It had been picked apart but still had a good engine with about 120k miles on it. I decided to pull the head first before I pulled the engine. I wanted to make sure it looked decent inside before I pulled the engine, plus I remember reading about someone flipping an engine off a stand trying to break the head bolts loose
Since this was a LPT engine my original plan was to build the engine using a set of pistons from a V70R to convert it to a HPT. I immediately hit a road block when I called my local dealer and was told the pistons were on back order and probably not available. So after talking to a few people on VS I decided that, since my plans included a set of RSI H-beam rods, I would go ahead and build it as a LPT. The jump from 8.5:1 to 9:1 probably would be ok with stronger rods.
Then the next road block. The machine shop called and said the block deck wasn't flat and the head needed to be milled. So between decking the block .005" and milling the head .011" now my compression would be even higher. Not sure how much, but from what I saw online I'm thinking about .25 to .5 higher. I wasn't comfortable going up to possibly close to 9.5:1 so I was on a mission to find a set of lower compression pistons. I talked to someone else at the dealer and was told the pistons were back ordered NOT discontinued. So since I was going to have to wait on rods anyway I might as well wait on pistons to.
I got the engine back from the machine shop and waited for my rods....
Decided to install the crank while STILL waiting for my rods
Finally got the rods on Tuesday
Followed by the pistons on Wednesday. Now we're in business!!
The rods and pistons will go in this week....more pictures then....
