Significant Oil Leak Passenger Side
23 replies to this topic
#1 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 05 April 2011 - 08:39 PM
I'm losing a good amount of oil from the front(passenger side) of my engine. When parked,it looks like it is trickling down the frame and dripping at a spot between the tire and the passenger door. It seems as if a lot of it is concentrated below the timing belt/oil tstat area. It seems to be worse when the car is on(drops of oil all over my street), but continues when off. It has gotten oil all over the passenger side of my car(control arm, wheels) My initial hunch was the oil cooler bracket thing, lots of oil in and around that area, but its hard to tell...That or a cam seal. I'm thinking it is on the front of the engine because of how concentrated the oil is over there. No real smell of burning through vents or anything like that. I'm going to my carwash soon to wash it off and hopefully get a better clue. What other areas can leak alot of oil over there?
http://imgur.com/a/XOpXA
1993 Volvo 850 GLT 193,000mi
Back on the road Retired.
1997 850R 107,000
#2 phunktified
phunktified
  • 349 posts
Posted 05 April 2011 - 08:43 PM
I would pull the outer timing belt cover (just one bolt) so you can have a better look at the front of the engine with a flashlight..
Former: 89 744 GLE 16V, 90 745 GLE 16V, 95 964, 94 854 Turbo, 01 S40 1.9T, 99 C70 HPT, 01 S60 T5, 07 VW GTI
Current: 98 V70 GLT, 97 854 GLT
#3 atefitty
atefitty
    Manuals tighten my pants
  • 430 posts
Posted 05 April 2011 - 09:16 PM
If your oil cooler lines are wet then they are leaking.
The only other area I've seen that can leak a ton is the turbo drain tube seal and rear main seal.
1997 850R
IPD Strut Brace, IPD Boost Guage, EST Intake, TME Catback Exhaust, Bilstein Struts/Shocks, TME Lowering Springs, Wastegate adjust to 6psi, European Side Markers...just new, black jewels and ECU upgrade....next : finally a downpipe!
#4 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 05 April 2011 - 10:00 PM
The rear main seal wouldn't spray exclusively onto the other side of the engine though right? I had a bad RMS that made me get rid of my otherwise good GLT, but the leak was exclusively on the drivers side, where as this is exclusively on the passenger side. The weather has been bad around here lately so I couldn't give it a thorough check. I'm really hoping its not the RMS.
I checked under the timing belt a few weeks ago but i was looking at the condition of the belt and not checking to well for oil, but it wasn't soak. I'll give it another look tomorrow when its a not raining. For now i'm going to do my best to degrease my car.
1997 850R 107,000
#5 Zappo
Zappo
    The One Upper
  • 15,528 posts
Posted 05 April 2011 - 10:19 PM
I would say oil cooler lines are a good guess, but it could be other things.
When was the last time you replaced them?
#6 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 06 April 2011 - 12:11 AM
Just got the car a few months back, so never. I'll have a better idea tomorrow as to whats going on, I'll try to get some good pictures too
1997 850R 107,000
#7 AverageVolvo
AverageVolvo
  • 1,634 posts
  • Interests:Woman,Cars,Guns, Sex, Music.
    And making $$$ to fund the above.
Posted 06 April 2011 - 06:22 AM
Degrease it first.
Most likely the oil cooler lines as suggested, could also likely be the Oil thermostat housing or the lower front seal or Oil Pump/gasket/ Seal, I have seen quite a few of these sneaky lil bastard.
96 850 (412) wagon W/2 racing seats no rear seats, ..Converted to M56h with Quaife. R clutch,Kw v2 coilovers, qbm end links,Ipd sways,strut and shock braces/ Front/rear lower Ultra racing chassis braces. Team Dynamic 17in rims 17lbs .Poly mounts on trans, engine and firewall.Porsche Bbk, Ss lines, Super Blue Ate.5mm Spacers,Rolled Fenders,R Manifold, T04E 50 trim @18psi. Divorced WG and BOV ,3in Downpipe, gutted 3in cat,2.5 tme/Ipd catback Gizzmo Ebc, 1 gallon Aem progressive Meth Injection kit. Walbro 255. Na mani W /960 plate and Na Silicone Tb hose. Boost/egr/wideband gauges dash mounted. Double Din touchscreen Nav. 12in Fosgate p3 and 2 Alpine amps/ + Cf spoiler+ V70 stuff.
#8 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 06 April 2011 - 06:10 PM
View PostAverageVolvo, on 06 April 2011 - 06:22 AM, said:
Degrease it first.
^^^This!
I had one in the shop last week just like it...
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted ImagePosted Image
#9 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 07 April 2011 - 07:44 PM
I'm thinking it might be the exhaust cam seal after giving a better look under the timing belt cover today. The back timing belt cover had some oil running down the side of it, on the exhaust cam side, especially towards the bottom. I tried to get a look at the seal itself through the holes and it appeared to have some oil coming out of it. I figure i might as well do the timing belt job since its been a while. Could cam seals be the source of a significant oil leak?
http://imgur.com/2YdR3 General view under timing belt cover
http://imgur.com/PnENk View through a hole in the rear cam timing gear.
1997 850R 107,000
#10 cn90
cn90
  • 1,339 posts
Posted 08 April 2011 - 02:14 PM
I have the exact same leak.
I am thinking EXHAUST Cam seal.
I am doing the whole thing in the Timing Belt area this summer (from a to z) and will post a DIY later.
1998 V70 Non-Turbo 100K miles
#11 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 08 April 2011 - 04:24 PM
How much oil are you losing? I'm losing a lot, making me think its more than one thing, but i will replace it and find out.
1997 850R 107,000
#12 cn90
cn90
  • 1,339 posts
Posted 08 April 2011 - 04:42 PM
I am losing 10 drops a day.
If you lose alot, check CCV system.
#13 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 22 April 2011 - 11:21 PM
The leak has gotten worse and it seems like i'm losing a lot out of the oil thermostat housing, so maybe thats where its been all along. Does anyone know the size of the o-rings and if i can get them at pepboys or something?
1997 850R 107,000
#14 scumcity14
scumcity14
  • 2,644 posts
Posted 22 April 2011 - 11:33 PM
Could be not just one, but some or all of the above...most of mine were leaking. I had the engine out and replaced everything. clean first and go for a drive and see what's dripping..
'98 s70. has over 62 zip-ties
'05 xc/90. The stereo sucks.
#15 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
  • Interests:Volvo's, football, and finishing school.
Posted 23 April 2011 - 09:22 AM
This might sound stupid but heck the oil filter. I thought i had a major problem but when i went to take a closer look it was a loose oil filter. It dripped a lot when running and dripped for a little while when turned off then stopped sounds like your problem.
1996 850 turbo wagon auto, Custome intake, MSD coil, IPD spark plug wires, Eibach springs, Bilstiens HD, Mesh grill, IPD strut tower bar,ultra racing 2 point rear strut bar, Tiki end-links,IPD intake manifold spacer, FCP silicone inter-cooler hoses, stoptech steel braided brake lines front and rear, completely rebuilt auto tranny, Complete stage zero. soon to have (white injectors, s70 front end, 16t, ARD tune)
#16 850_GLT_owner
850_GLT_owner
  • 201 posts
Posted 23 April 2011 - 05:22 PM
I can actually see the oil dripping from the oil Tstat housing,only when running. I was thinking it might be more things than just that but there is enough oil leaking from the thermostat housing that would account for all the oil i've been losing, like a drip a second or two.
**don't know how to edit**
Wanted to add that i tried hand tightening the oil filter and its not moving at all. It seems like its coming from that area but i'm pretty sure its the oring going into the Tstat
1997 850R 107,000
#17 jdlc
jdlc
  • 1,510 posts
Posted 23 April 2011 - 07:58 PM
Clean the t-stat well using spray and brush, make sure where the leak is from - the o-rings going to the cooler lines or the mating of the t-stat into the pan which also has an o-ring (rectangular). Be 100 % sure it's not something else.
Replacing the two o-rings for the cooler lines is a PITA job you just want to be sure.
* SOLD - Joy.D - 98 S70 T5M Blk/Blk, B&G springs/Bilstein HD/TC, ipd TCV, 17psi ST tune, Volans, est short shifter, Forge BOV, SAMCO ic hoses, R-mani, 3" dp/obx exhaust, SAS delete
#18 g96nt
g96nt
  • 32 posts
Posted 17 September 2011 - 08:03 PM
Did you ever solve this? mine is leaking profusely from the passenger lower side, too. the timing belt is dry, and so are the pullies.
initially, I thought it was a bad front seal, but I think the belt would be wet with the amount of oil I'm losing. we're talking about a quart/week right now, and it's covered the entire passenger side of the under-car.
I saw someone elsewhere mention that it may be oil thermostat gaskets?
for reference, I have a '00 motor in my 850, so it's got the oil cooler in the oil pan. ( I think that eliminates the oil cooler lines?)
Thanks, guys!
#19 rmorse
rmorse
    GLT's aren't turbo,YO
  • 744 posts
  • Interests:SPEED! Snowboards, dirt bikes, volvos, crotch rockets....
Posted 17 September 2011 - 09:32 PM
Damn it. Someone +1 him. I'm on my phone and accidentally -1 him while scrolling.
#20 g96nt
g96nt
  • 32 posts
Posted 08 October 2011 - 02:16 PM
I fixed mine.
Ended up being a cracked turbo oil feel line.
It was dripping from the banjo bolt @ the block, and making a hell of a mess.
I bought a turbonetics 3' stainless line from summit for $25 the appropriate banjo fittings for $25, and swapped it out. I had to cut the old line in half to remove it without removing the turbo coolant lines, which made me happy I chose the stainless line.
Dry as a bone, now, and won't need to be replaced if/when I upgrade the turbo.
