Vehicle Speed Sensor Wire?
Posted 21 June 2011 - 08:52 PM
I know the 850 gauge clusters have an output that does 48 pulses/revolution, but that requires pulling the dash pad and running the wire from there. I know there are two wires going from the transmission and ABS units to the gauge cluster. They are Yellow/Brown and Green/Yellow. That is, this is what the wiring diagrams say. I cannot for the life of me find these in the car! I even have a whole set of wires from another car, and there are no Yellow/Brown or Green/Yellow wires running to the gauge cluster.
Anyone know where it is?
This is for a 95 850, btw.
Serge - 95 850 T5
Posted 01 July 2011 - 01:28 AM
Posted 04 July 2011 - 08:59 PM
Ghost Shadow, on 01 July 2011 - 01:28 AM, said:
You positive? I know the newer models have that to account for the speed-dependent volume control, but I doubt MY95 cars had it.
Serge - 95 850 T5
Posted 05 July 2011 - 03:05 AM
Serge, on 04 July 2011 - 08:59 PM, said:
dude did you look before you replied?
i needed a speed pulse back in 2004 when i did the stereo in my 94 855t. yes it is there
Posted 05 July 2011 - 04:59 AM
Touche.
I'll check in the morning. Thanks man.
Serge - 95 850 T5
Posted 05 July 2011 - 10:54 AM
Posted 06 July 2011 - 12:33 AM
I looked and didn't find it in my 95 T5-R. I went over each wire in the harness and it was not there... I would love to know which wire you used for that since I need it for my double din navi...
Posted 06 July 2011 - 12:39 AM
Posted 06 July 2011 - 03:24 AM
Ghost Shadow, on 06 July 2011 - 12:39 AM, said:
I knew I wasn't crazy
Did you take the ABS wire from under the hood and run it up? Or found one under the dash?
Serge - 95 850 T5
Posted 06 July 2011 - 05:15 AM
For instance, if you had a 850 with a outboard amplifier you had the speed sensor wire. This would be going to the radio's speaker connector as a single wire (you would see it as a single wire going to a connector that had like 10 blank connections).
2007 Volvo S80 V8 Silver - Stock.
Posted 06 July 2011 - 09:13 AM
Posted 06 July 2011 - 02:30 PM
I looked for it on my T5R, and I couldn't find it at all. Is it possible it was on the amp harness and not the factory harness? I will look again when I get the car back apart but I don't think it is there...
Posted 14 July 2011 - 05:01 PM
1998 V70R, 203k, black: EST duals, IPD sways+HDlinks, 302 brakes, ss lines+AteSB, ABMs+4200HID, K&N filter, Propus Cs, Eclipse DVD/nav AND 1991 740 Turbo wagon, mystery mileage, red: stock utility beater with crazy sound system. Sold: 1995 T-5R sedan
#14
Posted 14 July 2011 - 05:30 PM
Tyler T5R, on 14 July 2011 - 05:01 PM, said:
Yellow/brown and and Green/yellow (which is different from Yellow/green, this has to be mostly green with a thin line of yellow).
Problem is, can't find them in the harness! And the only one that is that color, goes to another portion of the car no where near the gauge cluster (which is where the wiring diagrams show it going).
Serge - 95 850 T5
