Aftermarket Stereo Install
11 replies to this topic
#1 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 15 March 2011 - 09:58 PM
So I am trying to switch out my aftermarket kenwood stereo from my 93 850 to my 97 850r. I plugged it into my 850R and no sound. Stereo turns on, antenna functions, no sound whatsoever. After doing some searches, i found that there is(perhaps was) an amp that came with the 97, seeming to be the only difference between the 93 and 97R. The stock radio produces sound, the kenwood does not, but seems to function properly(scans/seeks correct stations, volume up works fine etc) There is a chance that the amp was removed from the car(if anyone has a picture of it installed, that would help alot in locating it). I did the heater core job a few weeks ago and there was a bracket attached to the core housing unit that seemed out of place, like it was there to get in the way of my heater core install.
The harness is wired up properly(at least for the 93) and the stock HU works without the amp plugged in. Am i missing something? Do i need to disconnect the battery to reset something?
tl;dr Aftermarket stereo worked in earlier 850, doesn't in 97R..powers on no sound. No amp connector found, problem?
1993 Volvo 850 GLT 193,000mi
Back on the road Retired.
1997 850R 107,000
#2 rmorse
rmorse
    GLT's aren't turbo,YO
  • 744 posts
  • Interests:SPEED! Snowboards, dirt bikes, volvos, crotch rockets....
Posted 16 March 2011 - 01:56 AM
No picture, but the amp is located right in front of the heater core. If you remove the panels for the heater core, you will see it. If you see the heater core shroud and don't see the amp, you don't have an amp.
#3 BEJinFBK
BEJinFBK
  • 1,760 posts
  • Gender:Not Telling
  • Interests:Lottsa stuff!
    The world is a big place...
Posted 16 March 2011 - 04:48 AM
Check BOTH power leads from the car - Constant and switched.
This sounds a lot like the constant lead has no power.
Kinda weird if the stock deck works, though...
STILL - check power.
If you still have a fail with the KW, get a pair of speakers
and a 12 volt power source and bench test that sucker.
As for the amp question. If you plug a round, 6 pin DIN
connector into the stock radio hole marked "AMP" and
you get sound, and the sound goes away when you
unplug it? You have one.
#4 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 16 March 2011 - 06:08 PM
I don't think I have an amp at all. I was reaching inside the hole left by the radio and found nothing. There is a CD changer wire though(no cd changer). I reinstalled the stock HU yesterday and it worked, sound and all.
I SHOULD get sound from the stereo without an amp though right? Is it an unnecessary component? I Don't have to disconnect the battery or anything when installing it right? There is no anti-theft feature that would prevent it from working, The code for the stock HU is tied to the unit itself right..not the ECU or anything?
Seems like it should just plug in and play.
1997 850R 107,000
#5 Black Betty
Black Betty
  • 6,987 posts
Posted 17 March 2011 - 04:12 AM
Your 850R should have an amp that powers the speakers you'll have to adapt the 6 pin connector to 4 RCA outputs for your new stereo. I made my own in my 850R. You could also get a small amp to run your speakers too.
#6 Tyler T5R
Tyler T5R
  • 190 posts
  • Interests:Mountain biking, road biking, music, "restoring" (fixing) my Volvos
Posted 17 March 2011 - 12:44 PM
Or you can bypass the factory amp wiring and use the kenwood to power the speakers. Easier than it sounds and it might sound better (does for me). There is an extra harness that goes to the factory amp. Take that out and plug the kenwood wiring harness (wired to correct wiring harness, a la Crutchfield etc) into the cars connectors. Contact me if you need help. Don't want to type more on iPhone now.
1998 V70R, 203k, black: EST duals, IPD sways+HDlinks, 302 brakes, ss lines+AteSB, ABMs+4200HID, K&N filter, Propus Cs, Eclipse DVD/nav AND 1991 740 Turbo wagon, mystery mileage, red: stock utility beater with crazy sound system. Sold: 1995 T-5R sedan
#7 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 20 June 2011 - 09:39 PM
Ok first a correction. I used to have a kenwood, but this thread is actually about an alpine.I have an 850 GLT where my stereo(s) previously worked. The kenwood was stolen out of my GLT and with it some harnesses and wires. I had to go to a junkyard and reach deep inside another volvo to get the wide black harness, and then attached the aftermarket wiring harness to the replacement alpine and everything worked perfectly. So now i'm trying to put the alpine in the 97 850R that definitely HAD a stock amp, but is not there anymore(checked when replacing my heater core).
I took some pictures the wiring that is currently in my 850R. http://imgur.com/a/CK9G4. It plugs into the wiring harness that from the 93 850 where it used to work, powers up, antenna functions, but there is no sound. Now that i have pictures, does anyone have any idea of whats wrong?
1997 850R 107,000
#8 chevyb
chevyb
  • 66 posts
Posted 25 June 2011 - 02:32 AM
what i did with mine...the factory plugs that go into stock radio follow those in farther they plug into another set (mine was wrapped in foam)unplug that and then plug your new harness into there this bypassed factory amp and everything works in mine
91 240-IPD front and rear swaybars, panhard bar, torque arms billy hd's on all four lowering springs w/ a sbc 350 v8 autometer dash guages gt grant wheel and more to come
96 VOLVO 850R-soon to get some stuff for it and a 92 chevy silverado and a 2010 elantra
#9 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 26 June 2011 - 01:46 AM
Not sure why my pictures didn't show up
This is the plug that I think your talking about, what i'd be plugging directly into. Something is missing I just can't tell what. http://imgur.com/UorUd
A closer look at the wires http://imgur.com/scpLj
1997 850R 107,000
#10 chevyb
chevyb
  • 66 posts
Posted 26 June 2011 - 02:18 AM
here is what come out of stock radio
here is what you want...plugs from radio plug into these
#11 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 15 July 2011 - 03:38 PM
Well, problem solved, and it seems as if it was a unique problem. At some point, someone must have reinstalled the rear drivers side speaker incorrectly. The two wires on the speaker had crossed, got completely squished down, and was right up against the stud that holds the speaker in place. So in other words, the stereo was installed correctly but the alpine deck had some sort of protection where it wouldn't pump out sound to any speaker.
1997 850R 107,000
#12 chevyb
chevyb
  • 66 posts
Posted 16 July 2011 - 03:11 PM
glad to hear you have it all worked out now
