V70 Tcv Fitted To 1997 850 T5 Problem
Posted 16 March 2011 - 05:25 PM
I did a full stage 0 before fitting the TCV went from NGK plugs to Bosch Irridium ones with the fine point electrode
I know several other 850 owners who have the same TCV with no overboost problems seems really odd I should get serious overboost
Suggestions please
Edit the boost was fine for two weeks with the new TCV I have replaced all the pipes going to the Turbocharger
Yellow to Wastegate
Blue to air hose
Red to Compressor
I've lifted off the wastegate arm to see if its jammed the wastegate mechanism will check tomorrow when the engine is fully cold
Posted 16 March 2011 - 06:15 PM
Edit: OEM's GREATLY outlast coppers, it's your call. Some people don't mind changing spark plugs every other oil change. Personally I prefer to only change mine once every ~40K miles. That being said I likes the Genuine plugs.
Edited by --Aaron--, 16 March 2011 - 06:16 PM.
Posted 16 March 2011 - 06:24 PM
I have changed all the vacuum hoses on the T/C and added new pipe clips throughout. One thing I have found was the waste gate vacuum unit was jammed solid so I've disconnected that to see if it can free itself off over night and tomorrow morning I'll see if I can move the vacuum arm
Posted 16 March 2011 - 06:26 PM
Posted 16 March 2011 - 06:33 PM
I'm interested in why you believe the irridium plugs are a problem considering Bosch are the recommended ones over NGK? Or at least they are in the UK for late 850 T5's. I swapped to the V70 TCV as it was the only thing I could get one the I needed a replacement as my 850 round one had fallen appart and wasn't working also several other UK owners have the same unit without any issues
If you search the term spark plugs you'll find out why I'm saying Coppers/OEM only. Did you put up a wanted ad here? I'm not saying the V70 TCV is going to cause these issues but if it were meant for the car it would be listed in the computers for 850's and x70's.
You have a problem, you have a variable that doesn't belong. I would start by putting in the correct BCS.
The plugs will probably serve you alright for a little while but then you'll start having idle hiccups, random unexplainable misfires, etc.
Posted 16 March 2011 - 06:44 PM
Yes I did put a wanted ad up for some oversized pistons +0.50mm as I can only obtain +0.40mm and my engine rebuilder has suggested that the block needs a 0.36mm rebore [it's a for an engine upgrade I'm planning later in the year as my current engine has 270.000miles on it and rising
Posted 16 March 2011 - 07:16 PM
Posted 16 March 2011 - 08:41 PM
Posted 16 March 2011 - 09:24 PM
You'll get timing pull and reduced performance if you try and trick the turbo into working harder...
Posted 16 March 2011 - 09:26 PM
The MBC is no longer being used as it fell to bits. I'm using a Rica based map. Theres a list which shows the TCV's? or BCS's never knew that see how far out of the modification game we are here in the UK the part number was checked for a 97-98 V70
What MBC? I'm confoosed. Your BCS is round. Is the part you bought round or more rectangular?
What do pistons have to do with your issue?
I cannot find any information regarding not using Bosch Iridium plugs in favour of Platinum/Silver or Copper can you point me to where this list is
Go through a few pages of these threads in regards to the plugs: http://www.google.co...=volvospeed.com
0.028inch would be around 0.70mm ish ? here in the UK it's getting harder to locate imperial feeler gauges everything is metric
http://www.google.com/search?q=.028+inch+to+mm&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Posted 16 March 2011 - 09:35 PM
Here is my experience.
And make sure the wastegate arm is set correctly.
Here is IPD's how-to video.
Posted 16 March 2011 - 09:41 PM
Pistons are something totally different I answered the question regarding putting a wanted post which was for pistons.
The MBC reference was from what appears to be a glitch in one of the replies, that has gone as has the reference to gapping the plugs to 0.028inch odd but not essential, It's also listed in my signature which I haven't amended yet.
The wastegate has been adjusted to the 3 turn adjustment it will be put back to stock in the morning.
#14
Posted 16 March 2011 - 09:50 PM
One very interesting article claiming that the Haynes is showing an incorrect way to fit the HT leads but again nothing to claim iridium plugs aren't good, very expensive yes [£39 a set of 5 against £16 for NGK's]
Will keep scanning through to see where the justification is got from though.
#15
Posted 16 March 2011 - 11:17 PM
#16
Posted 16 March 2011 - 11:36 PM
I've had my coppers in for 25k so far, no misfires yet with a starting gap of 0.032" and the stock coil system on an engine that hits 6k a couple times a day.Your vacuum lines are correct. Your plugs are an issue, Coppers or OEM only. Start off with the gap at .028. Why did you use a V70 TCV? IIRC the ports inside are different diameters so that is probably throwing something off.
#17
Posted 22 March 2011 - 11:51 AM
