79 242 Hard Starting Problems
7 replies to this topic
#1 negrito211
negrito211
  • 48 posts
Posted 20 September 2010 - 05:05 PM
Hello. Sometimes when I go to start my car, it wont fire; then I can hear the the pump or something priming for 2 seconds or so. Or sometimes it starts for a second then dies right away. (erhehehevroom ... dead) Sometimes it starts too fast (erhevroom .. dead)Last but not lease, there's times when i have to keep my foot on the gas pedal for it to start and it puts until everything smooths out while I am pumping the gas pedal.
I've have new ignition coil, spark plugs, wires, distributor and rotor, air filter.
So could the fuel filter be the problem? I took it off and it's hard to blow through. Doesn't have a straw flow. W
What can be the problem?
Soy boricua y me dicen oro negro....!! 98 s70 112k miles
http://i304.photobuc...oto524_0719.jpg
#2 Y.B.
Y.B.
  • 115 posts
Posted 12 October 2010 - 11:23 PM
Same guy different user name. (had forgot my password used brothers account etc etc)
Anyway. I replaced the fuel pump relay and fuel filter and still have hard starting issues. Sometimes the car acts like it wants to start but doesn't. Other times it'll keep cranking and then I can hear the fuel pump AFTER the cranking stops. Is this normal? When it does start, it's kind of rough and then things smooth out. I'm probably gonna drive this car of the cliff.
1996 Volvo R 180800 |
Never ending stage zero: PCV Job Done | stylin motors vac hoses
new Ignition switch | Thermostat and rad hoses replaced | new rad
new front o2 sensor | starter replaced
#3 Mesoam
  • 19,721 posts
Posted 14 October 2010 - 12:33 PM
try unplugging your cold start injector
#4 NEU
NEU
    Old Man Crew Photographer
  • PipPipPipPip
  • 3,622 posts
Posted 14 October 2010 - 12:56 PM
Did you clean the throttle? My 245 use to have a hard time starting if the little air passage was clogged.
Laser Blue 2000 V70R
Speedtuning St2 @18psi/19T w/Forge CBV/IPD drop-in intercooler/R mani/CJ 3"DP/dual 3"Magnaflow/EST intake w/K&N/Samco & Snabb hoses/Delco TCV/Bosch Super Plus/IPD HD COP/UR lite pulley/CJ delrin subframe mounts/TME AWD springs/TME strutbrace/IPD sways w/adjustable endlinks/Koni Sport strut/18" OZ Ultraleggera
#5 Y.B.
Y.B.
  • 115 posts
Posted 14 October 2010 - 10:23 PM
I will try the suggestions you guys gave me. Thanks.
#6 Y.B.
Y.B.
  • 115 posts
Posted 15 October 2010 - 11:31 PM
Suggestions didn't seem to work :( Only thing I can think of is that it has to be the:
:: fuel accumulator ::
What are the odds of this part failing? Has anyone had to replace this on their vehicle before?
#7 VFL83
VFL83
  • 74 posts
Posted 16 December 2010 - 02:23 AM
It could be the fuel pump check valve. That is what keeps the fuel in the lines from going back into the tank and that could be why it is hard to start as the pump get fuel back in the lines.
#8 vivalavolvo
vivalavolvo
  • 182 posts
Posted 21 December 2010 - 01:45 PM
Could be the warm up regulator. Try pumping the gas pedal very quickly while starting it, this causes the the system to richen the mix and can help it get going.
K-Jet is a fun system :)
1978 242DL - 1995 855 T5 ARD Green - 1991 Stanza XE
