Autox From This Weekend.
Started by Korruption, Oct 21 2010 01:25 AM
9 replies to this topic
Posted 21 October 2010 - 01:25 AM
1991 244 NA - M47
Posted 21 October 2010 - 01:48 AM
Dude!!!! That was kickass!!! Your car sounded great and loved the tires screaming the whole time!! I want to do it!!!
Lee 1998 S70 T5M; 113K+ miles; IPD Stage III ECU; 18T turbo @18.5psi; Precision FMIC; R manifold; EST 3" DP; balanced crank with LGSpeed rods; 3 angle valve job; SPEC III clutch; ALL of Sconeman's T5M parts; KW2 coilovers; TurboSmart Eboost2 EBC ---13.605 @ 105.39 mph ---
Posted 21 October 2010 - 02:54 AM
Zappo, on 21 October 2010 - 02:43 AM, said:
And hopefully not the last.
You were clearly faster in the first section the second time through in the video. You were also at the limit of the tires.
Hope you had fun.
Hope you had fun.
Definitely not the last time!!
Had an absolute blast. Tires were definitely maxed out. I was running on my roommate's 16's with some summers on them. I didn't run the 19's because I thought they'd rub.
1991 244 NA - M47
Posted 21 October 2010 - 03:06 AM
Yeah, the 19s may have rubbed, but you would have had better lateral traction. Hard to say.
Posted 26 October 2010 - 10:10 PM
Good stuff man! Better suspension/camber and tires could help with all that understeer though.Talk about screaming tires.
Edited by dublin14, 26 October 2010 - 10:11 PM.
Posted 29 October 2010 - 07:42 PM
Nicely done! Sounded like an episode of Dukes of Hazzard, too.
1998 V70T5 - 2010 VW GTI - 1989 VW Cabriolet
2000 V70R - Gone to a new home...
Posted 29 October 2010 - 08:43 PM
hahahaha our cars are not the greatest autox... but nice work! ive only done it in fwd mode... howd the awd do?
00 Olive V70R -- 98 S70 T5M
Posted 30 October 2010 - 01:47 PM
I could very much feel the rear pushing the front around. This only complicated the understeer in heavy turns... but it did well. It feels like it pulls out of corners rather well. I will hopefully get an onboard video soon.
1991 244 NA - M47
