Manual Swappers!
Posted 19 May 2011 - 04:13 AM
-1996 850 Turbo
-2007 XC90 V8
Posted 19 May 2011 - 04:24 AM
Posted 19 May 2011 - 04:29 AM
-1996 850 Turbo
-2007 XC90 V8
Posted 19 May 2011 - 05:56 AM
Yup. Night and day difference.
+1
and you have more control cause it uses the bigger throttle wheel
Posted 19 May 2011 - 12:21 PM
+1
This is the main reason for doing it.
Posted 19 May 2011 - 01:31 PM
(Factory Manual)
Thanks!
1994 Volvo 850 Turbo Manual
ARD Green Tune | FMIC | OBX Turbo Back | Angled 16T | TurboSmart BOV
Posted 19 May 2011 - 02:38 PM
Is it normal that when the car is off, the pedal is nice n easy to press, but once you start it the pedal gets firm?
(Factory Manual)
Thanks!
Well, there is no air flow when the engine is off, not that the amount of air passing the throttle would create a heavy resistance. Can't imagine what else you are describing, though.
On older Volvos, the throttle cable used to have the potential for metal to metal contacts - in other words, it could become a ground cable = very bad. This could lead to cables binding, and even electrical fires. All our cables are isolated from ground - you will notice that the cable retainer is plastic, the bobbin is plastic, the gas pedal is plastic and the cable ball end is held in a plastic seat. So, not likely that you would experience any binding or resistance while the engine is operating for that reason.
Posted 19 May 2011 - 06:09 PM
$28 bucks from Tasca!
Manual Cable
enter this part number in the bottom left 9157600
2007 Electric Silver S60R-------112k
Posted 19 May 2011 - 06:32 PM
86 Kawasaki Gpz900R Ninja
Posted 19 May 2011 - 06:37 PM
79 242 GT*84 F150*96 854R*98 S70 GLT-M*98 V70 AWD*00 V70R
72Chevy K10 Cheyenne*78 242 GT*89 740 TIC*96 855R *97 855R*98 V70 NA*98 V70 XC*98 S70 T5
98 C70 T5m*98 V70R*98 V70R*99 S70 AWD*99 V70R*99 V70R*00 V70R*00 V70 XC*04 V70R
Posted 19 May 2011 - 06:45 PM
I enjoy driving the car even more now.
-1996 850 Turbo
-2007 XC90 V8
#14
Posted 19 May 2011 - 10:34 PM
They say it's for an auto transmission.
'95 854 T5M 195k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue - DEAD - To be parted out
'04 S60R - 125k
#15
Posted 19 May 2011 - 11:15 PM
will order this week! Thanks Brett!
Manual Cable
Interesting. that link doesn't work or I would have ordered one also.
Strange navigation, but I finally got to the part.
#16
Posted 19 May 2011 - 11:18 PM
enter the part number 9157600 in the bottom left
#17
Posted 20 May 2011 - 02:18 AM
1996 855R~ 287/304 at 18 psi~tuned by English Racing "BATLWGN" SOLD
2006 Evo 9 MR built for SCCA STU SOLO #13 #33 Sponsored by English Racing "BATLSDN" 2012 STUL National Champion
2002 BMW Z3 M coupe "BATLCPE"
2004 Dodge Ram 3500 turbo diesel "BATLRAM"
#18
Posted 20 May 2011 - 02:33 AM
i have a new cable sitting in my trunk but haven't gotten around to putting it in
lol It literally takes 15min.
#19
Posted 20 May 2011 - 03:38 AM
IDK how to explain it really...just basically when the car is off, its super easy to push the gas pedal, but once its started, the pedal is noticeably harder to push. When its raining, forget about it...even worse. Its annoying cuz sometimes I shake the car in first cuz the pedal is suddenly harder than usual. Maybe i'll try changing the cable since its a little eaten up at the throttle wheel and clean the TB again.Well, there is no air flow when the engine is off, not that the amount of air passing the throttle would create a heavy resistance. Can't imagine what else you are describing, though.
#20
Posted 22 May 2011 - 04:16 PM
Got one at work on Friday and installed it on my yellow wagon, like you said it is a night and day difference. I will be ordering one for my wife's wagon tomorrow!
After 3 swaps you would have figure I had already tried this but I never really saw any reason to, man was I wrong! Thanks for the tip.
