So You've Decided To Buy And 850/70 Series........ An Homage.
36 replies to this topic
#1 MnOpRacing
MnOpRacing
  • 98 posts
Posted 07 December 2010 - 11:21 PM
Disclaimer: This post is long and is a history of my ownership and work on a P1 car which can be applied to anyone thinking of buying a P1 volvo. Some Volvo's were harmed in the making of this post.
Well then the first decision you have to make is how much of your hard earned money goes to this noble cause. Fortunately there are options, but for this post were going to talk about the most common two.
The first being the easiest and most expensive UP FRONT. Simply purchase a very well maintained car with up to date service, a clean body, and up to date service. These will run you about 7-9k on average with a lot of documentation and service records to back up the price. Most will have timing belts, pcv systems, and tune up parts all ready done. Also the bodies will be in good to great condition and interiors resembling the cleanliness and quality of 1000 count Egyptian cotton sheets. After purchase the only thing that really needs to be done is regular oil changes and to be driven.
I bet by now your thinking to your self that 9k is waaaay to expensive and being the savvy consumer that you are remember that your grandmothers friend has a P1 that she never drives and being partially related that you could grab it for 2k and never have a problem with it because its the uber rare model that runs on unicorn tears and leprechaun jizz. If thats the case I wish to shake your hand because you are in the 1% rarity category. For everyone else 2-3K will buy you a weathered car with little to no service history or records, a body showing its age, a motor with no stage 1 work and the sweet sweet smell of coolant every time the heat is turned on. That is depending wether or not your HVAC is blinking HELLO to you in mores code reminding you its broken......or its feeling festive.
Im sure by now the mechanically inclined will still want to go with the 2k car with the impression that with a little work and time they can get there car to the 9k standard in 1/2 the cost. After all that 3k v70 on the lot down the street runs fine and all it needs is a simple stage 1 and some after-market goodies to make it rock solid. Maybe get some sweet koni yellows and some sways, then throw in an exhaust and you got yourself a M3 killer that can swallow a Christmas tree in its boot.
This is were my V70 comes into play, because I had the same options when looking for a P1. More specifically I was looking for a 1998 V70 T5 MT, the unicorn. So when I found one only 90min away for 3k I though to myself "What a deal!!!". My thinking was that it only needed some work, and being mechanically inclined It could be done on the cheap and ill feel like a King! A King with a 5k wagon that will give me no problems ever. I imagined it being on the same level as an after school special or a really good episode of Full House in which Danny tough Michel a life lesson with some laughs along the way.
So now sit back an enjoy this photo heavy journey into what one might find down the cheap Volvo build path. Or what I like to call:
“Volvo, how I learned to love the box.......on wheels”
The day I bought her, NEVER BUY A CAR I THE RAIN!!! Seriously, it hides a lot of imperfections.
Upon initial inspection I thought it didn't need too much. Stage 1, RMS, and maybe I would swap to charcoal interior. This was exactly a year ago in November, she had 138,589 on the Odo with no service records and four previous owners. But for some reason I just had to have it even after thinking about it for a cupel of days. There was something about a turbo 5sp wagon that just made me giggle like a school boy.
Being that I didn't have a garage to service the RMS problem I was lucky enough to find a rentable unit 30min from my home for $150 a month. What follows is a montage of what might happen when pulling a motor, Id call it a bad case of "Well, while its out I might as well....".
TOOLS!!
The Space
I didn't notice this until I brought her home, NEVER BUY A CAR IN THE RAIN.
Upon closer inspection It looked like my V70 had the optional chassis lubrication system.
And the Fun Begins...
After the pull it became apparent that all of my oil seals had died some time ago, not too bad though being only seals. The upon taking the exhaust mani off I found more good news!
Ok so my valve seals are leaky, just a head rebuild is all it needs.
UG, looks like someone didn’t change the oil that much. Well might as well get a rebuilt head at this point.
I did however luck out with this, Head bolt #5 was literally holding on by A THREAD and broke in two when I placed it on the table.
On to cleaning, the before.
Its all in the prep, a lot of shop towels and grease to fill the small holes just incase something were to find its way into the oil passages.
After 5 or so passes using gasket remover, a brass wire brush and razor blade for the larger material this is the mess it causes.
Eventually it took me around 10 rounds of gasket remover/scrubbing to get it clean, about 10 hours total. I used brake cleaner and a variety of artist brushes to clean the pistons, then blew out the shmeg with compressed air. Yes it was a bit anal but look at the results, I could stare at this for hours.
Now it was time to bust this puppy out!!!!!
Now that the top end is done, time for the oil pan sump gaskets and RMS replacement.
Resurfaced flywheel, 850R clutch and PP.
Even the trans housing was smeared in oil, probably great for the clutch.
Lightly used replacement turbo of an 04 S60, the oil/coolant feed lines are slightly different but with a pipe bender they can be made to work.
Then back in she goes!!
On her maiden voyage the turbo's coolant feed line burst (1 of 2 old lines I reused, yea).
After the shake down tests and some weeks of driving it was time for some other new items to compliment the "new" motor.
Koni yellows on H&R springs with all new fixins to replace the old worn out crap. As well as a slew of new suspension goodies.
The next biggest thing was the tan hell that was the interior. All the seats were trashed and all the door cards were delimitated. I was going to go tan again but I found a pristine black interior out of an 850 in the JY so I decided to go charcoal and get as much usable parts out of the 850. The dash and door cards were sourced out of a number of other 70 series cars in the same yard.
Some various shots of the body. Started with a busted tail gate and stock springs then slowly got the lowering springs on, a JY hatch, new tires and an xc70 roof rack system.
How she sits now, more or less.
The last thing I did was apply some sound deadener to the trunk area and below the rear seats to cut down on the resonance the wagon naturally has. I also applied foam to the back of every plastic panel to stop all the squeaks and rattles. Took for friggin ever but its quiet as a wagon can be without adding another 50lbs of material.
T5 logo
So now after all that pic whoring lets tally up the total of what I spent to get it to this point.
"Hold on to your buts!"
MOTOR:
-Reman head from Clearwater Cylinder Heads
-Resurfaced flywheel
-850R Clutch and PP
-New throw out bearing, slave cylinder
-Lightly used 16G Turbo and exhaust manifold of 04 S60
-Brass shifter bushings
-All new motor and Trans mounts
-Complete PCV system
-Volvo plugs/Wires/Cap,Rotor
-New Bosh MAF
-Air filter
-Fuel Filter
-All new vacuum hoses
-Silicone turbo hoses
-Timing belt/Water pump/pulleys/tensioner
-Serp belt
-Thermostat
-All gaskets and seals replaced, all Volvo OEM and not that after market crap (Oil sump, Turbo drain, Cam seals, RMS, Axle seals, Dip stick, Ext ext)
-All new hardware/bolts for anything that required them (Head,PP,Flywheel, Ext)
-All fluids flushed and replaced (Oil Mobil 1 synthetic 5-30, Coolant Prestone, P.S. Dextron ATF , Trans Red line MTF)
SUSPENSION:
-Ipd sways, front and rear
-H&R springs
-Koni yellows
-Shock mounts, bearings, spring seats
-Sway bar HD end links
-Control arms
-Inner/Outer Tie Rods
-Strut tower bar
-Bridgestone Potenza Pole position's 55-16-115
-2 used wheels to replace a bent and damaged original set
-Replaced axle boots
-New ABS unit
BRAKES:
-Centric rotors all around
-Wagner semi metallics all around
-New brake lines, front
-New e-brake shoes and hardware
-Complete fluid flush and replaced with DOT4
EXHAUST:
-Eurosport Tuning catback.
STERIO:
-Pioneer Deck with USB input
-Pioneer 6 1/2 three way speakers all around
-New battery
-Second skin mass load sound deadener material for trunk
-Second skin closed cell foam for squeaks and rattles
COSMETIC:
-Complete charcoal interior (Might stay black on tan)
-JY Hatch to replace dented original
-JY front/rear bumpers (Not on yet, need to be painted)
-IPD boost gauge and pod
-Replaced all burnt out bulbs in dash
-Fixed rear bumper sag at least
HOURS:
-The motor/trans took a cupple of months to complete since I was working. The rest was done over the corse of this year. If I had to guess probably a solid two to three months of 8hr days of work, all free thank God. Right now the Odo reads 142,000, around 8k since the rebuild.
THE GRAND TOTAL:
As of right now with all the parts listed above and counting the cost of the car (3k) Im up to ...............................
$11500!!!
Yea, that doesn't even factor in the rent for the garage, oils, chemicals, gas to get to garage and other small items it took to get it this far. Not to mention the things that I still need to do to her to get it perfect. Like a full paint job, wheel spacers, sub-frame bushings, all new bushings for the rear delta links, and I need to install the heater core I bought last year that I’ve been too lazy to do.
I still want more powa too, like a 3”DP and tune$$$$
Overall though, at the end of the day Im driving a car that I made just the way I wanted it from the factory. But I think the best part about going this rout is the knowledge gained from taking your car completely apart and putting it back together again. If the motor blows up, no sweat Ill pick up another for cheap and rebuild that one with more powa this time. Thats probably why I drive the snot out of it without worrying too much about if I might damage anything, plus it amuses me to no end driving a wagon like a sports car. Im sure I speak for the majority when I say third gear pulls are simply orgasmic and the symphony of sounds belched forth from the motor when your in her hard lets you know your not the only one who is being satisfied.
So take what you can from this in making your decision on what condition Volvo you want to buy. Keep in mind this is only one man’s story, Im sure there could be a cheap Volvo out there that only needs a small amount of work. Just be prepared to easily spend 2x what you think is needed, parts and problems add up quick especially when talking about a 12 year old European car.
Full top end rebuild, 850R clutch kit, Koni Yellows, H&R springs, Eurosport catback, and a lot of love...er money.
#2 Vagabond
Vagabond
  • 1,047 posts
Posted 07 December 2010 - 11:30 PM
Cool post dude. +1
As a counter point to your total, I'd like to link my thread. http://volvospeed.co...ou-get-for-200/ for others to follow.
Just to show a daily drivable cheap Volvo is absolutely feasible. It should be noted I drive this car Monday through Friday 150 miles a day on average between NY, CT and MA for work.
Again great post.
Edited by Vagabond, 18 May 2011 - 11:26 PM.
1994 850 NA 200,XXX mi. Coming Soon: Mo Flow...
The Build
#3 Account_Deleted_T5M
Account_Deleted_T5M
    I Was Pwned
  • 5,827 posts
Posted 07 December 2010 - 11:33 PM
Sweet investment :unsure:
Seems like a lot of money to dump into a volvo, i mean i've owned my 850 for 5 years and spent about $1000 in parts, and it runs tip top, and my s70 ive owned for 3 years, and i've spent about 9,000 in parts so i'm not far off i guess
Sorry to all the people who are still trying to get their money back.
#4 greekone
greekone
  • 3,414 posts
Posted 07 December 2010 - 11:45 PM
That was a pretty good read. Just curious, did you buy this car from a dealer in Franklin, CT? If so, maybe it was a good thing I didn't get a chance to buy it. lol
'95 854 T-5R
'98 S70 T5
'09 BMW 335i 6MT
#5 besthaticouldo
besthaticouldo
  • 585 posts
Posted 07 December 2010 - 11:50 PM
wow...that was quite a read. but still a badass unicorn you have there man.
some people are trolls. lol
#6 831t5r
831t5r
  • 522 posts
Posted 08 December 2010 - 12:48 AM
Sweet thread man, only thing I would add if you had the motor apart and that far and downtime, you shoulda pulled the pistons out and cleaned in between the rings and the grooves. They easily gunk up and especially if oil isn't frequently changed.
95 850 T5-R - Sold : (
'00 V70R-Parted and Junked : (
'01 C70 Coupe - Stock
05 XC90 T6-coming soon
#7 Keaton85
Keaton85
  • 7,499 posts
Posted 08 December 2010 - 01:18 AM
WOW, not what my plan would have been but heck, now your set for a while.....
Always, extremes out there and this is one of them! good work getting it all good to go.
#8 scumcity14
scumcity14
  • 4,819 posts
Posted 08 December 2010 - 01:27 AM
Nice post! That is exactly what I am in the middle of doing right now to my red T5m...bought a cheap fixer upper and now I am replacing everything including the trans, clutch, t-belt etc etc.....I don't know if I shoulda done it or not, (the grenaded trans was a surprise) but it was a 98 T5m and all the electrical crap works and the interior is mint(and already black ;) ) exterior is very good..whatever its too late to change my mind now, the money has been spent!
#9 Keaton85
Keaton85
  • 7,499 posts
Posted 08 December 2010 - 01:36 AM
How did you mess up the tranny!
It's all about being able to spread the cost and knowing what to replace or what not to replace. You are always going to get shafted going all out and trying to fix everything all at once.
#10 volvoskiah
volvoskiah
  • 1,732 posts
Posted 08 December 2010 - 01:57 AM
That is some good work! Just an fyi, the 05- present s40 and v50 are the P1 platform. x70/850 is the P80 platform.
79 242 GT*84 F150*96 854R*98 S70 GLT-M*98 V70 AWD*00 V70R
72Chevy K10 Cheyenne*78 242 GT*89 740 TIC*96 855R *97 855R*98 V70 NA*98 V70 XC*98 S70 T5
98 C70 T5m*98 V70R*98 V70R*99 S70 AWD*99 V70R*99 V70R*00 V70R*00 V70 XC*04 V70R
#11 scumcity14
scumcity14
  • 4,819 posts
Posted 08 December 2010 - 02:14 AM
I didnt mess it up, the damn PO did.. I bought it with all 4 cv joint boots torn and making a racket...turns out some of that racket was the trans. There was no filler plug and there was only @ a cup of oil mixed with water in the the gearbox :angry: I am doing the clutch of course and the RMS too...I was thinking about doing a photo thread, just like this one!
#12 Oreo931
  • 24,508 posts
Posted 08 December 2010 - 04:48 AM
Nice work. That's commitment right there. As far as money spent, it's a hobby, and if you enjoy doing it and it makes you happy, then go for it. Every time I look at the spreadsheet detailing pretty much every dollar I've spent on my car, it freaks me out a little. But then I get into my car and completely forget about it, and that's all that really matters.
I hope you hold on to this for a while. I plan on keeping my car forever. :)
Edit: I'm moving this to the showroom section. I think it will get more views there, and it's a good thread.
#13 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,594 posts
Posted 08 December 2010 - 05:42 AM
All I can say is wowwwwwwwwwwwwwwwww.
1996 850 turbo wagon auto, Custome intake, MSD coil, IPD spark plug wires, Eibach springs, Bilstiens HD, Mesh grill, IPD strut tower bar,ultra racing 2 point rear strut bar, Tiki end-links,IPD intake manifold spacer, FCP silicone inter-cooler hoses, stoptech steel braided brake lines front and rear, completely rebuilt auto tranny, Complete stage zero. soon to have (white injectors, s70 front end, 16t, ARD tune)
#14 johnloves850's
johnloves850's
  • 2,472 posts
Posted 08 December 2010 - 08:04 AM
A lot of unnecessary expenses, but hey it's not my car :lol:
Looks like a sweet ride though :tup:
1996 855 n/a.
#15 matt b
    Earth Day-Every Day
  • 15,744 posts
Posted 08 December 2010 - 02:53 PM
But your cars don't come close to this one, in terms of reliability and cosmetics. Sorry. Posted Image
OP: great read, nice work on the car!
If you decide to change the color of the console to match the rest, this stuff was a perfect match in my '96 850 after the swap. It help up really well too: Posted Image
#16 esundell90
esundell90
  • 741 posts
Posted 08 December 2010 - 03:11 PM
For the figures posted above, there is a reason I don't keep a record of how much I spend, lol. Ignorance is bliss :rolleyes:
That being said, I haven't done that much work, but then again, you have the knowledge of knowing you did things right. Props.
I need to do my PCV and replace my oil pan next year. mine haz a dent. Could probably replace that sump system too while I'm down there. For now the car runs awesome tho. Its got its quirks, but its a 15 year old car with over 150k, can't ask for perfection. Oh, and I need to paint my bumper, side skirts too! :)
-Eric-
Her name is Violet, She's my Wagon.
#17 RBoy8
RBoy8
  • 6,447 posts
Posted 08 December 2010 - 04:12 PM
Very nice job! I always get the "wow look at how much time and money you spend on the car" thing from people, but in the end it's because I like the car and think it's worth it. With all the work you've done, it's now like having a brand new '98 T-5M lol. For $11 500, I can't imagine finding a brand new car even close to your liking. :)
The two-tone you have going is exactly what I want to do! I like it hehe.
#18 ADavies207
ADavies207
  • 27 posts
Posted 08 December 2010 - 06:56 PM
Great read! +1
I guess this shows you that you never know what you are going to get yourself into when buying a used car. Nice work man!
-Andrew
99' S70 T5M - Charcoal interior swap|Comets|IPD turboback|Koni yellows|Eibach springs|Stylin
90' 745T - 15g|Bilstein HD's w/ cut springs|3" turboback|green top injectors|FMIC
#19 Keaton85
Keaton85
  • 7,499 posts
Posted 08 December 2010 - 07:26 PM
I'm with you on this one, it's a lot to do with knowing what to replace and what not to replace along with spreading the cost.
I would have done the PVC system, and the timing belt first. Run it for a few years with a poor RMS, then when i had time do the RMS with a clutch and no resurfacing needed. Then keep up with the general stuff over the next 4-5 years with about 1,500-2,000 worth of parts max. By that time the vehicle will either be sold or wrecked.
Maybe that just because I've had way to many of these vehicles to care. I've done the fix everything, love the car, perfect maintaince bit to only either sell or get it wrecked to do that ever again...
Sorry but just different stokes for different folks.....
#20 Tom.
Tom.
    LONGTOM
  • 2,995 posts
Posted 08 December 2010 - 08:25 PM
this car was at swedeish car day? where in mass are you from man? :lol: excellent read!
00 Olive V70R -- 89 244 DL
