Drop Bolts
24 replies to this topic
#1 Organs016
Organs016
  • 15 posts
  • Interests:I enjoy working on my Volvo and playing sports. Even so Volvos are difficult to work on its something I just love about these cars.
Posted 24 March 2011 - 07:57 PM
My friend is going to install the drop bolts for me but he doesn't have a clue how to do it. Can someone please send me directions on how this is done. I'm going to purchase them shortly but this is the only thing holding me up. I have a 1999 Volvo v70xc. Thanks
#2 s_moneh
s_moneh
  • 1,166 posts
Posted 24 March 2011 - 07:59 PM
wth is a drop bolt?? what r u trying to do?
#3 2.3 l turbo
2.3 l turbo
  • 48 posts
  • Interests:everything
Posted 24 March 2011 - 08:58 PM
still waiting on response!! i am curious
#4 Fake-R
Fake-R
    Rarest Member Ever
  • 2,170 posts
  • Interests:Pushing envelopes.
Posted 24 March 2011 - 09:00 PM
A drop bolt setup is used on the 870 based cars that use Nivomats. It allows you to lower the rear of the car.
-1996 850 Turbo
-2007 XC90 V8
#5 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,809 posts
Posted 24 March 2011 - 09:17 PM
 There's nothing to it really.  You remove the bolts on the lower mounts of the nivos and install the new.  Keep the spacers between the shock and lower mount.  The net effect is that you are lowering the lower mount of the shock.  It should make sense once you look under there.  You'll probably want a jack underneath the shock because it is load bearing and hard to compress.  I don't recall anything else special about the job.
99 V70R
98 V70 GLT
#6 WayAway
WayAway
  • 1,174 posts
  • Interests:Bewst, Beer, Women, Towers
Posted 24 March 2011 - 10:58 PM
Pm'ed you with instructions! If you need anything else just ask :)
96 854R Black IPDStage III, Winter (M56, 99T5 motor, 18T) 19psi, Whites, OBX, Eibach springs, SSQV, Exhaust Cutout, Aem UGO, 17" Peggs etc...
98 V70R Saffon AWD, RICA 18psi tune, Sconeman intake pipe, Mufflers Delete,IPD springs, CX Racing FMIC, Hillman MBC @ 18psi, VR Charcoal Swap, Cai, HKS SSQV, Projectors, 18" Peggs
#7 Snabb T5M
Snabb T5M
  • 10,331 posts
  • Interests:IU BASKETBALL; 1969 Roadrunners; Drag racing; rugby; traveling the world
Posted 24 March 2011 - 11:44 PM
Funny we just did this with lucas' V70R this past weekend. Went to Ace Hardware, bought some stainless extended bolts, some spacer nuts, and the car was dropped 1.5" in the rear.
Lee 1998 S70 T5M; 113K+ miles; IPD Stage III ECU; 18T turbo @18.5psi; Precision FMIC; R manifold; EST 3" DP; balanced crank with LGSpeed rods; 3 angle valve job; SPEC III clutch; ALL of Sconeman's T5M parts; KW2 coilovers; TurboSmart Eboost2 EBC ---13.605 @ 105.39 mph ---
#8 Jack8745
Jack8745
  • 1,128 posts
  • Interests:not facebook
Posted 25 March 2011 - 03:11 AM
does anyone have the know how on how to do this on a 97 854
K.I.S.S. - Keep It Simple Stupid
'97 854 GLT | 16T | ARD Green | OBX full exhaust | R Mani | NA TB | Unorthodox Racing Underdrive Pulley | etc...
#9 T5power
T5power
  • 4,773 posts
  • Interests:Underwater Basketweaving
Posted 25 March 2011 - 03:16 AM
:lol: :lol:
you dont need drop bolts. you can just toss in a set of lowering springs and be good to go. R wagons and AWD had nivomat suspension. sedans didn't have those.
///T5
#10 Jack8745
Jack8745
  • 1,128 posts
Posted 25 March 2011 - 03:20 AM
View PostT5power, on 25 March 2011 - 03:16 AM, said:
:lol: :lol:
"heheheh" i has eibach
#11 Ipd
Ipd
    Mr. IPD
  • Validating
  • 1,562 posts
  • Gender:Not Telling
Posted 25 March 2011 - 03:24 PM
For those with Nivomat rear setups that want drop bolts, you can PM me I've got some kits I made up with stainless spacers and extended bolts for lowering from 1/2" to 2"
No, I don't have instructions :lol: sorry
#12 Korruption
Korruption
  • 1,835 posts
Posted 25 March 2011 - 08:51 PM
Lee is correct. There are two bolts... M10 I believe... that mount the lower portion of the nivomat to the lower control arm. Here's what you need to do. The tops of the bolts are held together with a thin metal bracket that also connects to some lines (it's not needed)
Lift rear of the vehicle and support on jack stands or put car on a lift.
Remove rear wheels (you don't have to, but it makes things easier to get to IMO)
Remove nuts from bolts. Remove nut from other side of bracket holding the bracket to lines.
You will then need to compress the rear suspension with the nivomat disconnected
Once you have the appropriate space between the nivomat and the lower control arm, put the spacers between them.
Install new bolts ... enjoy lowered car.
Personally, I very much like the ride with the drop bolts. I know many do not like it, but what the hell... car handles way way better IMO.
Good luck!!
1991 244 NA - M47
#13 EVL WAGN
EVL WAGN
    Old Man Crew Trailer Park Supervisor
  • 4,505 posts
  • Interests:Golf, Hockey, and Snowboarding!
Posted 25 March 2011 - 09:13 PM
Good luck!!
That's that really matters in the long run dude...it's your car after all. With the headaches I've dealt with in regards to my Intrax set-up...I probably should have just done this too...lol
Now I just have to convert to full air ride and I'll be in a complete state of bliss!!!
Amish Approved!!!
#14 Korruption
Korruption
  • 1,835 posts
Posted 25 March 2011 - 09:37 PM
I'll take your intrax headache if you go air-ride. Drop bolts are too easy... I am used to mods being much more complex. :lol:
FWIW, here is my car after installing 1.75" drop bolts in the rear. It only yielded a 1.25-1.5 drop, though. I'd suggest going a full 2", as I will in probable near future.
1991 244 NA - M47
#15 EVL WAGN
EVL WAGN
  • 4,505 posts
Posted 26 March 2011 - 05:34 AM
I shall keep that in mind bro...I will let them go for a decent price too.
Amish Approved!!!
#16 johnloves850's
johnloves850's
  • 2,439 posts
Posted 26 March 2011 - 07:11 AM
You two bring teh lulz.
1993 960 wagon. Most awesome car evar.
#17 wezo00
wezo00
  • 1 posts
Posted 28 September 2011 - 03:03 AM
Good luck!!
I installed nivomats on my '05 V70 AWD and that mods raised the rear suspension for 1". Drop bolts seams to be the only way to lower it back! But I didn't find anyone who did it on a P2.
Could it be the same as on -'00 V70? (parts and installation)
Where can I find these bolts for my car? (I guess 2" long would be fine)
How does it change the handling of the car? (i.e. Bad sides of the drop bolts)
Thanks in advance.
2005 V70 2.5T AWD Powered by RICA Stage2+
www.clubvolvoquebec.com
#18 WayAway
WayAway
  • 1,174 posts
Posted 01 October 2011 - 12:16 AM
100% cosmetic my friend. Get under the car and look lol
#19 Chilled Man
Chilled Man
    MILFSPEED
  • 30,087 posts
Posted 01 October 2011 - 01:15 AM
Thanks in advance.
Completely different . You cant put bolts in the P2
What you want is S60 AWD Springs for your car If they offer that car with the nimovats
I have done this on my 01 XC and going to do it on the wifes 04 XC also.
#20 Ashes
Ashes
  • 1 posts
Posted 04 October 2011 - 02:53 AM
Hey guys, first Post. Near stock 2000 v70xc. All the AWD Volvo's I've seen here using the drop bolts are 98-99, I'd assume they also work on the 2000 v70xc's, since it's a P1, but you never know with year to year revisions. I'd PM "IPD", since he was selling them, but he hasn't posted since may. Had the car for 4 years, this cure for the truck ride height will really help get the ball rolling for me.
