Brake Failure Light
4 replies to this topic
#1 eggman5480
eggman5480
  • 10 posts
Posted 20 June 2011 - 09:02 PM
I have a 1978 245 DL station wagon.I've put 4 rebuilt calipers and 2 brake hoses on the left front.Each time the brakes work for a few miles and then the brake failure light comes on and the car pulls to the right when the brakes are applied.Any ideas?
#2 MistrThou
MistrThou
  • 23 posts
  • Interests:Electronics, Automotive and buses LOL!
Posted 21 June 2011 - 04:13 PM
Do you have a spongy or soft brake pedal?
I'd put a wager on it being the master cylinder.
#3 eggman5480
eggman5480
  • 10 posts
Posted 22 June 2011 - 12:34 AM
I did replace the master cylinder.The pedal is not spongy,in fact as soon as I step on it the car starts to pull...Another strange fact---sometimes after sitting all night,the brake light will go out when I first step on it,and the brakes will work fine for several minutes!
#4 kepla
kepla
  • 6 posts
  • Interests:Motoring, electronics, computing, photography, music, gardening.
Posted 22 June 2011 - 03:37 AM
Well, obviously this is not the master cylinder or wheel cylinder, but it does sound like something to do with the dual-circuit nature of the braking system. I am assuming that you have allready checked over the whole system for leaks and damage to brake pipes ?
I'd be inclined to suspect the device which connects between the two brake circuits and has a switch in it which brings on the brake fail,light if the two circuits are out of balance. It is simply a sliding piston, with the pressure from each circuit on either side, which moves and operates a switch with a 'centre-off' arrangement. Ideally, when bleeding the brakes, the switch should be unscrewed and the piston locked in place. Otherwise the device can tend to give false indications.
#5 AverageVolvo
AverageVolvo
  • 1,634 posts
  • Interests:Woman,Cars,Guns, Sex, Music.
    And making $$$ to fund the above.
Posted 24 June 2011 - 08:54 PM
Yep, most likely Brake Distribution/junction block . Notorious for setting brake light warning light on.
Are you sure the system is bled properly. IE car brakes straight. no pulls etc...
96 850 (412) wagon W/2 racing seats no rear seats, ..Converted to M56h with Quaife. R clutch,Kw v2 coilovers, qbm end links,Ipd sways,strut and shock braces/ Front/rear lower Ultra racing chassis braces. Team Dynamic 17in rims 17lbs .Poly mounts on trans, engine and firewall.Porsche Bbk, Ss lines, Super Blue Ate.5mm Spacers,Rolled Fenders,R Manifold, T04E 50 trim @18psi. Divorced WG and BOV ,3in Downpipe, gutted 3in cat,2.5 tme/Ipd catback Gizzmo Ebc, 1 gallon Aem progressive Meth Injection kit. Walbro 255. Na mani W /960 plate and Na Silicone Tb hose. Boost/egr/wideband gauges dash mounted. Double Din touchscreen Nav. 12in Fosgate p3 and 2 Alpine amps/ + Cf spoiler+ V70 stuff.
