyCarIsRed
MyCarIsRed
  • 1,526 posts
Posted 06 August 2010 - 02:50 PM
it's a 1.5qt difference between the lower and upper lines, fyi
#8 Keaton85
Keaton85
  • 7,492 posts
Posted 06 August 2010 - 03:40 PM
Sounds normal to me. It's kinda nice though, since if you run synthetic you are adding a Qt every 3K. This brings your additive package back up thus letting you do extended OCIs!!
All my volvos go through that to some extent...
#9 mrbrightside2009
mrbrightside2009
  • 1,144 posts
Posted 06 August 2010 - 07:23 PM
i'm not sure how much is in there now, i'm hearing ticking telling me its low, so how low can it be when the ticking starts, a quart, 2 quarts? just did an oil change 2000 miles ago and switched back to high mileage, was using synthetic which was worse.
and i did not know that is normal for turbos, thats really good info.
#10 gogot5!
gogot5!
  • 28 posts
Posted 06 August 2010 - 07:29 PM
Where exactly does it go, and why does a turbo model use it and not the non-turbos? I'm guessing it gets blown past the seals in the turbo under high boost?
#11 Matt854T5
Matt854T5
  • 59 posts
Posted 06 August 2010 - 08:01 PM
If it burns it fast enough you wont ever have to change it you will have fresh oil all the time ;)
97 854 T-5 MSD coil,IPD wires,OBX TB,optima bat,drilled and slotted rotors,pegs,10k HL 3Kfog,LED everything,mesh grill,R front bumper and spoiler,E codes
#12 Keaton85
Keaton85
  • 7,492 posts
Posted 06 August 2010 - 08:07 PM
It should not be worse while using synthetic. Anyway, the ticking could also be your pick-up tube o-rings. Mostly this will show up as loud ticking when you first start the car since all the oil on the top end has drained back.
As for why turbos use more oil? well for one you have more pressure on each cylinder thus increased blow by, a couple more places for oil to leak from, and the PCV system isnt the best in these cars. It's not really just turbos either, the N/As will do it as well, along with most cars of this age.
I would check the number one culprits:
RMS
Valve guides (blue smoke on cold start-up)
PCV system (smoke coming out the dipstick when at temp and while increasing RPMs)
Turbo drain back o-ring
Front cam seals (sometimes)
rear cam seals (mostly under the cam sensor)
Try checking those along with using a 40 weight full syn. (try, it's not a must!)
Still have to change your oil filter or it will go into by-pass. Although you are correct that you can go a lot longer with your OCIs if you are adding a Qt every 3K or so. Just keep that filter changed out.
#13 mrbrightside2009
mrbrightside2009
  • 1,144 posts
Posted 06 August 2010 - 08:20 PM
well just went out and checked my oil, def seems full, i was reading it could be a loose spark plug, i took my cover off, about 2 or 3 of them i could put the wrench on and barely use any force and they were loose, re-tightened them, i'll see what happens.
#14 Keaton85
Keaton85
  • 7,492 posts
Posted 06 August 2010 - 08:43 PM
Loose spark plugs burning oil? I think it would be the opposite, that would just decrease your compression thus decrease crankcase pressure. Loose plugs would make it run like **** but that's about it.
#15 mrbrightside2009
mrbrightside2009
  • 1,144 posts
Posted 07 August 2010 - 12:03 AM
no i meant i read on other forums loose plugs can cause a ticking sound, they werent loose as where i could wiggle them, just werent that tight, i dont know if that is really true or not, my oil might not even be low, doesn't seem like it, but yea i would think that would make it run like crap too, im just throwing guesses out there.
#16 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,896 posts
Posted 07 August 2010 - 12:11 AM
So you made this entire thread without even pulling the dipstick? :rolleyes:
Jesus christ.
#17 Keaton85
Keaton85
  • 7,492 posts
Posted 07 August 2010 - 12:48 AM
</thread>
#18 mrbrightside2009
mrbrightside2009
  • 1,144 posts
Posted 07 August 2010 - 12:52 AM
haha, i don't believe in the dipstick and this happened to me before when the dipstick said it was full when it was 3 quarts low, open thread....
#19 mrbrightside2009
mrbrightside2009
  • 1,144 posts
Posted 07 August 2010 - 01:20 AM
i do get the code p0172 which i believe could be an exhaust leak, which could cause ticking, that would make sense since im getting the code.
#20 850T5IVE
850T5IVE
  • 188 posts
Posted 07 August 2010 - 05:12 PM
Jesus christ.
:lol: :lol: :lol:
