Turbobricks
Posted 22 March 2011 - 04:50 PM
Volvospeed On Google+
Posted 22 March 2011 - 06:28 PM
Did his server go kapput and he jumped ship, or was this a planned move? Either way its funny, just different funnies.
86 Kawasaki Gpz900R Ninja
Posted 22 March 2011 - 06:41 PM
Not sure. There are lots of upgrades I do not post and just do, because I do not want to hear the complaining. With that said all Volvspeed affaliated sites will be down ~15 minutes on the 30th.
Posted 22 March 2011 - 07:46 PM
#6 Guest_Dana_*
Posted 23 March 2011 - 11:41 PM
Yeah we were severely over utilizing our server apparently... the one we just upgraded to back in Nov. lol More upgrades and moves - i guess thats a good sign though. Glad to have you guys around to fall back on for the addicts (even if they can be a pita).
-Dana
Posted 23 March 2011 - 11:50 PM
-Dana
You sure you do not have a config issue? I thought you were on a dedicated box. I have run forums with 500+ apache calls a second on very basic servers. Think dual 2 ghz processors and 4-8 gigs ram. So call it 4000-5000 users per hour with no issues. You seeing I/O errors or what? Are everyone of your members pressing search on the count of 3?
#8 Guest_Dana_*
Posted 24 March 2011 - 12:14 AM
Che, on 23 March 2011 - 11:50 PM, said:
Nah, we were still on a VPS actually - just on the biggest setup they've got before going with a separate database server or full dedicated. Our "slice" was something like 1 CPU and a couple gigs of ram which was handling the load perfectly fine up until this month - and i havent seen any major jump in utilization. Im still not entirely sure we've fixed the problem since i find it unbelievable that we out grew a server that fast and our loads are not that big in actuality. We shall see.
#9 Guest_Dana_*
Posted 24 March 2011 - 12:17 AM
Posted 24 March 2011 - 01:28 AM
Dana, on 24 March 2011 - 12:17 AM, said:
Are all the tables using indexing? Temp tables HEAP? Any locked tables? Whats the connection to the sql server? 1000T? On that set up ignoring I/O errors you should be able to handle 500-1000 online at a time no problem. If it truely is a processor issue ever consider litespeed over apache? Cache the files, minify java, and you should be good to go.
#11 Guest_Dana_*
Posted 24 March 2011 - 01:51 AM
Che, on 24 March 2011 - 01:28 AM, said:
indexing - im pretty sure, HEAP = yeah, I'll have to check the rest when i get home from work. I dont think its a processor issue per se but im not sure what made them see that it was a load problem. Never tried litespeed, but then again i've never really seen anything wrong with apache, just mysql. I'll shoot you an email when i get home and can pull some info from the server and see what you think. thanks again.
Posted 24 March 2011 - 03:59 AM
#14
Posted 25 March 2011 - 08:09 PM
PyROTech, on 25 March 2011 - 08:05 PM, said:
With an upgraded NIC and RAID card yes. For sites the size of VS/TBs you need about 2 gigs ram, and 2 2ghz cores.
#15
Posted 25 March 2011 - 08:48 PM
Che, on 25 March 2011 - 08:09 PM, said:
so the onboard mobo ethernet ports wont do? and the cpu specs need to be that? you couldnt run it on an old i7 920?
