Intermintent Power Loss '94 960
#1 JimBlu
JimBlu
  • 2 posts
Posted 13 July 2011 - 08:54 PM
I have a 96 960. On my way home today in 100 degree weather the car would shut down and restart immediately. Almost like a reboot. I checked the diagnostic codes and got an A-114 code. All other codes normal. Any driveway fixes suggestions? Also any cost of repair guesses? Any info would be appreciated.
It's hard to believe it's a tranny problem.
Jim
#2 DEWFPO
DEWFPO
  • 539 posts
Posted 13 July 2011 - 11:08 PM
I thought your '96 MY was OBDII compliant.
OBD I : A1 -114 is a gear selector code
OBD II : 114 is an air intake temp sensor code.
DEWFPO
#3 JimBlu
JimBlu
  • 2 posts
Posted 13 July 2011 - 11:14 PM
[quote name='DEWFPO' timestamp='1310598527' post='1981988']
I thought your '96 MY was OBDII compliant. Typo 94 obd I
[quote name='JimBlu' timestamp='1310590491' post='1981943']
I have a 94 960. On my way home today in 100 degree weather the car would shut down and restart immediately. Almost like a reboot. I checked the diagnostic codes and got an A-114 code. All other codes normal. Any driveway fixes suggestions? Also any cost of repair guesses? Any info would be appreciated.
Jim
[/quote]
#4 Three Fat Tigers
Three Fat Tigers
    RWD Moderator
  • 1,746 posts
Posted 14 July 2011 - 05:10 PM
What is the "A" part of the code? Is that diagnostic socket A? Also what method are you using to retrieve the code? There is no 1-1-4 code from pin two of socket A. Pin 1 is for the transmission and 1-1-4 is as reported above, or alternately as "Program selector open-circuit or short-circuit to ground".
Otherwise I'd start by pulling the cover off the center of the engine and have a close look at the ignition coil wiring harness, failures here are common.
