Xr Bumper Mods
99 replies to this topic
#41 RobT5M
RobT5M
    Whiner
  • 6,327 posts
Posted 03 January 2012 - 05:47 PM
Looks good how it is.
If you go for a bigger fmic then yeah go for it. I think it looks good either way.
And looks beautiful over all.
But I am still curious about what is going on here.
Mine 98 S70 |  RN Swap | Manual Swap | K24 | Green Giants | Beüst Tuning | Snabb Intake | OBX | Much More |
Wife 08 S80 |  PlastiDip and Leather Care
Florida Volvo Community            |            Love Thy Cider / FB
#42 lookforjoe
lookforjoe
    Let me show you why you're wrong
  • 12,350 posts
Posted 03 January 2012 - 05:51 PM
I do have a larger FMIC now...
On the other thing, that is my secondary air intake - I have had two feeders into the custom CAI box. I had to remove it recently as I added a larger drain can for my breather system, and they sit in the same area behind the IC piping.
1998 V70 XR M66CA21 Quaife 14J PTE6262 BB Built '04 2.3l Block Wiseco Pistons 147mm H-Beams '03 Ported Head EnemCams TurboTuner TunerPro/Ostrich2.0 1085cc Inj, DW300, Surge Tank w/Dual 044's, 12mm fuel lines 3" DP back Dual Magnaflow 14834's Jul 2013 446WHP AWD (@ 21psi / 7795rpm) 347WTq(@4400rpm@18psi) LGSpeed Header Custom Intake Manifold 30x12.5x3.5"Treadstone FMIC AP Racing Clutch KU SM Billet Flywheel Kaplhenke CoilOvers & Rear Setup
#43 the commissar!
the commissar!
  • 2,080 posts
Looks GREAT the way it is...perhaps a bit odd in the over-sized opening you photo-shopped. Plus as you said, I'd think long and hard before cutting that bumper bar in half.
1998 V70 T-5 -Auto - ARD Blue & Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
#44 Guest_luke_jones_*
Guest_luke_jones_*
Posted 03 January 2012 - 05:59 PM
I'll have to check, but I think this would entail cutting the bumper bar into two - which I'm not keen on.
Pretty sure you are right there. IMO it looks super clean the way you modded it the first time, I wouldn't change a thing.
#45 Volvo5.0
Volvo5.0
  • 1,422 posts
Posted 03 January 2012 - 06:16 PM
Looks good either way, but if airflow is the main objective...go bigger :)
You would probably need to remove 3 sides of the aluminum bumper support, but you may be able to leave the 4th (top) side. That would at least hold everything together, and maybe give some (very little) impact protection.
I have the same intercooler as your old one (28x8x3.5), and the opening in my modified bumper comes right to the top edge of the intercooler. I still have 3" of my bumper support left. So cutting that 3" off and only leaving the top edge would put you where you need to be for the 3" taller intercooler.
1998 S70T5M, 2000 Built B5244T2 RN Engine, K24 turbo, 550cc injectors, Turbo-Tuner, Coolingmist Progressive WMI, Precision FMIC, 311whp 363wtrq
#46 lookforjoe
lookforjoe
  • 12,350 posts
Posted 03 January 2012 - 06:34 PM
It's 4" taller... I feel that this is primarily a cosmetic mod - I've tried running with no bumper at all, and it made no difference to IAT's. Probably if the opening is reasonably scaled for the IC, it won't have that much impact to temps.
I've found a source for 160ºF Thermostats - that will have more impact, I'm sure :D I do have to check what ME4.4 sees as normal operating temp, though - don't want it to run rich because it sees the temp as below normal...
#47 Guest_luke_jones_*
Guest_luke_jones_*
Posted 03 January 2012 - 07:15 PM
If you were going to do it, how much material could you save from the bumper support? Perhaps with enough material left it could be built up to withstand impact again.
#48 Volvo5.0
Volvo5.0
  • 1,422 posts
Posted 03 January 2012 - 07:26 PM
If it's only cosmetic, I'd leave it the way it is. For me the whole plastic welding thing was kind of a PITA anyway....
#49 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,594 posts
Posted 04 January 2012 - 02:18 AM
Well what people do around here they actually cut oval holes through the bumper and bumper cover. It actually looks pretty good and can be made to look clean. similar to what the older gtr's have on the bumper but not square, oval and i actually think it would look good on your Volvo.
1996 850 turbo wagon auto, Custome intake, MSD coil, IPD spark plug wires, Eibach springs, Bilstiens HD, Mesh grill, IPD strut tower bar,ultra racing 2 point rear strut bar, Tiki end-links,IPD intake manifold spacer, FCP silicone inter-cooler hoses, stoptech steel braided brake lines front and rear, completely rebuilt auto tranny, Complete stage zero. soon to have (white injectors, s70 front end, 16t, ARD tune)
#50 lookforjoe
lookforjoe
  • 12,350 posts
Posted 04 January 2012 - 04:01 AM
I've seen old Swedish Rally Volvo's with bumpers like that - not really my cup of tea. Still, I'd be curious to see what a newer car looked like with a swiss cheese bumper. I doubt I would want it myself, though.
#51 T5Hammy
T5Hammy
    Dick Sledge
  • 342 posts
Posted 04 January 2012 - 11:22 PM
I like the PS of the larger opening but if i was rocking an intercooler that large I wouldn't run the grill in it. If your still trying to keep the oem+ look keep it how it is, if you wanna show off a bit make it bigger. Either way you'll probably make it look super clean as all your projects.
1998 s70 t5- auto :(, Stage 0, kw var 3, Ipd short ram, N/A TB from Snabb, FMIC 29x9x3, OBX exhaust, 18" Ipd pegs flat black, black projectors, aux tranny cooler.
#52 lookforjoe
lookforjoe
  • 12,350 posts
Posted 22 March 2012 - 02:56 AM
Working on the larger opening I had photoshopped back in Jan.
cut out the bumper & bar
cut down & splice the trim line & the contour section
started heat welding the sectioned pieces back together
thinking of leaving the bottom most grille section jutting out like this...
ran out of light.
#53 okoye
okoye
  • 518 posts
Posted 22 March 2012 - 03:12 AM
definitely interested in how this turns out
99 v70xc x2 sold
#54 D s50r
D s50r
  • 2,155 posts
Posted 22 March 2012 - 03:43 AM
Looks hungry haha nom nom nom! Looks great as always h!
98 midnight blue s70 glt se
04hpt Rn engine, 5speed swap, k24 turbo, ard blue tune, meth injection, snaab intake pipe, intake spacer, n/a throttle body, r manifold, obx exhaust, aem tru boost, d2 coilovers, ipd swaybars, 18 inch vectors, r front bumper number 2, tomcat front lip, s60r rear bbk, roof spoiler.
#55 Piston Slapper
Piston Slapper
    Old Neckbeard Deimos
  • 3,107 posts
Posted 22 March 2012 - 06:37 AM
Almost getting to the poi's bumpercooler status.
1999 S70 Base w/ Manual - "5 BANGER" - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Pioneer Double DIN, Michelin PSS's on 18x8 TDR 1.2s
1999 S70 AWD - XC Grille, Autotragic... for now.
#56 lookforjoe
lookforjoe
  • 12,350 posts
Posted 24 March 2012 - 02:14 AM
Worked some more this evening on the bumper cover
hard to photograph, but its coming along...
test fit with grille & lower valance
stock grille is now sandwiched between a cropped upper & lower grille section. Required 3 grilles in total, as each added section needs the middle ridge for proper height
#57 andyb5
    why don't you take a picture, it will last longer
  • 5,173 posts
Posted 24 March 2012 - 02:54 AM
Awesome. Even without paint, still looks very clean so far.
99 V70 R - silver & charcoal
#58 lookforjoe
lookforjoe
  • 12,350 posts
Posted 25 March 2012 - 01:48 AM
Test fitting with headlight
took about 2 hours(!) to cut back the bumper foam for the new opening, reduced depth & get the proper alignment with the fenders
#59 scandalo
scandalo
  • 1,767 posts
Posted 25 March 2012 - 02:05 AM
Love how you ran with this idea. I think this is going to be great. Finally our fronts will be different :lol:
Gonna check in. Wanna see how this shapes.
if people are hating, your doing it right
Stu M. or Stum
98 S70 2.3 stgIII
#60 VTawdR
VTawdR
  • 67 posts
Posted 25 March 2012 - 03:34 AM
Went from :o to :o lol. Btw I admire your plastic welding skeelz. I extended my 960 lip the other day, and I suck at it hardcore. Any tips?
