So the first bit of work was to tear everything down to the short block. Even though the head was professionally rebuilt < 20K miles ago it had 4 exhaust valve stem seals that were leaking and carboning up on the stems. I sent the head in for a cleaning and a new batch of stem seals.
The first few days, consisted of pulling everything off, and doing some heavy cleaning. The oil pan came off, along with pulling the pistons out of their bores. We were fortunate that the motor had very little wear in the cylinders and I didn't have to use a ridge reamer to pull the pistons out. Soaked the pistons in a cocktail of carb cleaner and gasoline, to loosen up the carbon and gunk. Popped out the wrist pins, swapped in the big fat rods, squished the rings down, and pushed them back into their holes. Wiped down the journals, installed the bearings, and torqued down the arp rod bolts.
Before:
Piston 1 is in:
Something is missing here:
Some underneath shots:
Once the bottom end was back together, we cleaned up the oil pan, and pick up screen, and threw that back on along with some new rubber O rings. Tech tip, a few dabs of crazy glue will hold the O rings up in the bottom of the block while you wedge in the oil pan, it a tight fit but do able.
While we were waiting for the head to get back from the shop, we decided to get the intake and cam cover polished up for the Ipd show. I picked up a 97 n/a intake and t-body about a month ago, to go on this build. I spent probably a good 6 hours grinding out the casting lines and all the roughness before taking it to a local polish shop. The difference is quite stunning, you can do alot of the grunt work yourself and cut the cost down considerably.
Chris working on the intake:
Our work:
Back from the shop:
Michelle worked in the engine to get it spiffy, plus the old downpipe:
I picked up the head just this last Friday the 29th, the cost for a cleaning, and r&r the stem seals ran a $113 with the tax. So if your head is burning oil, go get it fixed its not that expensive. I torqued down the head with new bolts and gaskets on Friday, and tossed the R mani on.
Next on the list was to bolt up the new turbo, so this turbo is a Taiwan knock-off of the Mitsu 19t. I picked it up on E-bay from Nickel Sport the cost shipped was $438, there is nothing that throws up a red flag to me, it appears to be well made and the price was right, cheaper than getting my 16T professionally rebuilt by a local shop. The 19t didn't come with a turbine housing, but I had a oem angle flange one from a previous turbo.
