Rear Deck Speakers
Posted 20 August 2010 - 04:05 AM
any advice on what to do there.....
the ohm of the speaker wont matter since i would be powering the speakers with an amp.... so any additional suggestions on which speakers to buy?
Posted 20 August 2010 - 05:17 PM
Are you asking which size other than the size that fits best would fit best?
stick with 8". and yes, resistance of the speaker does matter, equally as much with an external amp as with your stock system.
Why are you replacing them?
Posted 20 August 2010 - 08:28 PM
Posted 21 August 2010 - 02:43 PM
But you can certainly make your own adapter plate. A jigsaw and some polycarbonate would work just fine. Upgrading the speakers is the first thing i do to a new car, but usually the task is stepping UP a size, not down. The majority of the down-sizing is to accommodate component setups, so you can fit a 6.5" round and tweeter in the hole for a 6x9 (etc). The best sound would come from a 6.5" component setup, unless the rear deck is just doing low-end, in that case just get a better 8" driver.
Posted 21 August 2010 - 03:55 PM
the ones in the deck right now 8'' are mostly bass, so in order to keep that little bass i would replace them with something better.... but obviously like you said i would have to modified a little bit, drill and stuff.
Posted 21 August 2010 - 06:18 PM
Posted 21 August 2010 - 07:45 PM
but i dont know DLS reliability nor quality
Posted 21 August 2010 - 08:01 PM
1. Coaxial 8" speaker
2. Midwoofer 8"
3. Subwoofer 8"
2&3 you could always add more speakers to the rear deck, just remember that you need to power them somehow either with the radio/factory amp/aftermarket amp. Your car your choice, just need to design a setup.
Posted 22 August 2010 - 04:09 AM
my setup:
front doors (6.5inch) a pair of c2 650x JL audio (2 way coaxial)
rear doors, (5.5 inch) a pair of Infinity from a dodge ram speakers, dont know model (2way coaxial)
rear deck, planing to buy a pair of JL audio zr800 8' midwoofer http://www.sonicelec...o ZR800-CW.html
and i have a subwoofer 12'' dont' know the brand.... the midwoofer front doors speaker, rear door speakers, and trunk subwoofer all of this will be powered by 2 amp i think
for now i will start the installation with the door installations and maybe later with the midwoofer and subwoofer installtions
any suggestions, doubts or comments ?
Posted 22 August 2010 - 08:50 AM
Durry, on 22 August 2010 - 04:09 AM, said:
my setup:
Do not put much faith in sonics warranty. Seen first hand denying warranty claims on their products. As to your setup, that is not a planned system, but rather an idea of what you would like to do.
1. Dodge factory coaxial, really? Free does not mean it's good(nor bad, but in this case yeah).
2. rear door location is poor, any good speaker in the rear deck will drown out the sound.
3. space and wiring of multiple components, will it fit.
4. budget, what can you spend on which components to get the most out of your dollar? You have considered speakers, but what 2 amps?
Once you start, you will know what direction you want to take it,GL.
Posted 22 August 2010 - 02:41 PM
1. they sound really good (at least to me)
2. well maybe nothing in the rear doors then
3. space for wiring would be a little complex but already have all that figure it out
4i already have everything i said, except the rear deck mid woofers
i just want a decent quality setup
Posted 28 August 2010 - 12:28 PM
It's also a function of tuning. Lots of folks upgrade their stereos, but to get the real benefits you need to EQ it correctly. A 15" sub will produce tons of trunk popping bass, but it will also produce some very smooth sound at lower levels, and with the right frequencies compensated for.
Posted 28 August 2010 - 10:21 PM
looking for something chip like the CLARION EQS746 - $70.00
#14
Posted 30 September 2010 - 11:05 PM
1. Front door Component speakers JL c3 650 (6.5)
2.JL Audio J2 320.4 AMP 4 60 watts x 4 @ 4 ohm
3. i have a pair of jl c2 coaxial speakers 650 (6.5) (maybe going to sell them in order to buy the dls coaxial speakers i stated before.. upgrading from 6.5 to 8 inches in the rear deck....
so far... im planning on buy a better amp.... replacing the rear deck speakers with bigger ones, and for future plans ...ill buy a Preamp ...
#15 Guest_DrPsych_*
Posted 09 August 2011 - 02:30 PM
