Aluminum Control Arms.
#1
Posted 03 May 2011 - 01:28 AM
Thanks!
Some of the dumbest people I know seem to know everything.........funny about that!
#2
Posted 03 May 2011 - 02:06 AM
IMO if you hit something hard enough to bend a c-arm you probably bent the rim/ and possibly the strut as well....
#3
Posted 03 May 2011 - 02:39 AM
1996 855R~ 287/304 at 18 psi~tuned by English Racing "BATLWGN" SOLD
2006 Evo 9 MR built for SCCA STU SOLO #13 #33 Sponsored by English Racing "BATLSDN" 2012 STUL National Champion
2002 BMW Z3 M coupe "BATLCPE"
2004 Dodge Ram 3500 turbo diesel "BATLRAM"
#4
Posted 03 May 2011 - 09:02 AM
#5
Posted 04 May 2011 - 06:51 AM
Edited by mdlimy, 04 May 2011 - 06:51 AM.
#6
Posted 04 May 2011 - 09:51 AM
#7
Posted 04 May 2011 - 11:39 AM
You can put polyurethane bushings on the sub-frame side. And you can replace the ball joints separately.
I want to do ^ that if they'll work for me. Does anyone know are they 4 bolts or 2 bolts attachments?
Laser Blue 2000 V70R
Speedtuning St2 @18psi/19T w/Forge CBV/IPD drop-in intercooler/R mani/CJ 3"DP/dual 3"Magnaflow/EST intake w/K&N/Samco & Snabb hoses/Delco TCV/Bosch Super Plus/IPD HD COP/UR lite pulley/CJ delrin subframe mounts/TME AWD springs/TME strutbrace/IPD sways w/adjustable endlinks/Koni Sport strut/18" OZ Ultraleggera
#9
Posted 04 May 2011 - 12:15 PM
What do you mean? Like at the subframe? The 93 control arms are identical to 95-97 control arms, besides the removable ball joint.
Yes to the subframe, I've got a 2000.
#10
Posted 04 May 2011 - 12:33 PM
Seriously ! Yes I was looking to see what everyone else was doing to modify them.Do I need you to hold my hand NO! I've probably done more aluminum welding and metal fab than you have seen! That's what I though these forums were for to share info thoughts and ideas and to improve our cars! On my other car/site I seen how everyone else was doing their control arms then actually changed mine just a bit to better stiffen them and change the fit of my sway bar.As we tinker with our cars we all learn which makes us a source of info for other members so that's why I asked! Someone has already done this what info do you have to share ? Looking at your build you look like a good source of info for a lot of things but specifically wiring and the ins and outs of the Mega Squirt system. Members possibly even me will be asking questions on that stuff we need you to share what you have learned with us .Not give us replys like "seriously? your looking for a diy step by step tutorial on how to mod them? or leave them alone if that is too complicated.... " By the way I love the way your car sits ! I have read through your build but I still may have some questions on what you did to achieve that stance so I hope when I ask you share your info !seriously? your looking for a diy step by step tutorial on how to mod them? get some aluminum barstock and a welder and use your imagination, or leave them alone if that is too complicated....
Thanks!
#11
Posted 04 May 2011 - 01:31 PM
#12
Posted 04 May 2011 - 04:10 PM
Mods.
#13
Posted 04 May 2011 - 04:16 PM
Neu I think you'll need a -98 subframe or some how swap the bushings over...Yes to the subframe, I've got a 2000.
#14
Posted 04 May 2011 - 05:17 PM
2.If you need to or still want to, bracing down the sides and accross the middle with 1/4in barstcok does the trick.
3. For someone that says they have done more welding and fab than me I find it hard to believe you are even asking this question, unless you are welding and fabbing barbeques you should know the ins and outs of the metal properties and how to increase strength of a part as simple as a control arm, I'm not bashing you but from my experience building 4 wheel drives, when these types of questions get asked its generally by someone who wouldn't have the experience to complete the task anyways.
But all bs aside, go get some aluminum barstock and breakout the tig/spoolfeed and beef em up a bit for the piece of mind, shouldn't take you more than an hour anyways, worth it for the piece of mind in my opinion.
Robbie
#15
Posted 04 May 2011 - 05:42 PM
Thanks John.
#16
Posted 04 May 2011 - 05:44 PM
#17
Posted 04 May 2011 - 05:47 PM
Is there much of a difference between subframes?
I though you were the expert. Right?
#18
Posted 04 May 2011 - 05:51 PM
#19
Posted 04 May 2011 - 05:55 PM
but is it worth doing a subframe swap just to use aluminum control arms?
Actually it could be worth it to run AL A-arms w/poly bushings and solid subframe mounts (see my other thread)
#20
Posted 05 May 2011 - 01:43 AM
