Exhaust Mod, Worth The Trouble?
Posted 01 July 2011 - 06:08 PM
What is the least rich ECU tune?
Posted 01 July 2011 - 06:38 PM
^^ edit
I dont believe keeping the stock cat would be an option in a new downpipe it would kind of negate the install of a new downpipe.
2008- G8 gt dark grey ------ bolt ons --- wifeys car
2009 -- blue g8 gt -------- bolt ons ----- my car
Posted 01 July 2011 - 09:26 PM
Volvospeed On Google+
Posted 01 July 2011 - 10:43 PM
And a 3" aftermarket cat will most certainly out-flow the OEM cat, no question there.
Do it.
855 Turbo Automagic :: T3/T4E .60 + E85 = fun!
4 gears, 5 cylinders, 7 seats...13 seconds.
Posted 02 July 2011 - 12:15 AM
i beg to difer, the stock cat is quite restrictive and will cause the rest of the exhaust to get much more hot, i have dyno experience of this, that is with a full turbo back 3" with the stock cat welded in for one day of emmision testing, decided to do a couple dyno pulls before i pulled it, needless to say i saw 9whp dissapear with the cat on then reapear when i removed the cat. I was running a standalone ems so it may not be so extreme with the stock motronic system but it goes to show the restriction of the cat.OEM CAT has huge flow numbers at very low resistance. Its not going to be a bottle neck like the DP or flex joint
Posted 02 July 2011 - 03:24 AM
http://www.wothrline...performance.htm
So no major performance gain without a tune since boost pressure might actually drop if
the exhaust is less restrictive (same as motronic 4.3 and 4.4). A tune really is the best
bang for the buck.
I'd put the EST on then look for a stage 1 tune since that is going to be the biggest
bang for the buck (cat back and off the shelf tune has made many Volvo drivers very happy).
Next the downpipe/cat if you think you need more.
A local muffler shop only charged me $50 to do my EST. No need to wait on that
1995 855 GLT (stock). 2006 XC90 Ocean Race. 1 of "only" 800 (says so on the dash).
Posted 02 July 2011 - 03:34 AM
What was stock whp with a NEW OEM cat?
What was it with a new after market one?
Posted 02 July 2011 - 03:43 AM
no idea stock numbers. this was without a cat and with a low mile oem cat on a 00r motor with a td05 hrc 20g, just to give an idea of how restrictive it was.
Posted 02 July 2011 - 03:47 AM
A used cat vs no cat is nothing like a race cat vs a new cat.
Posted 02 July 2011 - 04:39 AM
it still shows the restrictiveness of a used low mile oem cat as opposed to no cat which is very similar to a high flow cat. Yes a brand new oem cat may have high flow numbers at low resistance but it doesnt stay brand new for ever, and from my experience the oem cat was robbing me of 9whp which tells me that after he gets some miles on that brand new cat it will eventually do the same thing. i vote high flow cat if you are opposed to going catless, other wise i recommend catless.
Posted 02 July 2011 - 06:00 AM
Second and third paragraphs of the Bosch ME7 section might help answer your questions:
bang for the buck.
Completely incorrect if you use external boost control (the factory setup is fine for soccer moms but completely unnecessary for any of us).
Set the actuator to your desired boost level at WOT, and bypass the solenoid (or install an MBC).
I removed the OEM cat (exhaust was already 3") and I picked up a full 3psi on my gauge.
Posted 02 July 2011 - 04:30 PM
Does that approach work on a model year 99 with an ME7 ECU?
Posted 02 July 2011 - 04:48 PM
Yes and no, mainly no. short answer is to leave the stock boost controller and wait for ard to sort out me7 tunes and buy one when they are ready, that will net you the most gains for what mods have been done to your car. Or u could just buy an ipd tune right now but I think that's kind of a waste of money. But me7 doesn't like you to alter its boost pressure.
#14
Posted 02 July 2011 - 05:16 PM
#15
Posted 02 July 2011 - 06:28 PM
Couple this with the fact that the downpipe goes in to the cat at essentially a straight down angle there is no reason to weld oem used cat on to an OBX downpipe (OBX for example). Another reason is that I have had several cats simply break from rust at the back before the straight pipe.
Which brings me to my next point. I just got done welding a straight pipe to replace the cat on a 98 XC (for the reason stated above) and the consensus was that the metal there is just too thin. The exhaust will rot out.
In short, don't reuse anything and go aftermarket. And scrap your stock cat. They gave me like seventy bucks the last time.
Stu M. or Stumif people are hating, your doing it right
98 S70 2.3 stgIII
#16
Posted 03 July 2011 - 03:27 AM
For the cat, I found Magnaflow 46005 listed for my 99 S70 T5.
However, the diameter is 2.25" just exactly like the stock pipe.
So, if I am getting 3" downpipe should I get a cat with 3" inlet, such as Magnaflow 41409?
Do you recommendation for cat or downpipe?
#17
Posted 03 July 2011 - 03:40 AM
My OBX doesn't want to seal properly on the flange but I feel I may be one of the few. Many others didn't seem to share my problem and were fine.
Keep in mind it is probably the cheapest option unless your are a moderately skilled welder or have friends that can help.
98 S70 2.3 stgIII
#18
Posted 09 July 2011 - 08:01 PM
98 S70 GLT Auto = Wifes car
03 Mustang GT vert - 271rwhp, 311rwtq gone and missed
