Burning A Cd For 850 Stereo - Anybody Got It To Work?
Started by magnum46, Aug 12 2011 08:08 PM
11 replies to this topic
Posted 12 August 2011 - 08:08 PM
Hi
I have some music in various format, MP3, WMA.. etc.
I've tried to burn music CD's but they won;t play in the 850.
Is there a specific kind of CD to use that is more suitable? I use CDR not CDRW
Is there special software to use?
Alternatively, is there a way to make it read music from my IPhone? or a USB Drive?
Noob Here.
Noob Here.
97 850 T5 135K, Atlanta, GA
Koni FSD+Eibach, OMP Strut Bar, 8.5MM wires , ST 17PSI, 6KHid, OBX 3" SS Exhaust
StylinMotor Vac ,Turbo Hoses and Boost Gauge
Posted 12 August 2011 - 10:00 PM
I don't believe you have any options that will work with the 850 CD players.
You can get a BlitzSafe adaptor that hooks to the CD changer port on the stereo and that will allow you to use your iPhone, iPod, etc. That is what I use since I am still on the stock radio.
Posted 12 August 2011 - 10:33 PM
Every CD I burn works in my 850. Got an 816 in there....CDRW is what I use...
1996 855 Platinum Edition/2nd owner/Stainless Steel Brake Lines/Red Calipers/OBX V2 Strut Bar/Silicone Plug Wires/850R ECU/Memphis, TN
Posted 13 August 2011 - 01:50 PM
GENERALLY, you'll need to buy the "Music" CDR's. The 850 era CD players have weak lasers in them.
1994 855T Auto
Posted 13 August 2011 - 06:40 PM
make sure they burn as a Audio CD, not a MP3 CD.
1994 Volvo 850 Turbo 160K miles.
Posted 14 August 2011 - 11:26 PM
burned CDs work in my 816 only if they are burned @ 1x or 2x...any other speed and it won't read them.
'98 s70. has over 62 zip-ties
'05 xc/90. The stereo sucks.
Posted 29 August 2011 - 01:10 AM
CDs play just fine in my 815.. It might be a difference between CD-R and CD+R. I don't recall which I used.
'95 854 T5M 175k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue
Posted 30 August 2011 - 06:45 PM
Posted 30 August 2011 - 06:49 PM
Topic is aweful. If you use a program to write your CDs then just select audio cd not data.
If you write from prompt you need to assure 1. You are recording them as .wav not mp3 2. That you close the session.
The speed the CD is written at has nothing to do with play back......
Volvospeed On Google+
Posted 30 August 2011 - 06:57 PM
Posted 01 September 2011 - 12:18 AM
