I just ordered a Devils Own Meth kit and Im just wondering if I should use the 5 or the 7gph nozzle for my setup seems it will be 400+hp. Im assuming 7 will do?
The main reason for getting this kit is after seeing the difference in how all cars behave after this kit or similar when going bigger on Turbos. I have researched this on just about every forum out there for quite a while plus tuner Magazine tests. The biggest thing is..... everyone thats used the kit says how they have NO more timing pull! Thats going to be a big help with my tuning. Most add more timing and more boost. Not to mention how they all say the cars pulls so much nicer with the meth, and the simple fact that the meth keeps the engine clean.
Its been around for a long time since the WW2 and is really starting to gain in the tuning world more than ever. Its no doubt a win win with WMI to protect my engine. And of course the cooling and the HP increase is also a plus.
Some facts.
DevilsOwn's Benefits Include:
- Increase horsepower safely by 10-15%.
- Lower air temperatures by 50-200+ degrees.
- Decrease cylinder temperatures up to 300 degrees.
- Reduce the effects of heat soak in warmer climates.
- Allows you to safely run more boost and timing.
- Reduces carbon and helps maintain a clean combustion chamber.
- Increases octane at user programmable boost levels.
Edited by dublin14, 14 May 2011 - 03:29 PM.
