Seen This Manifold Style Before?
11 replies to this topic
#1 Jonathan Johansson
Jonathan Johansson
  • 152 posts
Posted 06 March 2011 - 10:37 AM
Anyone seen this manifold style before?
Attached File  manifold.jpg   53.94K   273 downloads
#2 ozzimark
ozzimark
  • 4,387 posts
Posted 06 March 2011 - 12:55 PM
Diesel?
#3 WayAway
WayAway
  • 1,308 posts
Posted 06 March 2011 - 01:46 PM
Looks like it flows pretty well
96 854R Black IPDStage III, Winter (M56, 99T5 motor, 18T) 19psi, Whites, OBX, Eibach springs, SSQV, Exhaust Cutout, Aem UGO, 17" Peggs etc..
87 Nissian Hard Body with a sweet clutch
98 V70R Saffon AWD, Fresh 18T, RICA Stg II, Porsche BBK Sconeman intake pipe, Mufflers Delete,IPD springs, CX Racing FMIC, Hillman MBC @ 18psi, VR Charcoal Swap, Cai, HKS SSQV, Projectors, 18" Peggs, XC90 Wood steering wheel, Front Lip, Full A/C Delete, Slow and Heavy
#4 lookforjoe
lookforjoe
  • 9,785 posts
Posted 06 March 2011 - 02:23 PM
looks pretty bad, the way they collide. At least ours make some effort to progressively feed into the collector.
#5 info2x
info2x
  • 1,056 posts
Posted 06 March 2011 - 09:46 PM
Maybe I'm just tired but it looks like they have heat shields over the runners?
1997 Volvo 855 T-5 The Silver Bullet 2
1994 Volvo 855 The Chiseled Brick
1985 Volvo 245DL The Silver Bullet
#6 Wagoneer855
Wagoneer855
  • 3,186 posts
Posted 07 March 2011 - 05:45 AM
Comments like this make me LOL
'97 855 - Build in progress
#7 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,594 posts
Posted 07 March 2011 - 06:44 AM
Maybe, i am tired but it does look very similar to ours, NO. the only real difference that i see is the separation in the mouth is more pronounced in ours. Is this from a diesel?
and the runners look bigger and more round to the eye. this has to be a diesel.
1996 850 turbo wagon auto, Custome intake, MSD coil, IPD spark plug wires, Eibach springs, Bilstiens HD, Mesh grill, IPD strut tower bar,ultra racing 2 point rear strut bar, Tiki end-links,IPD intake manifold spacer, FCP silicone inter-cooler hoses, stoptech steel braided brake lines front and rear, completely rebuilt auto tranny, Complete stage zero. soon to have (white injectors, s70 front end, 16t, ARD tune)
#8 bergmjs
bergmjs
  • 2,060 posts
Posted 08 March 2011 - 01:28 AM
Biggest difference is that the runners are introduced to each other at 90 degree angles, no smooth transitions. This results in a lot of collisions of the pulses which then results in turbulent flow and very little to no laminar flow, high Re#, etc, etc.
'95 854 T5M 195k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue - DEAD - To be parted out
'04 S60R - 125k
#9 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,594 posts
Posted 08 March 2011 - 02:41 AM
oh ok thanks for the info.
#10 Wagoneer855
Wagoneer855
  • 3,186 posts
Posted 08 March 2011 - 03:44 AM
Oh come on, I can't LOL without getting a -1?
#11 WayAway
WayAway
  • 1,308 posts
Posted 16 March 2011 - 01:37 PM
Maybe I should of looked at it in more detail before i said that.....
#12 Oreo931
  • 24,498 posts
Posted 16 March 2011 - 01:41 PM
LOL looks like an R manifold on steroids
(obviously not referring to flow, but to runner thickness)
