Front Pass. Control Arm Install Help
how to?
7 replies to this topic
#1 gmsgltr
gmsgltr
  • 5,499 posts
Posted 04 August 2011 - 02:44 PM
OK,
Replaced my pass. axle then found the ball joints on the control arm are shot including the rubber seals.
So now to replace the control arm:
any hints?
I dont understand the whole "Make sure to pre-load the arm" thing.
After this i will finally get a much deserved alignment!
thanks in advance,
greg
- Greg - '96 Red/Tan 855 R - M - 104k miles - '98 Blue/Charcoal V70 T5 - M - 170k miles -
#2 --Aaron--
--Aaron--
    Scum Bag
  • PipPipPipPipPipPip
  • 12,551 posts
Posted 04 August 2011 - 03:15 PM
theres a few ways to preload the arm, i prefer putting my floor jack under the hub there by the steering stop and jacking up until the hubs at right height, once u get to that point tighten the subframe bolts/nuts
u can drive up on ramps and do it that way as well
#3 erikv11
erikv11
  • 2,910 posts
Posted 04 August 2011 - 03:30 PM
Pre-load means the control arm is loaded with the weight of the car, before the two bolts are tightened where it attaches at the subframe.
The whole point is to put the control arm at the level it is during use, like parallel to the ground, before you tighten up the bolts on those bushings. You don't want to pinch them in with the control arm dangling, then lower the car and shear them.
'96 NA 855 - 111 k - daily driver
'95 R 854 - 177 k
#4 gmsgltr
gmsgltr
  • 5,499 posts
Posted 04 August 2011 - 03:50 PM
awesome thanks guys, I think I got it now... gonna take a half day at work and do it this afternoon
#5 FCP Groton
FCP Groton
  • 1,838 posts
Posted 04 August 2011 - 03:51 PM
When I did my control arms, I put a jack under the control arm and just jacked it up. This seems to be the easiest way to load them.
Andrew Owendoff
#6 Black Betty
Black Betty
  • 7,000 posts
Posted 04 August 2011 - 04:28 PM
Greg if your getting an alignment right after ask them to loosen the bolts and then tighten back up. That's what I did to my car when I replaced my c arms.
#7 erikv11
erikv11
  • 2,910 posts
Posted 04 August 2011 - 06:20 PM
hmmm maybe you wrote this because you misunderstand that I was suggesting he put the car on ramps or something? I was just explaining why it is called "pre-loading" not "pre-jacking" etc. You are trying to emulate the load of the car on the ground.
There are lots of ways to do the pre-load but of course the jack is by far the most common.
'95 R 854 - 177 k
#8 gmsgltr
gmsgltr
  • 5,499 posts
Posted 05 August 2011 - 01:23 PM
i kept them loose enough to rotate freely, then tightened them all the way once the car was on the ground
getting alignment tomorrow at stillman volvo
