Cam Timing Tool
88 replies to this topic
#1 Ipd
Ipd
    Mr. IPD
  • Validating
  • 1,562 posts
  • Gender:Not Telling
Posted 07 January 2011 - 04:29 PM
Had some prototypes made. Similar design to the old units QBM offered, few minor changes to make them more precise/easier to use.
Is there still interest in these? I basically had some made for our service shop and one to throw in my tool box.
Should we go into production?
These units are simply steel, would probably have them black oxide coated and then laser etched.
If we go into production I planned on doing a basics "cam timing 101" video, worth the time you think?
Gimme some feedback!
Mods, this probably belongs in member announcements, move as you see fit...Thanks!
#2 ozzimark
ozzimark
  • 4,352 posts
Posted 07 January 2011 - 04:35 PM
They look very happpy. :lol:
I know demand for them comes up every now and then, it would be great to have another source for adjustment.
Have you considered making one for the VVT cams too?
#3 7 VII 7
7 VII 7
  • 22,520 posts
Posted 07 January 2011 - 04:42 PM
That would be wonderful!
1 of 1 - '97 427 854R - 110k
#4 gilber33
    Level 6 Senior Member
  • 11,110 posts
  • Interests:you
I would say do a run of them if anything. I got in on that small group buy for cam timing tools a while ago, and I think only 7 people participated. After that, I never really see anyone asking where to buy one or anything. But those ones look good. :tup:
1994 850 Turbo | Rica Stage III | Poke and Stretch
#5 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 07 January 2011 - 04:43 PM
I'd be glad to field test one for ya to verify that they are easier to use and more precise, since I have and use the QBM version currently...
I would think if the price was right you would sell lots of them...if it was not at the right price you would still sell some since they are valuable tools for the dedicated tuner.
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted ImagePosted Image
#6 the commissar!
the commissar!
  • 2,024 posts
  • Crew:ECC
Posted 07 January 2011 - 04:53 PM
The problem with those, which we knew up front, was that they were not marked in 1-degree increments on the scale. It was something odd like 0-2-4-5-7, I think that scared some folks off. Otherwise it was ok, and I used mine a lot but I sold it once I obtained a QBM.
#7 Ipd
Ipd
    Mr. IPD
  • Validating
  • 1,562 posts
Posted 07 January 2011 - 05:01 PM
These are marked in 1 degree incements on the cam. Since the cam spins at half speed to the crank that means each division is 2 degrees of crank rotation. This doesn't really matter as all you need to know if how much more/less you want from where you started.
as for feild tester, pm me your address commisar and I send you one. These are rough not finished units though so I'll probably paint one quickly for you.
I'm hoping to keep the price point low, like a $19.95 scenario give or take.
Support it with a video so it isn't so intimidating to folks.
As for CVVT, cant be done. the ecu monitors the variance and can adapt for changes up to ~5 degrees. So you can change the base timing of teh cvvt head but ecu will learn around and comensate for it. Change it more than that and you get check engine light.
#8 ozzimark
ozzimark
  • 4,352 posts
Posted 07 January 2011 - 05:35 PM
Ah, wow. I didn't know it was using the CPS as a feedback loop on the CVVT systems. What about the intake side that doesn't have a sensor on it? :huh:
#9 98t5M
98t5M
  • 435 posts
  • Interests:Computers, Electronics, Motorsports, Food, Beer.
Posted 07 January 2011 - 06:05 PM
I'd definitely buy one if the price is right, heck I'd even buy the prototype if you're willing to sell it.
#10 sconeman
sconeman
  • 4,157 posts
  • Interests:family, cooking, making stuff, cars
Posted 07 January 2011 - 07:00 PM
I think if you had a cam timing 101 video available with it you'd get a lot more people who would be interested than in the past.
Do it!
#11 7 VII 7
7 VII 7
  • 22,520 posts
Posted 07 January 2011 - 07:18 PM
Do it!
Thats very true, that what I would do.
#12 div4scpro
div4scpro
  • 18 posts
Posted 07 January 2011 - 07:33 PM
mine is a 97NA so there is no VVT, just looking for a way to precisely adjust timing after a cylinder head job and experiment a little with lowering the power band. Would be glad to field test or purchase one outright. Even with photos there are too many conflicting how to's on the web that I just don't trust. I think if people realized the need for more accuracy when doing this procedure they would appreciate a device like this? Even if you don't have a video do you have a good source for theory and advantages/disadvantage?
Andy
#13 the commissar!
the commissar!
  • 2,024 posts
  • Crew:ECC
Posted 07 January 2011 - 08:11 PM
PM sent, I think you would sell a heap in the neighborhood of that price point...
A video as suggested, would be cool too...It always makes people feel at ease about messing with something like that if they see someone else actually doing it...Removes some of the mystique though :P
#14 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 07 January 2011 - 08:20 PM
i would be in for one. i bought one from the group buy and it's nice but i would like a bit more precision. as to the VVT engines, what about a cam sprocket to use that head on the older, non-VVT, blocks?
1996 855R
#15 troyhyde
troyhyde
  • 974 posts
Posted 08 January 2011 - 04:16 PM
Hey Lucky, I'll take 2. I've been looking for a Quickbrick version for a while now and haven't had any success in talking anyone out of theirs.
Should be more accurate than my paper cutout....... (sad but true)
#16 socal850tuner
socal850tuner
  • 1,238 posts
  • Interests:cars....
  • Crew:SCC
Posted 08 January 2011 - 04:26 PM
If the price is $25 or less shipped to my door I'm in 100%.
'97 850 T5; K&N cone filter, IPD Sway Bars, Powerslot Slotted Discs, Strut Brace, IPD Poly upper engine mount, Voodoo mbc, MSD Blaster SS, Magnecor Spark plug Wires, Autometer Boost gauge on A-pillar, Pioneer Head unit, pioneer 5 1/4" up front and pioneer 6"x9" in the back, Rockford 450w amp, ~600 MTX 10" Sub, pioneer back door speakers, and 3.5"clarions in the dash
projects: Porsche 2.8 race, Porsche 2.0 race(complete), Porsche 3.2 street (complete), Porsche 3.4TT street(complete), Porsche 3.0 street (complete), Porsche 3L twin-plugged carbed street rocket(complete)
2K Motorsports
#17 fitsofrage99
fitsofrage99
  • 303 posts
Posted 08 January 2011 - 05:00 PM
been looking for 1...guess i missed the group buy...so you should do it!
95 850 GLT M
#18 thewhiteguy1
thewhiteguy1
  • 4,288 posts
  • Interests:Whiskey and Blondes seem to be my two current favorite things.
Posted 08 January 2011 - 06:31 PM
i'd buy one..
bloop bloop
#19 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
  • Interests:Volvo's, football, and finishing school.
Posted 08 January 2011 - 10:03 PM
me too. i like the price point.
1996 850 turbo wagon auto, Custome intake, MSD coil, IPD spark plug wires, Eibach springs, Bilstiens HD, Mesh grill, IPD strut tower bar,ultra racing 2 point rear strut bar, Tiki end-links,IPD intake manifold spacer, FCP silicone inter-cooler hoses, stoptech steel braided brake lines front and rear, completely rebuilt auto tranny, Complete stage zero. soon to have (white injectors, s70 front end, 16t, ARD tune)
#20 Serge
Serge
  • 10,667 posts
Posted 09 January 2011 - 01:28 AM
I'm in if the price point is good. Can't wait to see more on this!
Serge - 95 850 T5
