Radio Code
13 replies to this topic
#1 Yukon
Yukon
  • 1 posts
Posted 06 June 2011 - 03:14 PM
Trying to get radio code for HU-615 radio for my Volvo 40. Serial Number is VO345020315461. Vin YV1VS27583F977671.
My email is jwarfi@yahoo.com.
#2 boxpin
boxpin
  • 835 posts
Posted 06 June 2011 - 05:44 PM
I dont think anyone has the generator for this. You would need to contact a dealer. Just tell them you replaced your battery and it says code. If they dont give it to you over the phone call another dealer.
13.7 @ 99 Automagic Posted Image 13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
#3 VolvoGuy500
VolvoGuy500
    Faulty The Chode-inator
  • 95 posts
Posted 10 June 2011 - 01:16 AM
This.
What interests me is I wonder how the codes are generated in the first place. It'd be interesting to see if there's any specific pattern between the serial numbers and matching unlock codes, or if they're just random 4 digit numbers. There has to be repeat codes anyhow, because 4 digits only give you 10K combos, and there are quite a lot more than 10K Volvo HU's floating around out there.
'92 745 NA Auto - Winter Beater
CAI, Audio System, Full Exhaust, Cherry Bomb Muffler, Nadia's
'96 Eagle Talon TSi AWD - Summer Car
Big 16g, DSMLink, 3" TBE, Flowmaster Muffler, ASA JS5's
#4 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,809 posts
Posted 10 June 2011 - 03:39 AM
View PostVolvoGuy500, on 10 June 2011 - 01:16 AM, said:
<br />This.<br /><br />What interests me is I wonder how the codes are generated in the first place.  It'd be interesting to see if there's any specific pattern between the serial numbers and matching unlock codes, or if they're just random 4 digit number.
Not likely straightforward. Probably some random math algorythm.
99 V70R
98 V70 GLT
#5 Guest_Terrance_*
Guest_Terrance_*
Posted 18 July 2011 - 11:24 PM
So does this mean nobody has the numbers cause if any one do post them on here
#6 TRACStar
TRACStar
  • 2,417 posts
Posted 19 July 2011 - 09:07 AM
FAIL
I thought you were at least smart with numbers, there is only 1296 possibilites.
:lol: ;)
#7 trs80
trs80
  • 435 posts
  • Interests:Anything with a fossil fuel power plant.
Posted 19 July 2011 - 06:51 PM
View PostTRACStar, on 19 July 2011 - 09:07 AM, said:
FAIL
:lol: ;)
0000 through 9999 would give you 10k possible 4 digit codes. I doubt Volvo used "0000" as a code but the math still holds true. Link for those that require additional explanation, My link.
To the OP: You will have to contact a dealer. You are only allowed three attempts before it is "OFF." Then you must wait two hours, with power to the unit, before you can attempt again.
Forgot to add, Volvo only used 1-6 so yes 1296 would be correct. Posted Image
'97 850R, resto phase. Mods in Garage: Volvo 850 R (1997)
'96 Jeep Cherokee, lifted, locked and ready for rocks.
#8 TRACStar
TRACStar
  • 2,417 posts
Posted 19 July 2011 - 08:42 PM
Thank you, come again. ;)
#9 joerickson
joerickson
  • 7 posts
Posted 22 July 2011 - 01:31 AM
I had the same problem with my car, just pull the radio to see if the code is there like it was on mine.
#10 PyROTech
PyROTech
  • 5,342 posts
Posted 22 July 2011 - 02:58 AM
most dealers will give you the code free of charge, as said above. This a sticky somewhere or no? b/c it seems a very common question.
#11 TRACStar
TRACStar
  • 2,417 posts
Posted 22 July 2011 - 03:54 AM
Mine was written inside the front cover of the maintainance record book. And on a card that said radio security code inside the sleeve that holds all the literature.
#12 paulbonard
paulbonard
  • 1 posts
Posted 14 August 2011 - 10:46 PM
Changed my battery, dont have a PIN written anywhere.... what info is needed? I have a 2002 Volvo S40 and the VIN is YV1VS29582F852102... any help would be appreciated.
#13 Swag Swag
Swag Swag
    Captain Tow Hook
  • PipPipPipPip
  • 4,476 posts
  • Crew:SWC
Posted 14 August 2011 - 11:17 PM
Read the pinned topic above!!!
Spence—855 T5-R W/RN Swap—NWC
http://www.seshday.com/invite/?r=43707
#14 Dan A
Dan A
  • 1,809 posts
Posted 22 August 2011 - 06:28 PM
Hand delivery....
http://volvospeed.co...here-dont-post/
99 V70R
98 V70 GLT
