Does anyone know if the pump to windshield washer reseroir, isn't integral or built into the reservoir, or where exactly its located?
The pump is attached to the reservoir. Here is mine relocated.....
Posted 21 March 2012 - 06:35 PM
1998 S70T5M, 2000 Built B5244T2 RN Engine, K24 turbo, 550cc injectors, Turbo-Tuner, Coolingmist Progressive WMI, Precision FMIC, 311whp 363wtrq
Posted 21 March 2012 - 06:43 PM
Posted 21 March 2012 - 07:30 PM
30% increase, thats good to know, assuming my stock head can even do anything with that...I believe he did, somewhere around ~ 30% increase in flow over stock along each runner.
Here is a pick of mine installed, for "reference", but don't ask me too many questions, I didn't install it.
Only problem with re-locating the reservoir to the drivers side. You may have a charcoal canister on the drivers side that will be in the way. My S70's canister is in the rear. Maybe a smaller washer reservoir mounted somewhere else???
2012 Jaguar XFR - 510HP and 461TQ
2012 Acura TSX A-SPEC 6spd1996 Volvo 850 Platinum Edition SOLD!!! "R" Exhaust Manifold, Garrett Stage III 54 Trim T3/T4 Hybrid Turbo, 550cc @ 3bar Injectors, Racelab Intake Manifold, 3" Full SS Exhaust, TurboTuner, CAI, BOV, Custom FMIC Setup, Crane Ignition, 5spd Swap, Walbro Fuel Pump, KONI FSD & Eibach Springs, IPD Sway Bar Kit, IPD BBK, 384WHP & 363WTQ
Posted 25 March 2012 - 04:38 AM
Posted 25 March 2012 - 11:17 PM
Updates?
Posted 25 March 2012 - 11:30 PM
Posted 25 March 2012 - 11:37 PM
If your 20G dyno was 328whp, you're making me think I'm probably a lot closer to 350whp or above than I expected! Looking forward to seeing her finished. You're gonna like the top end steam that turbo has!
Posted 26 March 2012 - 01:00 AM
Posted 26 March 2012 - 01:03 AM
What are the compressor & turbine dimensions?
That wg hole looks like it will need some hogging out!
That's definitely going to be a step up!
On what basis? Are you also using TurboTuner? Gauging your hp on someone else's setup is unrealistic. Dyno yours, then you'll know what you actually have.....
Posted 26 March 2012 - 01:54 AM
Posted 26 March 2012 - 02:22 AM
You gotta remember one thing though, you get more drivetrain loss with the Aisin Warner..........
Not hating just putting that into your equation.
Posted 26 March 2012 - 03:10 AM
Does using Turbo Tuner automatically mean more power? Nope. Sure doesn't. Looks like you're making assumptions too!
Posted 26 March 2012 - 03:29 AM
No, but it would level the playing field in terms of your statement. I asked on that basis.
Being able to pull on certain cars hardly seems a concrete test. Too many variables. Sure a dyno sheet is just a piece of paper. It's also a quantifiable test of the vehicle, a baseline at the very least. 1/4 mile data obviously is also meaningful.
Posted 26 March 2012 - 04:04 AM
Posted 26 March 2012 - 04:14 AM
Posted 26 March 2012 - 04:16 AM
I am not disagreeing with you, but by your own admission your engine is very tired, as you have noted in another threads...If your 20G dyno was 328whp, you're making me think I'm probably a lot closer to 350whp or above than I expected! Looking forward to seeing her finished. You're gonna like the top end steam that turbo has!
I have no idea, and I don't have a caliper handy to take proper measurements. I know its a 60trim that has been reworked...What are the compressor & turbine dimensions?
The throttle cable came as part of the kit for the intake, I will take a picture of the packaging and update the thread...Got a quick question .What did you use for a custom Throttle cable ?
I got intake laying around too i might be time to install it.
Posted 26 March 2012 - 04:23 AM
Its fine to genarlize, but I hardly think a dyno is a generalization, for you to say you should be in the ball park of 350+whp is a prettly bold statement, given the lack of proof. and there are far and few in between that actually have 300WHP, let alone 350whp...
Just saying, not doubting what your saying but it seems you are just guessing. I know alot of people have guessed wrong.
there's no guessing with a dyno or a quarter mile run...
Posted 26 March 2012 - 05:55 AM
Posted 26 March 2012 - 09:09 PM
Posted 29 March 2012 - 03:52 PM
