X70 Led Swap: The Thread
42 replies to this topic
#1 T5power
T5power
  • 4,773 posts
  • Interests:Underwater Basketweaving
Posted 07 November 2010 - 08:28 PM
i'm growing tired of the bi-weekly "what kind of LED goes where" kind of stuff. figured i'd just make a thread about it. hopefully this can be stickied.
you can really buy these LED's anywhere you wish, i'm just showing an example of where you might be able to find these. i have purchased LEDs from V-LEDS.com, autolumination.com, superbrightleds.com, and ebay. the ones i purchased already had resistors built in, cause i just wanted something "plug and play" essentially. but i will give you the website for where you can find these. what i have noticed though, is that v-leds.com sells them by the pair. so dont think that they are overpriced!
so. the list goes like this:
Turn signal indicators, malfunction indicators, mileage and info cluster
the bulb/LED type is 74
You will need:
2x for turn signals
1x for mileage cluster
2x for info cluster
20x for malfunction indicators, although not all indicators are used
the blue bases are for these kinds of bulbs, they are the ones that fit T5 leds. T5 LED is on the left. what i recommend is that the single led like below should be used for turn signals, malfunction indicators, and the mileage cluster. the info cluster you should have a multi SMT (surface mount technology... look it up. i'm not explaining it :P )LEDs to make even lighting.
Where to buy
http://www.v-leds.co...ForLanding/true
http://autolumination.com/74.htm
http://www.superbrig...mini-wedge.html
Gauges, and license plate lights
the bulb/LED type is 194
you will need:
4x for the gauges in the cluster
these are larger bases than the 74 one. on a side note, these are the same type of bases that you can use in your license plate. i dont have a picture of the bulbs, but your LED's should look something (not exactly) like this
Where to buy
http://autolumination.com/194.htm
Climate control
this is kind of a special case. i tried for a very long time to find the right plug and play replacement for this, because the shaft of the original bulb is extended with a 4mm bulb. the base is also somewhat unfamiliar because it is in between 2 common sizes.
the bulb/LED type i was able to find is NEO 4X
size="4"]you will need:[/size]
4x for the CC
Where to buy i could only find them on one website
http://www.superbrig...=/specs/NEO.htm
Radio
the bulb/LED type is T3 i believe these are slightly special. the ones from autolumination are the smallest i could find that could fit
You will need:
5x for radio bulbs, but i recommend buying extras, as these are delicate. other sidenote; if you are going to change over the radio to LED, the diffuser that spreads the light around needs to be milled down a little bit for the bulbs to fit. it is a VERY tight fit
they look like these
Where to buy
http://autolumination.com/74.htm scroll down and look for the ones i just posted
headlight switch & other toggle switches
Headlight switch, Dimmer, Info switch and Heated seat switches
the bulb/LED type is T3 again for these
al other switches use T4
You will need:
5x for the T3 LEDs
6x for the T4 LEDs
the T4 leds are right next to the T3's, obviously
Where to buy
http://autolumination.com/74.htm scroll down, you'll see them
that is all the info i can gather for plug and play. the other parts like the window switches require soldering, someone on the board i am sure is more familiar with that than i am. the other thing is the gear selector for automatic transmissions. this was the only ghetto part i could rig up, because the bulb they use is unique to volvo. i just took an extra 74 type LED and plugged it into the socket, wires just slid in. it looks terrible but you cant see it cause it's all hidden. and then i just taped it in there. all done! the only part i need to fix is the radio. the LED's i used are very old and i need to mill the diffuser out a little more and put some newer ones in. another thing is that i need multi SMT led's in the info cluster because the gauges are SO bright. next up for me is gauge rings and front lit LED's. check it out.
my fingers are tired. enjoy!
Edited by Goldmember, 07 November 2010 - 08:32 PM.
///T5
#2 besthaticouldo
besthaticouldo
  • 585 posts
Posted 07 November 2010 - 09:20 PM
thanks for the info bro...i am gonna do this soon.
some people are trolls. lol
#3 Logan2224
Logan2224
  • 1,124 posts
Posted 08 November 2010 - 08:06 PM
Thanks man! Definitely gonna bookmark this one. I can't wait to get this done.
02 C70 Coupe - 92k, Silver/silver, 6000K HIDs, EST intake, IPD HD TCV
#4 T5power
T5power
  • 4,773 posts
Posted 08 November 2010 - 08:17 PM
sure thing guys. also if there is anything i missed, let me know and i'll edit the post. i really want everything all in one post.
///T5
#5 Chilled Man
Chilled Man
    MILFSPEED
  • 30,087 posts
  • Gender:Not Telling
Posted 08 November 2010 - 08:19 PM
Finally :D
Now corey order all that for me in orange and come install it in the saffron :lol:
I will pay you double the cost of the LED and buy you lunch :lol:
#6 Logan2224
Logan2224
  • 1,124 posts
Posted 08 November 2010 - 08:23 PM
I'll have a little something to add to this when I get done.. :D
#7 besthaticouldo
besthaticouldo
  • 585 posts
Posted 08 November 2010 - 08:36 PM
what about the bulbs in the window switches??
Edited by besthaticouldo, 08 November 2010 - 08:38 PM.
#8 T5power
T5power
  • 4,773 posts
Posted 08 November 2010 - 08:55 PM
View PostChilled Man, on 08 November 2010 - 08:19 PM, said:
Finally :D
haha deal. that is going to look AMAZING in the saff... oh lawd i cant wait
///T5
#9 Tom.
Tom.
    LONGTOM
  • 2,916 posts
Posted 08 November 2010 - 11:10 PM
i un did all my leds :lol: buy quality bulbs guys dont cheap out you dont wanna havta replace them. mine were flashing and such...
00 Olive V70R -- 98 S70 T5M
#10 Oreo931
    Level 8 Senior Member
  • 23,659 posts
Posted 09 November 2010 - 12:26 AM
Pinned. Thanks for the write up Corey.
#11 T5power
T5power
  • 4,773 posts
Posted 09 November 2010 - 01:22 AM
one of the reasons why i had to switch all of this out. you gotta pay to play. i think the total cost is about 75 bucks for some quality LED's.
thanks for pinning this adam
///T5
#12 Korruption
Korruption
  • 1,835 posts
Posted 09 November 2010 - 01:56 AM
Good writeup. Should definitely be stickied. I need to redo my LED's, and this is perfect.
1991 244 NA - M47
#13 Prezman26
Prezman26
  • 1,855 posts
  • Interests:Volvos and girls.
Posted 12 November 2010 - 03:16 PM
The bulbs in the 850 trip computer are different than the 70 series.
2007 Electric Silver S60R-------105.5k
#14 T5power
T5power
  • 4,773 posts
Posted 12 November 2010 - 03:28 PM
for everyone who is interested in swapping over LED's in their 850 i refer them to this thread:
http://volvospeed.co...pics-of-my-car/
there are several things that are different between the X70 swap and 850 swap.
///T5
#15 Gage
Gage
    Che's Favorite
  • 2,688 posts
  • Interests:Sleeping , Driving And Sleeping
Posted 12 November 2010 - 04:04 PM
Yes you would need one of these two ill find out later today if its the b8.4 or b8.5
B8 8.4/8.5
Also why would you need 20 of the warning bulbs ? they are ment to light up a different color like the CEL it lights up orange so if you were to put a Blue led behind it i would show up green ? Dont get me wrong you did a GREAT Job on this writeup, but to me it just seems like a waste of money to get all the extra warning bulbs is all
BTW Thanks For this write up, im putting my order in today for the wifes S70 :D
Edited by Gage, 12 November 2010 - 04:09 PM.
-Pat-
'99 S70 AWD
RIP-Tom, '94 855 Turbo 5spd BUILT NOT BOUGHT
#16 T5power
T5power
  • 4,773 posts
Posted 12 November 2010 - 08:41 PM
B8 8.4/8.5
hahai didnt replace all 20, i did all the ones that pop up commonly. Tracs, ABS, CEL, Park Brake, Service. i felt like those bulbs would be the quickets to burn out, just preventative maintenance :lol:
all i did was replace the RED warning indicators with RED leds, the abmer ones with amber, and the blue hi beam indicator with white, makes it look great!
Edited by Goldmember, 12 November 2010 - 10:43 PM.
///T5
#17 --Aaron--
--Aaron--
    douche bag
  • PipPipPipPipPipPip
  • 12,546 posts
  • Gender:Female
Posted 14 November 2010 - 04:08 PM
Great write up, your information was the reason I was prepared when I pulled my cluster to install all new light bulbs.
#18 njbrickwithboost
njbrickwithboost
  • 17 posts
Posted 18 November 2010 - 07:36 PM
That's pretty awesome man. Thanks for the info. Just out of curiosity before I rip my guage cluster out.....can I make the speedo guage color different than the needle color? Just curious?
Steve P
#19 timebandit
timebandit
  • 4 posts
Posted 28 December 2010 - 05:59 PM
Very good info but I want to confirm the socket type.
I have tried to change the bulbs for the milage and clock/info. I gave now tried both socket B8.5d and B8.3d and they won't really fit!
Is it really a T5 socket (glass) for these?
//Kensy
#20 T5power
T5power
  • 4,773 posts
Posted 30 December 2010 - 03:49 PM
//Kensy
well it's the T5 LED that fits into the (#74 type bulb) stock base. you don't have to change out the socket at all. this is meant to be completely plug and play.
///T5
