2000 V70 With Alternator Problems Help
#1 2000V70SLEEPER
2000V70SLEEPER
  • 1 posts
Posted 04 August 2011 - 02:18 PM
WOW THROTTLE BODY 1st ,THEN O2 SENSOR 2nd; AND NOW ALTERNATOR PROBLEMS ! CAN I CHANGE ALTERNATOR WITHOUT DEALERS HELP CORRECTLY. PLEASE HELP...
#2 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,809 posts
Posted 12 August 2011 - 03:43 AM
1. Your car is 11+ years old.
2. You need to take caps lock off and post in the right forum.
3. I have no idea if you can do this correctly. If you have a specific question on the install then maybe someone will help.
99 V70R
98 V70 GLT
#3 BEJinFBK
BEJinFBK
  • 1,760 posts
  • Gender:Not Telling
  • Interests:Lottsa stuff!
    The world is a big place...
Posted 12 August 2011 - 04:17 AM
And before you answer the question:
"Can I do it ?",
Are you SURE the alternator is bad?
#4 slowvo
slowvo
  • 143 posts
Posted 18 September 2011 - 05:15 AM
I just had my alternator replaced. Make sure you check your battery cables (especially the positive) and also the positive power feed cable (I think it is called a B cable) connected inside the fuse box. Make sure the connections are tight and if the one inside the fuse box is black or burned, it probably needs replacement. I'm not saying these ARE the problems but they could be as they can cause some problems in voltage.
2002 C70 HPT - loud&low.
