Can You Protect Yourself?
11 replies to this topic
#1 PyROTech
PyROTech
  • 5,342 posts
Posted 07 June 2011 - 02:25 AM
im sure most people when reading the topic title thought it was a thread about guns. I choose not to include a poll in this thread due to the many different dynamics of the topic. Im writing this b/c of something that has being going around the province of Ontario and probably other parts of the world for some time.
Crime has been a problem in my life for along time. And many of the bylaws seem to relate to persons engaged in criminal activity. But the bylaws relate to property owners who themselves engaged in self preservation measures.
It comes down to the trend of "fortification bylaw" laws.
Most of the members on this board are american. And maybe some of this doesnt apply to you.
this is an example of whats going on...
http://www.oshawa.ca...rtification.pdf
highlighted notes...
"Excessive Fortification" and "Excessively Fortify" means the Construction of devices,
barriers or materials applied to Land and includes but is not limited to:
i) the Application of steel plates, steel bars, bullet-resistant shutters, laminated
glass or heavy gauge wire mesh to a window, door or any other opening on any
level of any building or structure other than the basement level of such building
or structure;
ii) the Application of concrete block, brick, or other masonry or similar product to
partially or completely obstruct or seal any window, door or other exterior
entrance or egress to Land;
iii) the Application of steel sheeting or plates or other similar products to the interior
or exterior walls of a building or structure such as to reinforce walls or create a
secondary wall such as to protect against firearms artillery, explosives, vehicle
contact, shock, and any other similar intrusions;
iv) armour plated or reinforced doors, whether exterior or interior, designed to resist
against impact of firearms artillery, explosives, battering rams, shock or vehicle
contact;
v) pillars, cones or barriers Constructed of concrete, steel, or any other building
material that are designed to obstruct, hinder, restrict, or deny access to Land by
conventional means of access or modes of transportation; and
vi) an observation tower designed to enable a visual observation of surrounding
areas beyond the perimeter of the Land whether the tower is occupied by an
individual or a surveillance camera or like equipment.
"Excessive Protective Elements" means devices, objects, material components, or
any contrivance applied to Land and includes but is not limited to the Application of:
i) perimeter warning devices such as "laser eyes" or other types of advanced
warning systems designed to forewarn of the encroachment onto the perimeter
of Land from adjoining lands or roadways but excluding similar applications to
forewarn of entry into a building or structure on Land;
ii) electrified fencing or other similar barrier including hidden traps, electrified doors
or windows, land mines or other explosive devices or any weapon or thing that
may cause injury or death when triggered or activated; and
iii) visual surveillance equipment, including video cameras, night vision systems, or
electronic surveillance devices capable of permitting either stationary or
scanned viewing or listening beyond the perimeter of the Land.
This is the part that provides for what you would assume to be an exclusion to the above, yet its up to interpretation.
Section 2.2 does not prohibit:
(a) the use or Application of commercially marketed security devices designed and
applied to provide reasonable protection from theft or other criminal activity against a
Person or property of a Person;
(the reasonable use of Protective Elements such as a "laser eye" or other advance
warning devices on windows or doors of a dwelling for the purpose of providing a
warning to an occupant of the dwelling or of dispatching emergency services
personnel where an entry into a dwelling has occurred; or
© a "normal farm practice" as defined in subsection 1(1) of the Farming and Food
Production Protection Act, 1998, S.O. 1998, c.1.
Interesting part...
Application for Partial or Complete Exemption
6.1. Any Person wishing to obtain a partial or complete exemption from the provisions of this Bylaw must file with the Chief Building Official a written application containing at least the
following:
(a) date of application;
(B) proof that the Person is the sole owner of the Land or, alternatively, each owner’s
written authorization to submit the application;
© the Land’s legal description and municipal address;
(d) particulars of the existing use(s) of the Land, and of the intended use(s) if any change
in use is anticipated;
(e) a sketch or survey of the Land and structures;
(f) particulars of all existing and proposed Fortification and Protective Elements including
the date or dates of Application of existing Fortification and Protective Elements;
(g) particulars of each exemption requested including the reasons for requesting the
exemption; and
(h) payment of the fee from time to time prescribed by the City’s General Fees and
Charges By-law 13-2003, as amended or superseded.
#2 AverageVolvo
AverageVolvo
  • 1,634 posts
  • Interests:Woman,Cars,Guns, Sex, Music.
    And making $$$ to fund the above.
Posted 07 June 2011 - 12:08 PM
WOW Posted Image
and they don't let you have guns IIRC (except hunting rifles) Dam I though California was bad Posted Image
I intend on keeping what I have earned Posted Image at nearly any cost.
Better build a fall-out shelter while you can Posted Image
96 850 (412) wagon W/2 racing seats no rear seats, ..Converted to M56h with Quaife. R clutch,Kw v2 coilovers, qbm end links,Ipd sways,strut and shock braces/ Front/rear lower Ultra racing chassis braces. Team Dynamic 17in rims 17lbs .Poly mounts on trans, engine and firewall.Porsche Bbk, Ss lines, Super Blue Ate.5mm Spacers,Rolled Fenders,R Manifold, T04E 50 trim @18psi. Divorced WG and BOV ,3in Downpipe, gutted 3in cat,2.5 tme/Ipd catback Gizzmo Ebc, 1 gallon Aem progressive Meth Injection kit. Walbro 255. Na mani W /960 plate and Na Silicone Tb hose. Boost/egr/wideband gauges dash mounted. Double Din touchscreen Nav. 12in Fosgate p3 and 2 Alpine amps/ + Cf spoiler+ V70 stuff.
#3 Owned
Owned
    Adam #1
  • 5,896 posts
  • Interests:$
Posted 07 June 2011 - 01:46 PM
Dude, just move already.
You should probably just vacate America Jr. and move up to the big leagues.
I had to register my basement as an NFA item.
#4 Fudge_Brownie
Fudge_Brownie
    Hippie Exterminator
  • 8,428 posts
Posted 09 June 2011 - 03:45 PM
Does your breaching crew have a $10 budget? Needs more winches and jackhammers. Weaksauce. Like a crack dealer holed up in his house is going to pay attention to rules about fortification :lol:
How does a warrant serving go? Knock knock, open uh in der, eh? I like the way SWAT does it. Shout "police" while dropping a 50lb concrete log through your door, deploy a flash bang, and toss all those confused poor fuckers face first in to the floor at gun point. If surveillance indicates the door is "fortified", arrive with a truck and a winch. Hook it up, hit the gas, and proceed shouting "police" as usual.
86 Kawasaki Gpz900R Ninja
#5 PyROTech
PyROTech
  • 5,342 posts
Posted 09 June 2011 - 04:06 PM
your assuming its a one story bungalo. Imagine the fun with breaching the first floor only to find each floor entrance has a new set of fun, all the way to the 4th.
edited part: btw im not concerned about cops and trucks and the man power for that. Im concerned about that crack dealer that is holed up, deciding its time to acquire a new tv from my house with a couple of friends.
#6 Fudge_Brownie
Fudge_Brownie
    Hippie Exterminator
  • 8,428 posts
Posted 09 June 2011 - 06:10 PM
So like I said, that law only hurts legal citizens. Troublemakers won't be following those rules.
#7 PyROTech
PyROTech
  • 5,342 posts
Posted 09 June 2011 - 06:22 PM
wow, the words i was looking for. Also applies to the stupid long gun registry.
How many gang bangers are buying guns legally and registering them? Basically these laws make honest citizens into criminals.
i have now seen what could happen in canada...
#8 Pops Racer
Pops Racer
    Old Man Crew Leader
  • 4,744 posts
  • Interests:Playing my violin around fires
Posted 14 June 2011 - 12:37 AM
looks like a home invasion invitation, I could get into your house with a 16 oz hammer.
Its not intended to weaken you against illegal intruders its to facilitate ease of entry for Government entities. Scary ass shit, real scary.
That is some of the dumbest shit I have ever read. Ban bolt locks on the doors, better yet ban doors. No I got it, hang a key on a nail outside the door. Cuz thats what dat is.
No cctv cams, no IR motion detectors, thats half of a good home security system. I install that shiit for a living, so imagine the jobs lost by killing that market?
Canada is going to get invaded by Iceland.
"Property is the fruit of labor...property is desirable...is a positive good in the world. That some should be rich shows that others may become rich, and hence is just encouragement to industry and enterprise. Let not him who is houseless pull down the house of another; but let him labor diligently and build one for himself, thus by example assuring that his own shall be safe from violence when built." - Abe Lincoln
#9 PyROTech
PyROTech
  • 5,342 posts
Posted 14 June 2011 - 03:10 AM
today, minivan had someone in it. Called police, finger prints should actually prove good this time around. Van is sitting in driveway awaiting cops... camera has video of places of fingers. Great facial of person!!!
#10 RobT5.
RobT5.
    Doctor Retardapus
  • 3,093 posts
  • Interests:We-mons
    Orange Soda
    Speeding
    Archery
    Cars
    Poking
    Your Mom
Posted 14 June 2011 - 01:57 PM
:lol:
1998, S70 T5.
RobT5 FloridaVolvoCommunity Car Domain
Quote
optimus prime when i do get this whole project underway im totally gonna eat a sandwich in my engine bay
#11 PyROTech
PyROTech
  • 5,342 posts
Posted 15 June 2011 - 05:27 PM
cops came this morning, got very little. It aint like on tv. Alot of photos and filling out cards and taking photos of the cards, then more photos of the cards they fill out (documentation if something ever turns up). Got some prints, but then again it could be mine or anyone that has touched the van. Gave them the video and still photos. They send it off, and i guess i just wait. Im not very hopefull. I was hoping a nice 5 finger smudge free hand would be on the door, but no luck.
#12 Pops Racer
Pops Racer
    Old Man Crew Leader
  • 4,744 posts
Posted 16 June 2011 - 02:04 PM
IT aint like CSI Toronto...unfortunately.
Sorry for the hassle.
