Got The Oil Drain Plug Blues
15 replies to this topic
#1 marsman
marsman
  • 49 posts
Posted 19 November 2010 - 11:52 PM
My original drain plug housing is stripped and I have been using a temp drain plug for a while 12 plus months. Im wanting to get a tap kit or replace the pan (a real PITA I understand). The last oil change the guy told me that I would need at least a 19.5mm tap. Any ideas as far as solutions. A new pan would cost me around $350 to $400. Trying to avoid such a large expendature for this. Any ideas/suggestions resource links would be appreciated!
#2 Guest_doug_*
Guest_doug_*
Posted 20 November 2010 - 12:49 AM
Thy self tapping plug made just for this purpose. Available at auto parts stores. Install it like you were tapping the hole. Work it back and forth. Purchase some new waskers / gasket. Worked well on my truck.
#3 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,479 posts
  • Gender:Not Telling
Posted 20 November 2010 - 01:19 AM
Get a pan from the junkyard on the super cheap and replace those crappy oil pan o-rings while your there ;)
98 S70 T5M
#4 marsman
marsman
  • 49 posts
Posted 20 November 2010 - 06:54 AM
Will head to the auto part store tomorrow to inquire on a tap kit...will do the junk yard exploration as a back up plan for now...Thank you!!
#5 jschaefer7406
jschaefer7406
  • 487 posts
Posted 20 November 2010 - 07:55 PM
Yeah, what he said :D. Might as well fix it right. Just had the pan off of my 2000 last night to replace the sump o-rings. Wasn't having too much trouble yet, but for $20 I figured I'd do it before winter for preventive maintenance. Not too bad on a 5 cylinder, its the S80 that's a bit tight :D. Had to pull the front mount and torque rod only (sub frame left in place). Mine actually had an o-ring misaligned from the factory, causing the pan to pinch the edge of the seal. Had to be causing a leak :). Anyway, not a bad job really.
Good luck,
Joe
#6 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 23 November 2010 - 02:37 AM
I covered this a few years ago... there is enough room too tap that pan for a 240 drain plug and seal ...(hint) the threads on a 240 plug are standard not metric ;)
"SMOKE TROUT NOT CRACK"
#7 marsman
marsman
  • 49 posts
Posted 28 November 2010 - 05:00 AM
That is great news MrWinkey - Thanks for replying. I will go this route!
#8 Account_Deleted_T5M
Account_Deleted_T5M
    I Was Pwned
  • 5,827 posts
Posted 28 November 2010 - 06:16 AM
Since your going to have to pull your pan anyway, I have a spare oil pan for your car if you would like to keep oem, also has the magnetic drain plug
If you want to replace with oem drain pan, since you have to pull the pan anyway let me know I have an extra one for your car
Sorry to all the people who are still trying to get their money back.
#9 marsman
marsman
  • 49 posts
Posted 28 November 2010 - 10:56 PM
Thanks for the reply - how much do you want for it?
#10 ProAv
ProAv
  • 22 posts
Posted 22 October 2011 - 05:10 PM
Just bought a 2003 XC70 with a stripped oil pan, has anyone had success with tapping it to 19.5mm?
1995 GLT Wagon
#11 Milo
Milo
  • 218 posts
Posted 23 October 2011 - 06:37 AM
Why not helicoil it? Also finding an SAE tap is way easier than finding a good 19.5mm tap and then you already have a reliable source of drain plugs (240).
For info:
The 240 oil drain plug should be 3/4-16 (confirm this)
Mcmaster.com part number 2521A668 is a 3/4-16 taper hand tap. It will work perfectly for you.
You'll want an 11/16" drill if you desire to pre-drill it (I wouldn't unless it clearly makes sense to do so when you are under there).
Go straight, go slow, use tapping fluid (made for aluminum) and you'll be set.
Just confirmed that a 240's plug is indeed 3/4-16
1995 855T 298k (sold) :(
2006 V70 2.5T 148k
#12 ProAv
ProAv
  • 22 posts
Posted 25 October 2011 - 05:12 PM
Milo, Thanks! That is a good idea, don't know why i didn't think of the helicoil...
1995 GLT Wagon
#13 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 16 November 2011 - 03:19 PM
I would not do a helicoil over retapping. Even if you do not have a tap and die set you can get by with the cheapest tap on earth.
http://www.amazon.co...21456591&sr=8-1 <-- more than enough for a one time use on an oilpan.
Next person who finds this post searching for fix, shoot some photos and I will set you up with a years supporting membership.
#14 marsman
marsman
  • 49 posts
Posted 16 November 2011 - 11:17 PM
Thanks Che'!
#15 MrWinkey
MrWinkey
  • 4,759 posts
Posted 27 November 2011 - 12:09 AM
#16 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 27 November 2011 - 12:24 AM
Oh noes! Someone is drinking again.
