Suspension Setup For A 96 855r
40 replies to this topic
#1 rmorse
rmorse
    GLT's aren't turbo,YO
  • 744 posts
  • Interests:SPEED! Snowboards, dirt bikes, volvos, crotch rockets....
Posted 03 February 2011 - 06:48 PM
As title reads, I'm looking into suspension options for my R. I plan on doing IPDs lowering springs, and then some good shocks. One question: how do I know if my brick has the self leveling shocks or not? If it doesn't, which shocks would you go for and why?
I've never bought performance shocks before, so any and all help will be greatly appreciated.
#2 MrLorence
MrLorence
  • 1,776 posts
  • Interests:Golf, Boobies, McDonald's, Skoal, Android Phones, Xbox, Cleaning, Diet Soda, Cars, Money...
Posted 03 February 2011 - 06:53 PM
Look at them and if they look like this:
Then you have them..
Shocks are all personal preference, but you want to try and get a HD Spring if you will be having large amounts of weight in the back..
1997 850 R
#3 rmorse
rmorse
  • 744 posts
Posted 03 February 2011 - 06:57 PM
Thanks for the fast reply. Is this something I can just glance at, or will I have to check it out next time I have it jacked up? I have never done rear suspension work before, only front...
#4 beewerks
beewerks
  • 421 posts
  • Interests:Beekeeping (family business), Computers and IT, photography and cycling.
    Wrenching on often broken Volvo's
Posted 03 February 2011 - 07:12 PM
You can usually see the shocks from behind the rear wheel looking up slightly. You shouldn't need to jack it up to see weather they are standard or self leveling models.
IMO the rear suspension is really easy to work on compared to the front.
I used Koni FSD shocks on my 850 and I was really happy with them.
'98 V70 AWD being converted to T5
'94 850 Wagon non-turbo--SOLD
#5 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 03 February 2011 - 11:12 PM
96 R's don't have Nivomat.
#6 r850glt
r850glt
  • 1,343 posts
  • Crew:ECC
Posted 04 February 2011 - 12:37 AM
Just got a 1996 855R and it has Nivomats, must have a special order ?
2000 Mercedes W210
1995 854 NA Auto
RIP - Dad - M.G.T 10/31/42 - 12/03/05 "Press On"
#7 blazen244
blazen244
  • 280 posts
Posted 04 February 2011 - 01:45 AM
Just my .02, I have the Bilstien Touring shocks in the rear along with Voght springs and they are great. In my trunk I have two 12"s two 10"s and three amps they still give a good ride firm when I need it and comfortable all the time. Also what crotch rocket do you have?
95' 850 T-5
09' Suzuki GSXR 1000
Caddy Escalade
#8 Darth R
Darth R
  • 536 posts
  • Interests:herz3mc autocrossing brewing beer raising chickens wrenching on turbo cars
Posted 04 February 2011 - 02:02 AM
My R had nivomats, infact it is on the original window sticker. Just buy the standard rear shock mounts from IPD and you are good to go. My buddy and I have identical 96 855-R he has the FSD and I have the tourings, his is much nicer all around, firm when you want and soft on the freeway. We both have ipd springs and sways.
1996 855R~ 287/304 at 18 psi~tuned by English Racing "BATLWGN"
2006 Evo 9 MR built for SCCA STU SOLO #13 #33 Sponsored by English Racing "BATLSDN"
2002 BMW Z3 M coupe "BATLCPE"
#9 c70pete
c70pete
  • 264 posts
Posted 10 February 2012 - 04:55 AM
I think with your "R" your stock springs should be ok.... I went with KONI FSD on my 98 c70 and stayed with stock springs... I had the IPD sway bar installed from before and the combination really gives you a ride that is comfy and handles really well in the corners... my goal was not to sacrifice comfort for a performance shock setup and the FSD + stock springs did just that... if you don't have the IPD sway bars you *must* get these... huge difference....
the FSD specifically helped bump steer and made the car feel more neutral... also in corners I was able to apply more power since the shocks have such high pressure they keep the wheels glued to the road...
I'm curious how low the IPD springs will make the car and if they are even a match for the FSD.... I think the R springs you have are already low and you should stick with them... just go for shocks and sways and you'll be smiling!
C70-T5A
Upsolute Level III
3" EST downpipe with race cat
2.5" (EST) Feritta Cat Back
K&N
#10 Deimos
Deimos
  • 605 posts
Posted 10 February 2012 - 05:10 AM
I adore my set up, ipd and bilstein. I mixed HD rears with touring fronts, 25/22 sways.
#11 bob850
bob850
  • 282 posts
Posted 10 February 2012 - 08:04 PM
I just had IPD sways and Koni FSD struts/shocks installed in my '96 turbo wagon (kept stock springs). I'm extremely happy with the setup. Softer over bumps, yet tighter around corners.
We have the same setup on my wife's '97 glt wagon. It rides even nicer due to the 15" wheels (as opposed to 16" on my car).
I've heard before that part of the reason the IPD sways ride better over bumps is due to the free floating bushings, as opposed to the bushings on the stock sway that are molded to the bar. Both our cars became better over bumps after the installation, but I'm not for sure which component did it, since the Koni FSD and IPD sways were installed at the same time.
1996 850 Turbo Wagon - approx 110K miles, IPD Stage 1 ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV, IPD HD CBV
1997 850 GLT Wagon (LPT) - approx 160K miles, Koni FSD, IPD sways & endlinks, SAS delete
#12 c70pete
c70pete
  • 264 posts
Posted 10 February 2012 - 08:18 PM
I agree! sticking to stock springs and adding IPD sway bar is the way to go...
I actually had IPD sways on my car way before installing the KONI FSD so I can tell you that it's not the sway bar that improves your ride... it's definitely the FSD. The ride on stock shocks with stock sway bar was the same as when I installed IPD sway bars... corner and stability improved... the IPD sway bars did not degrade the ride one bit.
when I installed FSD's.. the ride became much more controlled... harsh bumps are handled in a "rubbery" quick bounce and much less is transmitted to the cabin... potholes that would peviously destroy your front end are still felt with impact... but muffled and controlled and without the explo$ive crash that the stock shocks displayed.
Going FSD shocks and stock springs will better preserve your front end suspension components because the FSD's really do soak up a lot of the harshness out there... so you know they are doing their job!
C70-T5A
Upsolute Level III
K&N
#13 bob850
bob850
  • 282 posts
Posted 10 February 2012 - 08:23 PM
I agree with the "rubbery quick bounce" description for the FSD. Good way of describing it. You still feel the bumps, but they are less harsh.
#14 c70pete
c70pete
  • 264 posts
Posted 10 February 2012 - 08:36 PM
+1 much less harsh... controlled and muffled.... what I really like is the power delivery around corners and how the tires now stay planted.... definitely a function of FSDs...
I'm on michlien pilot alpin snow tires right now...can't wait until summer comes round so I can install some Pilot Super Sport... that should really be amazing with this setup...
C70-T5A
Upsolute Level III
K&N
#15 Jardim
  • 1,276 posts
  • Interests:Being a Volvo Rat. Eating, drinking water, sleeping, working, etc.
Posted 10 February 2012 - 08:55 PM
How is the handling on FSD's?
Do they go from "comfort" to "sport" depending on the situation?
94 854 T5M----------------Volvo Rat
#16 c70pete
c70pete
  • 264 posts
Posted 10 February 2012 - 09:15 PM
combined with IPD Sway bars (which are a *must* in my opinion) the FSD's make a for a great handling car without killing you over bumps and road irregularities....
they firm up the corners when you really push the car... and control body movements under hard braking and acceleration...
if your trying to build more of a "track" car that will see 50% track time and 50% street time you should go with KONI YELLOW + lowering springs - this is the better track setup but you will lose much comfort on the street...
the setup I have is definitely trackable but it's not adjustable... its comfy and performs well... just the way I wanted it....
C70-T5A
Upsolute Level III
K&N
#17 Jardim
  • 1,276 posts
Posted 11 February 2012 - 07:52 AM
Im debating between these, the yellows or the new strt (street) shock with either eibach's or ipd's im not sure.
#18 c70pete
c70pete
  • 264 posts
Posted 11 February 2012 - 03:43 PM
The FSD won't work that well with the eibach pro spring kit... they are not properly matched and the FSD were designed for stock springs...
the yellows or new street shock from koni (non adjustable) is better suited to the eibachs or IPDs
I would contact both IPD and Koni and see what they have to say...
do you value ride comfort?
C70-T5A
Upsolute Level III
K&N
#19 Jardim
  • 1,276 posts
Posted 12 February 2012 - 11:18 PM
Not really, i live for this stuff.
#20 c70pete
c70pete
  • 264 posts
Posted 12 February 2012 - 11:49 PM
then go KONI yellow and a good lowering spring... you should also do IPD sway bars and IPD Heavy Duty endlinks together... they will definitely add to the fund factor...
I would do the IPD sways and endlinks first just so you can appreciate the effect.
C70-T5A
Upsolute Level III
K&N
