I'm torn between Viper, Clifford and CompuStar systems.
I know that I want to add a dual zone proximity sensor to whichever system I go with.
Basically I want something that will 2 way page, start, unlock, lock, panic and pop the trunk. I'll be doing the install myself so if there's any pointers on which wires are where and such I'm all ears. I do know where the ignition wires are due to the device that was previously installed.
Being able to adjust various sensitivity settings from the remote would also be a plus. My wife's Viper system is like that and it's pretty neat being that it takes some tweeking to adapt the alarm to the car's parked living conditions. (Being in the city)
A remote with a nice display is a plus as well.
This system caught my attention: http://cgi.ebay.com/...=item5d26db0f18
Although for the above system I'm having trouble finding a compatible proximity sensor.....
This one's pretty neat too: http://cgi.ebay.com/...=item3cb5c2ad87
Any information is appreciated.
I'm going to spend some time searching around and hopefully find a useful wiring diagram.
I've never installed an alarm before but I'm pretty tool and electronics savvy so with a little direction things should go alright. The only things I'm a little unsure of is how to wire the starter kill, how to pick up the door triggers....I'm assuming a separate wire doesn't need run to each door but none the less it puzzles me a bit. If the system comes with a hood switch that's new to me as well. Although the hardest part there is probably aligning the switch properly.
Educate me.
PS, Steve, if you wanna help me I'll get us steak dinners.
Most importantly I am so tired of my damn factory keyless only working with the remote held up by the driver's side mirror. It has a range of like 6 inches from the receiver on the cluster.
If you need any other information or I left something out just let me know.
Edited by --Aaron--, 28 June 2011 - 02:52 PM.
