Help Me Save My 940!
Guest_Shadydave007_*
Posted 30 October 2010 - 11:17 PM
When my SRS dashlight goes on my charging system doesn't "charge". When the SRS light goes off my car works and "charges" just fine. Through several mechanics and personal trials; replacing the alternator does not fix the problem. Regardless of the old alternator or a replacement I get the same result.
If the SRS light stays on my 940 behaves like there is a bad alternator. After I allow the mechanic to install a new alternator it still will not charge. The old alterantor then has a positive bench test and proves not faulty. The mechanic then looses an easy payday but tries to regain losses and insists its the battery.
The battery is less then a year old and passes every test. Plus I have a 3 year warranty on the battery so they can't sell me a battery. I also have personally replaced the alternator 3 times myself. It takes a 13mm to loosen the tensioner, a 12mm and 13mm to remove the mounting bolt, and a 13mm and 8mm to remove the leads.
Here is my confusion/dedication...I have proved to myself that my charging system works when the SRS light is off. While the SRS light is on regardless of a new battery and alternator or an combonation of the two. While the SRS light is on my 940 doesnt charge.
I have the 100 amp alternator. I believe the voltage regulator is built into the alernator. This problem is intermitten and makes me believe the charging system is fine. The SRS light has a mind of its' own regardless of components.
I love my 940 brick and want to fix her. I am at a point finacially to either get a "push-pull-or-drag-it-in" value for a trade in. Plus my beloved brick gets crushed and scrapped. I will loose sleep over it (possibly cry into my cereal)!
After reading the discussion boards there is a contact or wiring problem that has an easy fix which doesnt require a dealership visit...your help is greatly appreciated!
Thanks,
shadydave007
Posted 30 October 2010 - 11:40 PM
I don't know of a specific fix, but I would check the ground. In fact, I would add a heavy duty ground to the chassis. About 80% of the electrical problems I've had in various cars could be traced to ground problems. I'd start there until someone chimes in with a specific answer.
Posted 30 October 2010 - 11:55 PM
Posted 04 November 2010 - 01:23 AM
Haven't yet had a chance to investigate the issue on my car, and it has fixed itself for the moment. I believe the fault is in the instrument panel, shouldn't be too difficult to track down.
I would inspect the small red wire at the alternator and make sure it looks in good order. You might disconnect this wire from the alternator and jumper this to a ground, with the ignition on the idiot lights should turn on, but if not, next inspect the instrument panel and it's connectors. I'd be more specific as the which connector but I don't have access right now to my manuals. Might be a fault in the flexible printed circuit board on the backside of the panel, which could be a visible fault, or may require tracing it out with a multi-meter.
Posted 21 December 2010 - 01:52 PM
Following that, Make sure the bulb in the dash is good. The current passes thru this bulb to excite the regulator and if its bad/loose/missing you will not get a charge. The reason the SRS light comes on is because the voltage is to low for it to operate, so it shuts down and puts on the warning light.
1978 242DL - 1995 855 T5 ARD Green - 1991 Stanza XE
Posted 05 January 2011 - 05:22 AM
Posted 04 February 2011 - 01:31 AM
(the first 3 are mine,heh,heh.) 525,000 Volvo miles put on 10 bricks
Posted 06 February 2011 - 02:06 AM
