Account_Deleted_T5M
Evap Woes
The time for inspection has come and gone, so i decided to fix the small leak today. Car is a 1996 Volvo 850 2.4, so i dropped the canister down, and here is the picture of said canister, there is one set apart from the others that is just open? Where does this route to?
  • Downvote 1
I see in volvo's picture that it supposedly goes to the shut off valve, and then air filter? But have not found said shut off valve, and it seems weird that there is no line going to it.
Cal3thousand    19
Would seem to be the "roll-over" valve (<-semi-educated guess :lol:)
erikv11    219
I don't think so, in a 96 (well, in mine anyway) the rollover valve is back next to the fuel filter so presumably on the line labeled "from fuel tank."
Dave 54    490
the shut off valve is located down under the battery tray, it should have a hard black plastic line going to it.
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
Are the two codes remaining, where is this pressure sensor etc located now, cant find anything online or in haynes.
1996 volvo 850 NA, also can't find air pump location :arob: i thought 96 NA's didn't have Secondary Air pumps
cheapwagon    357
Some NA's got them in 96
Volvo5.0    538
Shut off valve is located behind the LF plastic inner fender lining. You'll need to remove the rivets and take the liner out to access the shut off valve.
Reximus    31
this is actually the cruise control vacuum pump that you're pointing out here
pressure sensor is located on the fuel tank most of the time, the code appeared because you have P0446 vent control circuit malfunction code present. once you have that code fixed, you should be fine. looks like on the canister, the big hose has been disconnected for a short while before you pulled the canister off of the car. the vent control valve should have been connected to it... look around inside the wheel well, you will be able to find something around there that looked like it would fit onto it with... a valve with two hoses attached to it, one of the hose would have a "box" on it which is the air filter for EVAP system. the other end would be fore the canister. cheers! :D
erikv11    219
mine does
air pump on mine is under the battery, way up next to the bottom corner of the radiator. Most easily seen from under the car.
weston97glt    9
i have codes coming up for evap system also with the cansiter making a loud whistling sound from sucking in air from where it looks as tho there should be a hose connected to it. should there be a hose connected to each outlet?
