* * * * * 2 votes
The Zappo Build
500 replies to this topic
#301 Zappo
Zappo
    THE ONE UPPER
  • 16,471 posts
Posted 25 April 2012 - 03:56 AM
Are you routing your PCV back into your intake? Your valves look dirty and gummed up.
Yes, it is currently stock.
Look at that big end! :lol: Sucks! Crank doesn't look too bad.
Well, rods are easy. They have them in stock also so no problem getting one. hopefully the crank and piston are ok.
#302 Platinum 850
Platinum 850
  • 360 posts
Posted 25 April 2012 - 04:17 AM
Hope the machine shop gives you good news...
Are you still certain failure was due oil pickup?
2012 Jaguar XFR - 510HP and 461TQ
2012 Acura TSX A-SPEC 6spd
1996 Volvo 850 Platinum Edition SOLD!!! "R" Exhaust Manifold, Garrett Stage III 54 Trim T3/T4 Hybrid Turbo, 550cc @ 3bar Injectors, Racelab Intake Manifold, 3" Full SS Exhaust, TurboTuner, CAI, BOV, Custom FMIC Setup, Crane Ignition, 5spd Swap, Walbro Fuel Pump, KONI FSD & Eibach Springs, IPD Sway Bar Kit, IPD BBK, 384WHP & 363WTQ
#303 Jardim
  • Interests:Being a volvo rat, working for that dollar to feed my addictions.
Posted 25 April 2012 - 04:28 AM
Oh man thats no bueno, hope your solution to oil starvation works!
#304 Zappo
Zappo
    THE ONE UPPER
  • 16,471 posts
Posted 25 April 2012 - 04:46 AM
Years ago when I first started autocross, if the oil level was even only 1/2 quart from full, on fast turn arounds the idiot light would flash just at the end of the turn, but would go away immediately. I always have oil with me (along with tools, etc) at the track because you never know what might happen, so I would top it off and not have the issue again. I was cornering much slower back then also because I had no traction; automatic and Stage III means no gas until I am straight or I just light up the inside tire on the turn.
Now I have manual with LSD, so now lateraly traction is what I need to increase.
The whole purpose of the practice day for me was to test out the negative camber I got after modifying the coilovers a bit. I was at least 2.5 to 3 degrees negative, if not more. This was to help me do the turn arounds and sweepers faster, in turn keeping the RPMs higher to help me spool sooner on exit. It was an extremely fast course with two big turn arounds that were prefect for my testing. I was definately making the turns faster than I could have before.
I had low pressue when I exited the course, and it wouldn't come back up. The pump was sucking air at some point, so either the pickup was starved or the o-rings went out on the pump. Leaning toward the pickup problem based on others who have had similar failures on high load turns.
#305 T5Hammy
T5Hammy
    Dick Sledge
  • 342 posts
  • Interests:Long walks on the beach
Posted 25 April 2012 - 09:03 PM
This is your car telling you you are way too fast and need to slow down so everyone else has a chance!
1998 s70 t5- auto :(, Stage 0, kw var 3, Ipd short ram, N/A TB from Snabb, FMIC 29x9x3, OBX exhaust, 18" Ipd pegs flat black, black projectors, aux tranny cooler.
#306 Zappo
Zappo
    THE ONE UPPER
  • 16,471 posts
Posted 25 April 2012 - 10:12 PM
I am pushing to see what the car can do without making it a full race car. Everyone has a chance to beat me, just have to put in the practice. :) Experience has put me where I am at now, but I still have a lot to learn. The Miller's can jump in my car and easily match or beat my times. More experience and they race a whole lot more than I do.
I really enjoy beating cars that should be beating me. Part of that is I am a better driver, again because of experience, and part of it is they don't setup their cars correctly.
Most of the people on VS who are building higher HP cars aren't concerned about going around a corner quickly. They are making a drag car or just general street performer. I am taking a different direction and because of this I will encounter problems that people haven't had before. Tbrick cars wouldn't have this latest issue because I think it is only a problem with transverse engine layout. The later AWD cars might not have it either because the oil pan is different.
I am hoping that people who follow will learn from my failures. If you do, feel free to toss some money my way because this learning experience ain't cheap. :lol:
It is all about saying, "You just got beat by a Volvo." :)
#307 Fudge-Brownie
Fudge-Brownie
  • PipPipPipPip
  • 3,025 posts
  • Interests:Track events in NASA/ProAutoSports and dumping money into old Vulva. And forgive the VS mod on here that added the comment above. He just turned 5.
Posted 26 April 2012 - 02:58 PM
Auto X is a required taste thats for sure! Ive been doing road course tracks for quite a few years now and never got the auto X bug even though I did very well the 4-5 times I did it.
I Hope that the oil pan mod will help in future events. Its always nice to see the smile wiped off peoples faces when a Volvo beats them like I did to a Maserati Quattroporte the other day from a 40-100mph at only 15psi. Put a smile on my face thats for sure.
Edited by dublin14, 26 April 2012 - 11:16 PM.
#308 Zappo
Zappo
    THE ONE UPPER
  • 16,471 posts
Posted 26 April 2012 - 03:45 PM
I haven't done road courses for a while. Not since I had an engine meltdown at Portland International. :)
I would have a similar problem on road courses now anyway, so the pan would help for them also. I need to get back to doing them, especially with the new track that opened just a few hours away.
#309 lookforjoe
lookforjoe
  • 9,878 posts
  • Interests:Making Stuff
Posted 26 April 2012 - 04:10 PM
You got that right! Same thing applies to highway rolls :lol:
1998 V70 XR M66 Quaife 14J PTE6262 BB Built '04 2.3l Block Wiseco Pistons 147mm H-Beams '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DW300, 3" DP back Dual Magnaflow 14834's Apr 2013 408WHP AWD (@7925rpm) 347WTq(@4400rpm)@18psi LGSpeed Header Custom Intake Manifold 30x12.5x3.5"Treadstone FMIC AP Racing Clutch KU SM Billet Flywheel Kaplhenke CoilOvers
#310 fischmama
fischmama
  • 4,996 posts
Posted 06 May 2012 - 02:43 AM
Just wanted to post this...
I took my R motor apart today and got a chance to see the extra baffeling that volvo added to it.
Website: JJFab.net
#311 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 8,156 posts
Posted 06 May 2012 - 04:49 AM
Which motors had these?
#312 fischmama
fischmama
  • 4,996 posts
Posted 06 May 2012 - 12:21 PM
This from a 2004 S60R motor. B5254T4
Website: JJFab.net
#313 andyb5
  • 3,287 posts
  • Interests:cars?
Posted 06 May 2012 - 12:38 PM
Would that pan be interchangeable on any motor with a 99+ pan? Or are there modifications needed to run that on a 99-00 block?
#314 fischmama
fischmama
  • 4,996 posts
Posted 06 May 2012 - 12:45 PM
I can't be sure. I don't have a 99-00 block here to compare it too. Its possible that the pickup tube is slightly different.
Website: JJFab.net
#315 lookforjoe
lookforjoe
  • 9,878 posts
Posted 06 May 2012 - 01:54 PM
Nice! Should be a bolt up to any block, the part number (30777698) supercedes the original 1275868, if it has no oil level sensor
#316 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 8,156 posts
Posted 06 May 2012 - 02:17 PM
So the 2005+ T5 wouldnt have them?
#317 Kevin.
    I'm 22 and I love anal
  • 7,523 posts
Posted 06 May 2012 - 03:24 PM
Why wouldn't it?
Pretty sure it wasn't just for one year
FOR SALE THREAD $1900
#318 fischmama
fischmama
  • 4,996 posts
Posted 06 May 2012 - 03:26 PM
The 06+ T5 motors could have it as well, since they are supposed to have virtually the same internals as the R motor except pistons. no guarantee that they have the same oil pan though.
The R pan does have an oil sensor.
Website: JJFab.net
#319 Zappo
Zappo
    THE ONE UPPER
  • 16,471 posts
Posted 08 May 2012 - 10:00 PM
Update from the machine shop.
#2 rod is shot, but we already knew that. Looking for a source for Eagle rods because the few types that RSI carries don't match and won't balance correctly.
Crank didn't make it, so I need a new one.
All pistons survived, but....
Cylinders have same damage, so the shop is recommending going to .040" over on them. If I do that, I need new pistons. The other option is to use another block with good crank and machine it to .020" over to match the pistons. I have a block may still be useable, but it is almost 300 miles from the builder. We believe I melted a piston in that one 3 years ago, but I still haven't opened it up to inspect the damage. Apparently, I have a history of killing engines and I have a few victims still around. :)
I sent a PM to Josh hoping to hear about getting a rod from the same place they did originally. I have not been able to find anything other that custom making one. In that case I would probably just go with RSI rods to get my car back sooner.
That is it for now.
#320 Zappo
Zappo
    THE ONE UPPER
  • 16,471 posts
Posted 08 May 2012 - 10:05 PM
Here is a photo of the difference between the rods. Crank end is not the same between them.
